| FAQ: Fuel Filters | |
+33TonySmooth89 Karma '96reese palermocorey90 Chicken 1wickedninja 97chargedriv dreww jordynarz oldsman105 racinfan 1998 Riv albertj Jason deekster_caddy ewolfe0050 xxsupergman25xx turtleman ibmoses TType_Riviera jimmyriv RhinoFLA jonly SpaceBar Brad95Riv HirohataMerc Mr.Riviera SoCal Riv robertwolf86 AA NO 4 EVR 98riv T Riley 37 posters |
T Riley Guru
Name : Travis Age : 32 Location : Minnesconsin Joined : 2007-02-08 Post Count : 5127 Merit : 10
 | Subject: FAQ: Fuel Filters Wed Mar 14, 2007 12:25 am | |
| i have never looked but where is it?? | |
98riv Moderator
 | Subject: Re: FAQ: Fuel Filters Wed Mar 14, 2007 1:30 pm | |
| Drivers side under the car infront of the rear wheel. _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
NO 4 EVR Addict
Name : Troy Age : 37 Location : Sylvania, OH (Toledo) Joined : 2007-01-26 Post Count : 645 Merit : 1
 | Subject: Re: FAQ: Fuel Filters Wed Mar 14, 2007 1:33 pm | |
| Sorry to change the subject, but does fuel leak out when this is taken off for a change? | |
 | Subject: Re: FAQ: Fuel Filters Wed Mar 14, 2007 1:37 pm | |
| Yep. Have some rags handy. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
T Riley Guru
 | Subject: Re: FAQ: Fuel Filters Wed Mar 14, 2007 3:32 pm | |
| wow thanks !!!!!!!!!!!!!!!!! would it be best to do when the car is almost empty?? or full because if its almost empty and all the gas runs out ur hosed | |
 | Subject: Re: FAQ: Fuel Filters Wed Mar 14, 2007 3:36 pm | |
| Doesn't matter, just plug it while you've got it off. It doesn't take long. I don't think I even had to jack up the car. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
robertwolf86 Fanatic
Name : robert Age : 36 Location : new york Joined : 2007-03-11 Post Count : 268 Merit : 0
 | Subject: Re: FAQ: Fuel Filters Wed Mar 14, 2007 7:35 pm | |
| there is only so much fuel that will come out when you change it. it dont matter weather it is empty or full. when you finish turn the car key half way to let the fuel pump push more fuel into the lines. it will be fine. im changing mine friday. i like the fram ones. | |
NO 4 EVR Addict
 | Subject: Re: FAQ: Fuel Filters Wed Mar 14, 2007 8:23 pm | |
| Yeah, are there any reccommended fuel filters? Or is stock the way to go? I know with the oil filter most will reccommend the bigger one, wondering if there is something like that for the fuel filter. | |
 | Subject: Re: FAQ: Fuel Filters Wed Mar 14, 2007 11:21 pm | |
| Use a stock filter. Someone at RegalGS.org bought one at Walmart and it started leaking! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: FAQ: Fuel Filters Wed Mar 14, 2007 11:22 pm | |
| idk i use fram air, oil, fuel filters. i also use castral gtx high mi 10w30 for oil | |
NO 4 EVR Addict
 | Subject: Re: FAQ: Fuel Filters Thu Mar 15, 2007 12:47 am | |
- Use a stock filter. Someone at RegalGS.org bought one at Walmart and it started leaking!
LOL. I'll check out fram | |
 | Subject: Re: FAQ: Fuel Filters Thu Mar 15, 2007 1:00 am | |
| lol the fram i got was from walmart. the part store only had pualator and i dont like them pluse it was more $ | |
SoCal Riv Enthusiast
 | Subject: Re: FAQ: Fuel Filters Thu Mar 15, 2007 5:34 am | |
| Has anyone tried the NAPA fuel filter (Gold)? | |
 | Subject: Re: FAQ: Fuel Filters Thu Mar 15, 2007 8:54 am | |
| Although I've never personally had a bad experience with Fram, I don't use them on my cars because they're among the cheapest you can get. I found this in the Wikipedia entry:
"There has also been some controversy about Frams use of average to below average oil filter medias and cardboard end caps which when compared to competitors of the same price range, may seem very lack luster despite working well enough to meet OEM Specifications."
Sorry, I'm going to pay a little extra and hope the better materials and construction pays off. What's the difference in price, a couple bucks? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
NO 4 EVR Addict
 | Subject: Re: FAQ: Fuel Filters Thu Mar 15, 2007 11:42 am | |
| See, I would rather go for the more expensive one. If it follows that more expensive = higher quality at least. Sometimes this isnt always the case. | |
98riv Moderator
 | Subject: Re: FAQ: Fuel Filters Thu Mar 15, 2007 5:29 pm | |
| There was a thread on regalgs.org from flyboy about fuel filters. He tried a few different ones and I think he found out that AC Delco was the best. _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
 | Subject: Re: FAQ: Fuel Filters Thu Mar 15, 2007 6:14 pm | |
| I'd be interested in seeing that test. Trouble with some tests is, how do you interpret the results? How do we know what's "better"? I remember some guy cut up a bunch of oil filters and claimed some were better and some where worse, but then a lot of people were wondering how he arrived at his findings, and he really couldn't provide an answer other than it was his opinion.  _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
98riv Moderator
 | Subject: Re: FAQ: Fuel Filters Thu Mar 15, 2007 8:15 pm | |
Name : Matthew Age : 36 Location : Florida Joined : 2007-01-17 Post Count : 4394 Merit : 101
 | Subject: Re: FAQ: Fuel Filters Thu Mar 15, 2007 11:47 pm | |
| i have a napa gold for ~20k miles and i haven't had a problem with cloged injectors or bad mpg(when i drive nice). i guess i will get the ac delco when i change it out here in the next month or so. its cost the same for the napa as the delco. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily  | |
T Riley Guru
 | Subject: Re: FAQ: Fuel Filters Sat Mar 17, 2007 1:20 pm | |
| FINNALLY had time to change it and it was a little tricky to do when i finnally got the rusted thing off i thought that i had broken it LOL but now i have a new filter and 92 OCTANE in there WOOOOOOF | |
 | Subject: Re: FAQ: Fuel Filters Sat Mar 17, 2007 6:34 pm | |
| what oct. were you using b4? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily  | |
T Riley Guru
 | Subject: Re: FAQ: Fuel Filters Sat Mar 17, 2007 10:00 pm | |
| 87  | |
HirohataMerc Amateur
Name : Eric Location : Pittsburgh, PA Joined : 2007-03-05 Post Count : 27 Merit : 1
 | Subject: Re: FAQ: Fuel Filters Sun Mar 18, 2007 2:56 pm | |
| Fram makes the worst filters... Used to be a good product until AlliedSignal bought them out. I use A/C Delco filters or Purolator for the rest of my vehicles. http://www.bobistheoilguy.com/ | |
 | Subject: Re: FAQ: Fuel Filters Sun Mar 18, 2007 3:18 pm | |
| - HirohataMerc wrote:
- Fram makes the worst filters... Used to be a good product until AlliedSignal bought them out. I use A/C Delco filters or Purolator for the rest of my vehicles.
http://www.bobistheoilguy.com/ One has to be careful on how they access filters. There are many factors to be taken into consideration owed to the various offerings in each lineup. FRAM offers several levels of filters, as do some others. And you need to take into consideration that these brands can also re-box other suppliers' filters. So unless Bob the oil dude is absolutely current with each brand's executive departments, he and others have no idea of the contracts or internal manufacturing changes are being executed in real-time, and what each contract/manufacturing change might represent to each filter. In other words—things change. | |
NO 4 EVR Addict
 | Subject: Re: FAQ: Fuel Filters Tue Apr 17, 2007 2:39 pm | |
| Do we have a write up or tut for fuel filter replacement? I thought I saw one floating around. I don't think it has pics but I could add them when I find the write up. | |
 | Subject: Re: FAQ: Fuel Filters  | |
