| Write-Up: Yellowed Corner Lenses | |
+57IFallsRon h20man joshuadalegrimes Sir Psycho Sexy llamalor2112 matt270avian charlieRobinson ALR37115 HeartBeatRivi c0reyl Jelorian gmann3001 96riv BMD jlaw ghpcnm IBx1 nebstewart07 bigdave GMFreak8 Steve98 robotennis61 steve s 1wickedninja #1BearsFan woggy dnyce200 DEMonte1997 Eldo Rickw ibmoses albertj Sweepspear sburch23 curious riv deekster_caddy KillaKeninaRiv TonySmooth89 Shintsu manofmany nothincame2mind palermocorey90 Jack the R jimmyriv Buapo SpaceBar 97Riv-Jon turtleman Rivgirl06 Mr.Riviera 99Rivman Andysdorm jax95riv 1998 Riv AA xxsupergman25xx T Riley 61 posters |
| Subject: Re: Write-Up: Yellowed Corner Lenses Sun Aug 18, 2013 2:27 pm | |
| Nice. Looks a lot better! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
charlieRobinson Expert
Name : Charlie Age : 39 Location : Knoxville, TN Joined : 2011-05-17 Post Count : 3924 Merit : 31
| Subject: Re: Write-Up: Yellowed Corner Lenses Sun Sep 08, 2013 8:49 pm | |
| Can we get white light bulbs for these corner lamps? My headlights and running lights are eurolamps bright white and when I use these corner lamps, they are that yellow orange light.
What bulb should I look at to swap in for these? | |
h20man Enthusiast
Name : Aaron W. Age : 30 Location : CT Joined : 2013-10-04 Post Count : 242 Merit : -2
| Subject: Re: Write-Up: Yellowed Corner Lenses Mon Jan 27, 2014 2:12 pm | |
| Anyone ever tint the corner lenses? If so how does it look? | |
matt270avian Expert
| Subject: Re: Write-Up: Yellowed Corner Lenses Mon Jan 27, 2014 2:17 pm | |
| I've seen it done. Looks like crap IMO. | |
h20man Enthusiast
| Subject: Re: Write-Up: Yellowed Corner Lenses Mon Jan 27, 2014 9:28 pm | |
| Really? It has to look better than yellowed corners any pics? | |
matt270avian Expert
| Subject: Re: Write-Up: Yellowed Corner Lenses Mon Jan 27, 2014 10:35 pm | |
| They're on here somewhere. Just clean up the lenses, it will look better. | |
IFallsRon Fanatic
Name : R.L. Joined : 2012-11-23 Post Count : 268 Merit : 2
Animator Member
Name : Rob Age : 69 Location : South Coast Metro, CA. Joined : 2014-02-06 Post Count : 68 Merit : 2
| Subject: Re: Write-Up: Yellowed Corner Lenses Sat Mar 22, 2014 3:16 pm | |
| I used TR-3 with similar results. I think it is the factory clear spray coat, and not the plastic iteslf, that discolors, oxidizes, and peals. Wondering if a clear coat for UV protection might be a good idea now that the factory clear coat has been polished off. | |
th3fr4nchi5e Addict
Name : Dave Age : 31 Location : Cheektowaga, NY (Buffalo) Joined : 2010-10-31 Post Count : 572 Merit : 30
| Subject: Re: Write-Up: Yellowed Corner Lenses Sat Mar 22, 2014 3:22 pm | |
| I use 1200 and 2000 grit sand paper to wetsand and then 3M rubbing compound with a buffer once or twice a year and they look like new after but they start to yellow a bit after a few months but it takes less than 5 minutes to do them both each time so thats not really a burden. | |
Z-type Aficionado
| Subject: Re: Write-Up: Yellowed Corner Lenses Sat Mar 22, 2014 9:29 pm | |
| I think it's been about a year since i did mine. I polished them to perfection then clear coated them with urethane clear coat. Robo suggested it to me once...they haven't changed in the slightest since then! | |
High Chaparral Member
Name : Chris Age : 61 Location : Springfield, Illinois Joined : 2014-05-04 Post Count : 75 Merit : 1
| Subject: Re: Write-Up: Yellowed Corner Lenses Sun May 25, 2014 2:04 pm | |
| Great suggestions as always !!! Picked up the 3M and Turtle Wax kit off Amazon for about $7 each. Just finished using the 3M kit. Spent about an hour, turned out pretty good . Wish I had a corded drill though, although the cordless would have done it on a full charge. Put on a couple coats of synthetic wax will see how long it stays clear. With the drill attachment, correct sandpaper, and polishing compound should be easy to cleanup again. Went ahead and did the entire tail light this morning (recharged drill), and had enough left over from the kit. A few of my neighbors were watching me, and a couple thought I was ruining my tail light when they saw me sanding it. Have to admit I was also alittle worried too. After finishing though "we" were all impressed with the results. Just take your time, and use plenty of tape ................ | |
| Subject: Re: Write-Up: Yellowed Corner Lenses Mon May 26, 2014 8:11 pm | |
| 3M kit is even cheaper now on Amazon than what I paid. Too bad you can only submit 1 rebate . $13.49 current price - 3.00 coupon - 5.00 rebate $ 5.49 total | |
| Subject: Re: Write-Up: Yellowed Corner Lenses | |
