 FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)
brettfavreisamonster
jayeli
farmboy92
gmann3001
knuckled1
Bowersk
greg_anderson_78
95RiviSC
GMfan1111
tech408
curious riv
BKRIV
mrod7510
'96reese
Joey98riv
BillBoost37
1998rivman
urbsnspices
97rivman
43 posters
p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 Empty
PostSubject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)   p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 EmptyTue Oct 13, 2009 6:29 pm
I'll assume with infinite resistance between the ICM and PCM the car wouldn't run at all.?
No its just the designated Cam Sensor wire which is one of many wires going from the ICM to PCM. I tested one of the other wires going to the PCM and found zero resistance in order to confirm the testing procedure.
tech408
tech408
PostSubject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)   p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 EmptyTue Oct 13, 2009 9:59 pm
I'll repost what I found:PO341 code, 1998 Riviera
I found a broken wire in connector c101, pin a7, black 18 gauge wire to the ignition module. The wire was broken inside the insulation so it looked like it was good from the outside. C101 is the big 72 wire connector near the trans dip stick and A7 is the black wire on the bottom left side of the connector. It's a tight squeeze but you have to cut the wire before and after the connector to jump around it. Test the connection first with a meter between the connector then after confirming the open, gently pull on the wire with a needle nose from the front of the connector, and look to see that the insulation stretches indicating that wire inside is broken from the stress of the weight of the harness.
PostSubject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)   p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 EmptyWed Oct 14, 2009 11:23 am
Excellent post - only one thing to add.
Because of where the wire is broken, another option is to repair the connection. Use a jeweler's screwdriver to back the terminal out of the connector. Using a small vise or a pair of vise grips to hold the terminal, spread the wire crimp open (or simply use another pair of needletip pliers to yank out the butt of the wire). Then take the pin back out to the car. If there is enough wire in the harness you can simply strip a bit and solder the terminal back on, then reinsert it into the connector using that jewelers screwdriver if needed. If there is not enough wire in the harness, then splice, solder and insulate a short length on sufficient to let you reattach (solder) the terminal back on and reinsert it into the harness. If you do the repair this way you MUST be careful not to distort or fatigue the terminal because if you do it won't re-insert, will break on reinsertion, or some other failure.
Don't get me wrong - I am NOT saying Tech408's approach is bad, because it is a standard and avoids the problems that can ensue if you attempt to repair the connector without the Kent-Moore equipment. Another advantage is that Tech408's approach makes it real easy to find later where a harness has been spliced, and yet another advantage is that terminals to be repaired properly at a convenient time/place in the future are real easy to find. It's a good field fix. However I think you all might benefit from being aware of this alternative in cases where it's an advantage to repair in such a way that the connector can be normally detached, unless you also plan to put a spade or bullet connector in your splice.
In the FSM the approach that is taught is to use a repair kit to replace the bad terminal - pin or socket - in the connector, which if you have the Kent-Moore kit is fairly easy. Problem is, the kit is a cathedral unto itself -- take a look
http://www.acdelcotechconnect.com/pdf/imtn_V11I404.pdf
https://gmspecialservicetools.spx.com/Documents/Promotions/GM08-195.PDF (with prices)
These silly kits cost a bundle - great for a busy busy repair shop but just not something in a journeyman's reach. Give you a hint - the complete kit lists for about $6,100.-
Again - excellent post.
PostSubject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)   p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 EmptyWed Oct 21, 2009 12:22 am
Ok just want to make sure that I'm testing the right wire and getting a correct readout from my ohm meter. I'm testing the black wire that is designated Camshaft Position Sensor input at pin 5 (shown in the chart below) at the PCM, and also testing the believed corresponding black wire at the ICM where the large connector is (shown in picture below) for circuit resistance. When it was tested in this fashion it returned an infinite resistance. Just need to know if this reading is true because the wire is bad or it read that value because its the wrong wire.
p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 Icmn
p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 P0341
tech408
tech408
PostSubject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)   p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 EmptyWed Oct 21, 2009 12:29 am
check for continuity between the point you highlighted and the large connector to the left of the brake booster on the firewall. the circuit starts at the CPS, then into the ignition module, out of the ignition module, into the connector on the firewall, out of the connector and finally into the ECM. Read the details from my original post. It describes the exact locations. Good Luck
PostSubject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)   p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 EmptyWed Oct 21, 2009 12:34 am
Is my method inconclusive? It seems that the test you are calling for it very similar. I understand that your test will allow me to pinpoint the area of trouble but the planned solution was to splice in a new black wire near the ICM and route it along the passenger-side fender through the firewall to the PCM as turtleman did with his. I am in no way bashing your approach, just wondering how it differs smile
PostSubject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)   p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 EmptyWed Oct 21, 2009 12:51 am
I never looked at the pinout for the engine harness as it plugs into the firewall but you could check it from the ICM to there instead of the ICM all the way to the PCM inside. More than likely, the failed wire would be under the hood, rather than inside the car under the dash, but nothing's impossible.
To answer your original question, Matt, unfortunately the same reading of infinite resistance means it could be a broken connection in the wire or wrong wire just the same. It is important to be sure that you are looking at the right wire. It doesn't hurt to test other same color wires to be sure as I've found that my factory service manual actually said the wrong PCM connector.
If you have the pinout for the firewall connector, I would go head and check it to the ICM connector, like tech408 said. Don't forget to check between the actual cam sensor and ICM also! The trend for failure seems to be between the PCM and ICM but it's still entirely possible the problems right there.
PostSubject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)   p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 EmptyWed Oct 21, 2009 1:09 am
I did check another wire using the PCM pin chart I have and it returned zero resistance, so i believe that the pin # given to me for the black wire is correct. However I will still check the firewall harness to make sure that it is correct.
PostSubject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)   p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 EmptyWed Oct 21, 2009 8:29 pm
Here's some more stuff (including fuller images of somethings i posted) that someone may find of use.
p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 Pg1jt
p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 Pg2x
p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 Pg3s
p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 Pg4q
p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 Pg5t
GMfan1111
Location : In a undisclosed Bunker somewhere in Metro detroit
PostSubject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)   p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 EmptyWed Oct 21, 2009 11:47 pm
hopefully the problem will be fixed soon I'm the latest person to have a crack at fixing it (I'm also L67's older brother for any new members here) it's been helping me get my performance objectives done in my electrical class. (hopefully i do not end up with the other poor souls who couldn't fix it). The game plan is exactly what L67 said which involves the said wire splice. I'm just hoping the Car alarm does not throw another revolt like last week where it was set off by absolutely everything.
PostSubject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)   p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 EmptyFri Oct 23, 2009 1:59 am
Well GMfan1111 tested my car is his auto electrical class today and found some continuity issues between the ICM and previously mentioned firewall connector in the black wire. So it seems that that wire problem. He ran out of time in his class so the wire splicing will have to wait until next week.
PostSubject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)   p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 EmptyWed Nov 04, 2009 2:36 pm
Well my brother and dad were working on my car back home and found this:
p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 Wirem
The arrow points to the end of the black CPS wire that is cut from the circled plug in the big connector behind the trans dipstick that was mentioned a few posts up. It must've been weak or frayed when i was doing the rocker install, and all of the movement of parts to access the back VC tore it apart.
PostSubject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)   p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 EmptyWed Nov 04, 2009 3:00 pm
Good find. Hopefully all your issues will be taken care of with this repair.
PostSubject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)   p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 EmptyWed Nov 04, 2009 3:26 pm
joy joy joy
PostSubject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)   p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 EmptyWed Nov 04, 2009 8:17 pm
Good Work! clap
And thanks for taking the time to post the pics.
Bert tavis
PostSubject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)   p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 EmptyWed Nov 04, 2009 8:37 pm
ibmoses wrote:
Good Work! clap
Bert tavis
No problem, hopefully they will be of assistance to frustrated people in the future smile
PostSubject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)   p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 EmptySat Nov 07, 2009 11:49 pm
Code is officially gone, thanks to all who helped!
PostSubject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)   p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 EmptyWed Jan 20, 2010 7:03 pm
Matt, how did you actually do the repair at the main connector?
PostSubject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)   p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 EmptyWed Jan 20, 2010 11:19 pm
The wire was spliced with a tube splicer and wrapped up with tape.
95RiviSC
95RiviSC
PostSubject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)   p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 EmptyTue Feb 16, 2010 6:25 pm
I just had this code pop up on mine (as well as some others). The car has been running like absolute garbage lately. Hopefully I can take care of it soon.
http://www.clublakers.com
PostSubject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)   p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 EmptyMon Mar 29, 2010 5:12 pm
Hey everybody. I am back again with yet another issue. I hope it is the last for a while. I have had some time off of school recently thus why I have been posting on my number of problems...
Anyway, this code has been popping up in the '98 for a little over a month now. The code came up right after I replaced the LIM gasket and the supercharger gasket and replaced the coupler. So, I got one code (bank 1 lean code) out of the way and now I have the P0341 code up.
I have tried to fix it in a bunch of ways by now. I replaced the camshaft sensor, then had a CASE learn done. The code remained, and the GM dealer did the CASE learn and recommended a new cam sensor b/c they assumed the one I had put in was bad for some reason, even though it was new. So I had somebody else put another one in this time, not me, and the code remained after that.
I noticed this thread and saw that most people solved the problem by patching up a wire/wires going from the ICM to the PCM. I checked all of the wires for continuity and they are all good. So, I took it to my regular mechanic and they feel that the PCM may need to be replaced. They scanned it and showed me that the scanner is getting a readout from the cam sensor and I could see the "pulse" from it, or w/e you want to call it, on the scanner as the sensor fed it data... regardless, I am stuck.
Anybody have any suggestions? Let me know if more info is needed. I've been working on this for a few months now and can't seem to think of a solution except doing something with the PCM.
PostSubject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)   p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 EmptyMon Mar 29, 2010 5:16 pm
You can get a working PCM off ebay for less than $100, programmed already to your VIN - just have to install and do a CASE Learn.
PostSubject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)   p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 EmptyMon Mar 29, 2010 6:01 pm
That's probably what I will have to do. I personally can't think of anything else that could fix the problem.
PostSubject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)   p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 EmptyMon Mar 29, 2010 6:10 pm
As long as your absolutely sure that the wiring is all good to and from the PCM as mentioned earlier, then you can try a used one from Morads.
I think I paid about $50.00 for one a few years ago from them, installed it, performed a CASE learn even though the car was running good with no CEL and has worked good since.
PostSubject: Re: FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)   p0341 - FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain) - Page 6 EmptyThu Jun 03, 2010 5:12 pm
I recently got home from school and started thinking about this problem again, as the SES is still on. I did not replace the PCM yet. I took the car to a different mechanic. He thought that the magnet for the timing chain may be bad/not strong enough, or something. And then he let me know that fixing such a problem may involve replacing the timing chain, at least, which he let me know would be quite expensive as he can't even do it himself. He said that other mechanics let him know that it may be a problem with the timing chain magnet (if I remember correctly), possibly losing strength.
I really don't know what to think of this issue and I would appreciate some help. Because a ~$1000 repair for something as small as a magnet, after all of the things that I've had to work on for the past few years, may just lead to me selling this car (my 98, not my 95). I would love to keep it for the rest of my life... regardless, I just want to see what other people think about this before I possibly go throwing another huge amount of money into something that may not even fix this issue. The SES light is still on but the car doesn't seem to drive any worse than usual.
Page 6 of 10Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
» Camshaft position sensor
» Transmission problem..is it all in my head? (Camshaft Position Sensor)
» Timing Chain replacement & timing
» Crank position sensor?
» Oil leak from Timing chain cover?
