| Write Up: Transmission Fluid & Filter Change | |
+43IFallsRon Tajis rivierafrenchboy rk0ehn robotennis61 werdstrave manofmany charlieRobinson BMD dtrumbo DEMonte1997 BlownRiv BKRIV Jason L67 Bawb2u playa LARRY70GS moldymac beninohio BatMobile Ash flyineagle96 albertj VJD2 Eldo Cam Rickw Abaddon Mr.Riviera 96RIVMANN ibmoses 98riv captshiner deekster_caddy lionfish SpaceBar Buapo dreww turtleman pwmin AA SoCal Riv 47 posters | |
lionfish Enthusiast
Location : Suncoast Joined : 2007-01-27 Post Count : 167 Merit : 5
| Subject: Where did my Tranny Fluid Go? Wed May 21, 2008 1:41 pm | |
| I was driving home from work last week in my 95 Riv and noticed that my tranny was slipping in first gear when making left hand turns. After I got home I checked the vacuum lines from the fuel rail and throttle body that are connected to the modulator on the 4T60E and noticed that there was tranny fluid in the lines.
The tranny fluid was also low but there were no visible leaks on the floor of the garage. I also noticed over the last month grayish smoke from time to time when starting the vehicle. Is it possible that the tranny fluid in the vacuum lines was being used when starting the vehicle?
While inspecting the vacuum lines the rubber T connector on the throttle body crumbled and I was off to Advance auto parts to find some new connectors. I purchased a plastic T connector with two 3/8” and one ¼” port, a 3/8” to ¼” plastic adapter for the modulator connection, a ¼” to 3/16” plastic adapter for the fuel rail, two feet of ¼” fuel line for the modulator, one foot of 3/8 fuel line for the throttle body connection, one foot of 3/16 fuel line for the fuel rail connection, four quarts of Castrol ATF Dex III and a new Delco vacuum modulator 8662967.
I changed the vacuum lines, modulator and added tranny fluid. It appears that I lost almost 3 quarts of tranny fluid because of the leaky modulator. Is this possible?
I have been driving for a week now with no problems and better acceleration. | |
| | | deekster_caddy Master
| Subject: Re: Write Up: Transmission Fluid & Filter Change Wed May 21, 2008 2:41 pm | |
| There should not be tranny fluid in the vacuum lines. Sounds like a bad vacuum modulator. | |
| | | turtleman Expert
| Subject: Re: Write Up: Transmission Fluid & Filter Change Wed May 21, 2008 3:07 pm | |
| If the diaphragm in the modulator went bad, then ATF could pass through it. I would imagine it would happen mostly at idle since vacuum is highest and that would explain your smoke. It wasn't bad enough to effect transmission operation much so it was probably kind of bad for a while but never totally failed. | |
| | | captshiner Junkie
Name : Andrew Age : 38 Location : Cincinnati, OH Joined : 2008-07-23 Post Count : 756 Merit : -1
| Subject: Write Up: Transmission Fluid & Filter Change Mon Jul 28, 2008 6:36 pm | |
| Edit: Scroll down to the 11th post by Mr.Riviera to find the write up.
Hey could one of you guys and your infinate wisdom write up a tranny fluid and filter change for me? I've never done one before and I want to be sure not to kill anything when I do it. I tried having it done at my local "quick lube" and they said they couldn't. Needless to say, I don't go there anymore. Any pics you guys have of this operation would be awesome. Thanks. | |
| | | 98riv Moderator
| Subject: Re: Write Up: Transmission Fluid & Filter Change Mon Jul 28, 2008 8:17 pm | |
| There should be a write up on the website in my sig. _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
| | | captshiner Junkie
| Subject: Re: Write Up: Transmission Fluid & Filter Change Mon Jul 28, 2008 11:05 pm | |
| That has a good write up but the pictures have been moved or deleted. Thanks for the link though. | |
| | | 98riv Moderator
| Subject: Re: Write Up: Transmission Fluid & Filter Change Sun Aug 31, 2008 12:46 am | |
| I know this is late, but I got the pictures and I will hopefully get it updated and working some time tomorrow. _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
| | | captshiner Junkie
| Subject: Re: Write Up: Transmission Fluid & Filter Change Fri Nov 14, 2008 1:44 pm | |
| I'm going to get a trans pan gasket from GMpartsdirect.com, do I need to put some RTV on it or no? Also, what O-Rings will I need? | |
| Subject: Re: Write Up: Transmission Fluid & Filter Change Fri Nov 14, 2008 2:26 pm | |
| If it's a GM trans pan gasket, no RTV needed, it's a 'dry' gasket. Mine is this way and doesn't leak a drop. | |
| | | captshiner Junkie
| Subject: Re: Write Up: Transmission Fluid & Filter Change Fri Nov 14, 2008 2:30 pm | |
| Awesome, thanks Derek. I read on another thread about warnings of a cork gasket (no RTV) that's why I want the GM one. Any word about the O-Rings? | |
| Subject: Re: Write Up: Transmission Fluid & Filter Change Fri Nov 14, 2008 3:22 pm | |
| O-rings for what?
There is an annoying tip end thing on the filter that will ruin the whole job for you, but no O-rings that I'm aware of. | |
| | | ibmoses Aficionado
| Subject: Re: Write Up: Transmission Fluid & Filter Change Fri Nov 14, 2008 7:26 pm | |
| Do not use RTV, if any of it makes contact with the fluid it will dissolve and end up in the transmission. Bert | |
| | | 96RIVMANN Fanatic
Name : Paul Location : MN Joined : 2007-10-22 Post Count : 253 Merit : 11
| Subject: Re: Write Up: Transmission Fluid & Filter Change Sat Nov 15, 2008 10:13 pm | |
| I just did this last night on my '96 and I went to the stealer and paid up for and original gasket. Torqued the pan gasket bolts 12-13ft lbs and put it 6.5 qts of valvoline dex111/merc. The worst part of the job is getting that goddamm seal out of the tranny where the filter plugs into! | |
| | | Mr.Riviera Expert
| Subject: Re: Write Up: Transmission Fluid & Filter Change Tue Jun 30, 2009 7:49 pm | |
| Just finished changing my transmission filter and fluid for the second time since i got my riv. I try to do it every 30k, and my fluid was loosing its red color. It's a simple job, but i figured there still should be a write-up on here. I used 6.5qts of the new dexron VI fluid and a napa filter which comes with a new oem style gasket (beware of the cork ones). expect to pay around $80 in oil and a filter to do this yourself. i DO NOT recommend having your transmission flushed. Simply changing the filter and half the fluid will be safer and still keep your trans happy and alive. A big thanks to TType_Riviera for making this write-up! Servicing filter and fluid in your trans is pretty simple, a little time consuming considering there's no drain plug in the pan, however there is a drain plug above the pan, up near the passenger side cv joint, but that wont get all your fluid out.
If your trans seems sluggish, shifts funny, fluid smells burnt, and is a dingy brown color, chances are a filter and fluid change is in order. Your torque converter probably holds a good 5 quarts by itself, which you cant drain. If your fluid is really burnt, I would recommend doing it again soon. By doing this service, your increasing the life of your trans a great deal.
Tools and Misc things needed.
Jack and jack stands drain pan rags few cans of brake clean 1/4" drive ratchet, extension and a 10MM socket 7 quarts of new trans fluid (Dexcron/Mercon ONLY) new filter, gasket and filter seal (comes as a kit)Start by putting the car on your jack stands. Slide the drain pan under the corner of the pan shown below. Start removing the bolts on that corner, once you have about 5 of them out, only loosen the next few, and you should start seeing fluid drip out of that corner, loosen a few more untill there's a pretty good stream, and let it completely drain.
Once it is drained, start removing more bolts, when you come to the last 6 or 7 support the pan tight against the trans while removing the rest of the bolts, as there still some fluid in the pan, once removed carefully lower the pan down an dump the rest of the fluid in the pan. Next remove the old filter, and filter seal. The filter is easily removed, just simply pull an turn it a little an is should slide right out. Now the filter seal is probably going to be a slight pain, and you'll probably ruin it before you get it out. Use a flat head screw driver, to cave the side of it in, then just simply grab it with some pliers an work it out, doing your best not to score the inside surface. Next clean your pan really good with brake clean, cleaning all dirt off the gasket surface, and the magnet in the far corner, then let dry. Then take the new filter seal from the filter kit, and push it into the port, you will probably need to tap it very softly with something to push it in completely. I used a socket the same diameter as the seal, and it went right it. Next slide in the new filter, it may take some force but it will go, tap it until it stops, it should fit in the area nicely. Next take the pan and the new gasket and fit it to the shape of the pan. Take 4 pan bolts and push them through the holes and through the gasket, they should fit very tightly in the gasket, thus keeping the gasket aligned for an easy reinstallation. Be sure to spread the bolts evenly, as shown in the picture. The filter kit will come with either a rubber or cork gasket. They say the rubber gaskets can be reused, and are usually installed from the factory. I was a little weary about reusing the gasket, and just used the new one. You don't need any kind of sealer on this application, and NEVER use sealer on a cork gasket, it WILL leak.
Now clean the gasket surface of the trans with some brake clean or paint thinner will work, by wetting a rag. Then lift the pan and gasket in to place an start each of the 4 bolts, and lightly snug them, and then install the rest of the bolts. Once all of them are snug start in the center of the pan an moderately tighten the bolts, crossing back and forth working your way to each end. After that go back through an give each bolt a light tweak assuring there all tightened fairly even.
Drop the car back down on the wheels, pull the trans dip stick, set it aside, grab a small funnel, and proceed to dump in at least 5 quarts for now. after all 5 quarts are in, start the car and let the trans get warm, then run it through each gear 3-5 times. This will pump the fluid around where it needs to be so you can get an accurate reading on the dip stick. It took about 7 quarts to completely fill mine, but id suggest adding fluid a little at a time so you don't over fill it just in case yours doesn't need 7. Once the right oil level is reached, check for leaks, an easily drive around the block, come back an give it one more check, you may have to add a touch. Check for leaks again. After a few hundred miles I would check the pan bolts again most likely they will need a small turn.
This should fix your sluggishness an problems with shifting, if not you have bigger problems, and should see a professional trans shop.
If done correctly, you should have the end results of a smooth running, smooth shifting, and cooler running trans and a better responding trans as well. Good Luck to whom ever gives this a go there self, Remember All of us here on the board are always here to help!!!!_________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| | | Mr.Riviera Expert
| Subject: Re: Write Up: Transmission Fluid & Filter Change Tue Jun 30, 2009 7:56 pm | |
| Forgot to mention, always check the magnet for metal particles. it is a good indicator as to how well your transmission is holding up. Here is mine after 40k pretty hard miles. Just a thin layer of metallic sludge. Oh, and i have a spare oem gasket if anyone needs it. i wasnt sure what shape it was in so i got a new one, but they are reusable and mine looks good still. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| | | AA Administrator
| Subject: Re: Write Up: Transmission Fluid & Filter Change Sun Mar 07, 2010 7:08 pm | |
| Anyone have torque specs for the pan bolts? My shop manuals are hiding from me! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| | | Mr.Riviera Expert
| Subject: Re: Write Up: Transmission Fluid & Filter Change Sun Mar 07, 2010 7:15 pm | |
| will post them when i get home unless someone beats me to it. the numbers i have are for the 4t60 though. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| | | AA Administrator
| Subject: Re: Write Up: Transmission Fluid & Filter Change Sun Mar 07, 2010 8:42 pm | |
| I used 11 lb-ft. Seemed to feel right. I'll re-torque to spec in a couple weeks, when I have the real spec. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| | | Abaddon Expert
Name : Scott Location : Macomb, Michigan Joined : 2010-02-24 Post Count : 4316 Merit : 185
| Subject: Re: Write Up: Transmission Fluid & Filter Change Sun Mar 07, 2010 10:40 pm | |
- Anyone have torque specs for the pan bolts? My shop manuals are hiding from me!
97 INCH lbs. | |
| | | AA Administrator
| Subject: Re: Write Up: Transmission Fluid & Filter Change Mon Mar 08, 2010 12:07 am | |
| Or... 8 lb-ft, thanks. However, I didn't twist any off! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| | | Rickw Guru
| Subject: Re: Write Up: Transmission Fluid & Filter Change Mon Mar 08, 2010 12:47 am | |
| I just remembered that for a 10mm size bolt I generally go with max of 100 in. lbs. as a general rule. Only if I really feel the need to torque something that is delicate. Otherwise I use my calibrated arm. Always have just used my feel on things like the trans pan or oil pan, valve covers, etc. | |
| Subject: Re: Write Up: Transmission Fluid & Filter Change Mon Mar 08, 2010 2:20 pm | |
- I used 11 lb-ft. Seemed to feel right. I'll re-torque to spec in a couple weeks, when I have the real spec.
be careful. Over tightening will easily strip the threads out of the transmission. | |
| | | AA Administrator
| Subject: Re: Write Up: Transmission Fluid & Filter Change Mon Mar 08, 2010 2:44 pm | |
| Yeah, I was trying to be careful by posting the question, but the response just didn't come in time, and it was getting dark, and cold, so I had to guess. Turns out my wife hid my shop manuals in one of 72 plastic containers in our basement, so I had no idea which one to look in (she was out of town).
What actually happened (in my case a long time ago) is the heads of the bolts will twist off, leaving the shanks embedded in the holes. I did this with a large torque wrench set to 13 lb-ft. Of the 15 or so bolts, 3 heads came off. I think I misread the manual, which actually said 13 newton-meters (9.59 lb-ft, or 115 lb-in). Being that 13 lb-ft was on the bottom of the range, I'm sure it was off by 10% or so.
I'm guessing GM used softer bolts for this reason.
Yesterday I used a smaller torque wrench set to 132 lb-in (11 lb-ft) with no issues, although next time I'll check the manual. 13 lb-ft was too much from experience, that much I remembered. So I used 11 lb-ft. I'll re-torque in a week or so, as they like to loosen up a little bit.
I don't like trusting my arm to tighten, because I always under tighten. I've tried it before, then checked with a torque wrench - I'm usually under by 25% or so. You have to be REALLY GOOD with tools to know exact torque just by feel. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| | | ibmoses Aficionado
| Subject: Re: Write Up: Transmission Fluid & Filter Change Tue Mar 09, 2010 1:31 pm | |
| I use a 1/4" drive ratchet on those bolts, no problem so far. Bert | |
| | | Cam Rookie
Name : Cam Joined : 2009-03-15 Post Count : 11 Merit : 0
| Subject: What is the total fluid capacity of our transmission? Fri May 21, 2010 4:27 pm | |
| Haven't posted here in a long time, but I've been lurking. I would post more, but everyone here already knows more than me anyways. Much as the first time, I come asking for guidance. My transmission has an odd shift, I suspect it's because of the scam artists who rebuilt it didn't do a good job, but I've got this additive (I know, I know, snake oil and all that. This brand is usually pretty good), thing is, it's potent stuff, I can't put it in in concentrations greater than 1%. I doubt it will fix the problem, which is probably a mechanical issue, but it might help some.
I've found a source that said 13.4 quarts, but I've no idea how reliable there are, and many other sources seem ambiguous to whether the amount they list is the actual capacity, or simply what needs to be added back in after dropping the pan. But, I trust you guys, so I'm asking for help, again. I wish I could give something back, but I honestly just don't know that much about our cars. | |
| | | Sponsored content
| Subject: Re: Write Up: Transmission Fluid & Filter Change | |
Similar topics | |
