| Write-Up: Lower Intake Manifold (LIM) Gaskets | |
+45Mikel KnottyEagle rodrivi joshuadalegrimes Johnny5 96rivie th3fr4nchi5e al_roethlisberger highwaywarrior SC_Sailboat denim Z-type 3.8 Riviera VegasScott DEMonte1997 96rivi manofmany Karma moldymac BMD 97 park ave madrivage Abaddon BrianEsser robotennis61 rivman96 Eldo Rickw keller Ash deekster_caddy 98riv AA riviera2454 IBx1 ewolfe0050 TonySmooth89 dreww albertj Mr.Riviera T Riley BillBoost37 1998 Riv jax95riv Jason 49 posters |
Karma Aficionado
| Subject: Re: Write-Up: Lower Intake Manifold (LIM) Gaskets Wed Apr 27, 2011 8:58 pm | |
| If you want pics: https://rivperformance.editboard.com/t4250-write-up-lower-intake-manifold-change-on-a-95#54603Its series one, but the physical "things" are very similar. Changing the LIM was one of the first "big" jobs that I did myself. I spent awhile preparing for it and did it over the space of a week. That said, now I can and have done, LIM gaskets on both series one and two, and can blast through it in 4 hours or so. If you want to save money and are mechanically inclined, its not too bad. Must have tool is a torque wrench and basic hand tools. Its really up to your comfort level. If you've never done your own plugs and wires, then LIM may be a bit much for you. If you've done plugs, wires, oil, valve cover gaskets, etc already then go for it. That said, if you are trying to track down an oil leak that leaves traces on the driveway, likely your LIM is not the culprit.(though it is a VERY good idea to get it done. A leaking LIM lets coolant into your oil and results in a done engine) Likely the oil is your pan gasket or valve cover gaskets. To answer your question about the gaskets, LIM gaskets sit between the block and the LIM and the heads and the sides of the LIM. Valve cover gaskets sit between your valve covers and engine heads. If you want some series 2 pics, I *might* have some pics from when the 98 got done. _________________ | |
VegasScott Enthusiast
Name : Scott Location : Las Vegas, Nevada Joined : 2010-12-21 Post Count : 117 Merit : 8
| Subject: Re: Write-Up: Lower Intake Manifold (LIM) Gaskets Thu Apr 28, 2011 12:18 am | |
| Don't forget a strong back (or perferably a buddy) to help lift the supercharger and the plenum off the engine! I brought the wife out to help me do that. I searched this site first, and then made a big ass parts list, dropped a couple hundred at the parts store and went at it. I got it done in a night, but it was a long night! I had no manual at the time.
VegasScott | |
manofmany Addict
| Subject: Re: Write-Up: Lower Intake Manifold (LIM) Gaskets Mon Sep 19, 2011 11:30 pm | |
| Love how every vacuum fitting or line I remove broke or cracked today. Guess I'll be picking up an assortment of size and elbows tomorrow. Hopefully I can figure out where they all go to. Took pictures so that should help.
Going to go ahead and replace the spark plugs and pull the rear valve cover which I have a spare gasket for from 3 years ago. All this makes getting at the heater core hoses much easier. | |
manofmany Addict
| Subject: Re: Write-Up: Lower Intake Manifold (LIM) Gaskets Tue Sep 20, 2011 8:59 pm | |
| Can anyone confirm that the 97's have this? I was pretty sure I just pulled an elbow off of there with one line running to a solenoid towards the firewall. In fact, I can't find any T fittings in my garage. | |
BMD Aficionado
| Subject: Re: Write-Up: Lower Intake Manifold (LIM) Gaskets Tue Sep 20, 2011 9:35 pm | |
| I asked that very question during my repair.... - Mr.Riviera wrote:
- BMD wrote:
Thanks for the link 98Riv. Three questions...
Haven't found the P/N # for the large plastic elbow yet. ( yellow in pic )
Instead of a "T" coiming out of the manifold ( as in the pic below ), I have an elbow?! Is that only on a 96? Obviously that should be left alone aswell?
Valve cover gaskets- GM: 24503937 : Fel-Pro: VS 50465 R. Are these the revised valve cover gaskets, what are they made of?
The coolant elbow can be picked up from http://www.zzperformance.com/grand_prix/products1.php?id=370
On the 96's our vac lines are arranged differently than the 97+ due to the vac controlled transmission. We have just an elbow where the 97+ have a T. However, a T will work on a 96 should you ever need to free up another vac port on the blower or loose one in a swap.
As for the VC gaskets, i dont know what changes were made, but if the prices are the same, go with the updated version. There was a recall for other 3800's to have the gaskets replaced. If you get the elbows from zzp, they also have the proper gaskets for $14 each or $27 a pair. | |
manofmany Addict
| Subject: Re: Write-Up: Lower Intake Manifold (LIM) Gaskets Tue Sep 20, 2011 10:02 pm | |
| I just came across a picture in another thread showing the same connector I have and it's not a T fitting. My car is a 97 though. | |
manofmany Addict
| Subject: Re: Write-Up: Lower Intake Manifold (LIM) Gaskets Fri Sep 23, 2011 9:26 pm | |
| Quick question:
I opened my felpro supercharger gasket set. It came with two identical gaskets and the yellow o-rings. My assumption is that one gasket goes face down and the other face up. Is that correct? | |
BMD Aficionado
| Subject: Re: Write-Up: Lower Intake Manifold (LIM) Gaskets Fri Sep 23, 2011 10:03 pm | |
| Hmmm, my felpro gasket set didn't come with two identical gaskets? This is what mine had... Not sure why they would have two identical gaskets? | |
Z-type Aficionado
| Subject: Re: Write-Up: Lower Intake Manifold (LIM) Gaskets Fri Sep 23, 2011 10:10 pm | |
| Sounds like you got two for the price of one! Mine always came the same as BMD's. You only need one supercharger gasket.
If you have two, can I buy the other one from you? | |
manofmany Addict
| Subject: Re: Write-Up: Lower Intake Manifold (LIM) Gaskets Fri Sep 23, 2011 10:15 pm | |
| I better take another good look in the box for the smaller gasket as I didn't see it. I did get two of the larger gaskets though.
If I can figure out a way to ship it without breaking, I'd send it to you for the cost of shipping.
Last edited by manofmany on Fri Sep 23, 2011 10:17 pm; edited 2 times in total | |
Z-type Aficionado
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 8622 Merit : 180
| Subject: Re: Write-Up: Lower Intake Manifold (LIM) Gaskets Sat Sep 24, 2011 8:42 am | |
| - manofmany wrote:
- I better take another good look in the box for the smaller gasket as I didn't see it. I did get two of the larger gaskets though.
If I can figure out a way to ship it without breaking, I'd send it to you for the cost of shipping. Priority Mail flat-rate box, perhaps. happy shipping Albertj | |
manofmany Addict
| Subject: Re: Write-Up: Lower Intake Manifold (LIM) Gaskets Sat Sep 24, 2011 1:36 pm | |
| Having trouble with two connections..
Where does the 3rd fuel connector go? It seems to have a rubber elbow on it
Also, on the bottom of the evap switch, there is a connection. Diagram says it goes to the evap canister on firewall? | |
| Subject: Re: Write-Up: Lower Intake Manifold (LIM) Gaskets Sat Sep 24, 2011 1:54 pm | |
| i think you are answering your own question. The 3rd line on the firewall goes from the evap purge valve to the evap canister at the rear of the car. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
manofmany Addict
| Subject: Re: Write-Up: Lower Intake Manifold (LIM) Gaskets Sat Sep 24, 2011 4:47 pm | |
| I was confused because there were three nipples. Apparently one just contains an elbow and vents. Thanks for the help. Car is back together and running pretty good. Think I may have some slight vacuum issues but I'm going to have the shop go through the system when they do the heater core. Can't spend any more time under the hood this weekend. | |
denim Junkie
| Subject: Re: Write-Up: Lower Intake Manifold (LIM) Gaskets Sat Aug 18, 2012 4:43 pm | |
| Anyone? > Can LIM bolts be reused? A source if not? > Can the SC gasket be reused? Thanks in advance | |
| Subject: Re: Write-Up: Lower Intake Manifold (LIM) Gaskets Sat Aug 18, 2012 4:50 pm | |
| - denim wrote:
- Anyone?
> Can LIM bolts be reused? A source if not? > Can the SC gasket be reused? Thanks in advance i reused mine and they are holding fine. i think tq spec and order are more important. SC gasket can not be reused. it will come off in pieces with a razor blade. even the zzp garloc ones will fall apart with oil exposure and time. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
denim Junkie
| Subject: Re: Write-Up: Lower Intake Manifold (LIM) Gaskets Sat Aug 18, 2012 5:09 pm | |
| Subject: Re: Write-Up: Lower Intake Manifold (LIM) Gaskets Sat Aug 18, 2012 9:52 pm | |
| Agree, reuse the LIM bolts. They don't get tightened very much: Use red thread locker (GM 272 or equivalent) and torque to 11 lb-ft (132 in-lb). _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Karma Aficionado
| Subject: Re: Write-Up: Lower Intake Manifold (LIM) Gaskets Mon Aug 27, 2012 9:32 am | |
| Relevant crosspost from here: http://www.gmforum.com/1992-1999-91/doorman-has-new-aluminum-coolant-elbows-%5Bx-post-bville-pro%5D-303623/
Part # 47065hp http://dormanproducts.com/advance/p-52351-47065hp.aspx?year=2006&make=BUICK&model=LUCERNE%253A%2520CX
About frigging time someone did these in aluminum. _________________ | |
| Subject: Re: Write-Up: Lower Intake Manifold (LIM) Gaskets Mon Aug 27, 2012 2:09 pm | |
| That's awesome. In defense of the plastic ones, mine held fine with no leaks for 246k miles. But if you're taking the LIM on & off frequently, this metal part makes perfect sense.
(Keeping my brand new plastic one for as long as I can!) _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
denim Junkie
| Subject: Re: Write-Up: Lower Intake Manifold (LIM) Gaskets Mon Aug 27, 2012 3:27 pm | |
| I'm curious why plastic was chosen as the replacement. | |
| Subject: Re: Write-Up: Lower Intake Manifold (LIM) Gaskets Mon Aug 27, 2012 3:44 pm | |
| GM plastic = better quality than HELP! replacement plastic. Good price on the aluminum though at $8.50. They are aluminum, so expect some corrosion. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Write-Up: Lower Intake Manifold (LIM) Gaskets Mon Aug 27, 2012 4:49 pm | |
| - Karma wrote:
- Relevant crosspost from here:
About frigging time someone did these in aluminum. Yep. | |
| Subject: Re: Write-Up: Lower Intake Manifold (LIM) Gaskets Mon Aug 27, 2012 4:50 pm | |
| - denim wrote:
- I'm curious why plastic was chosen as the replacement.
Plastic was the original too - cost and corrosion are issues. Riv block is iron, can have a galvanic reaction with aluminum parts, I am told, if the coolant gets acidic for some reason for instance. | |
| Subject: Re: Write-Up: Lower Intake Manifold (LIM) Gaskets | |
