| Broken crank pulley leads to timing cover removal | |
+8L8-2BNGO deekster_caddy albertj ewolfe0050 Rickw Chicken AA Mr.Riviera 12 posters |
| Subject: Re: Broken crank pulley leads to timing cover removal Fri May 08, 2009 1:42 pm | |
| Maybe a small bolt extractor, or drill a small hole and tap it, then thread a bolt in there to pull on... or else tack weld something to it to hit.
Or pull the timing cover... is that key still attached by the bottom timing gear? | |
| Subject: Re: Broken crank pulley leads to timing cover removal Fri May 08, 2009 2:04 pm | |
| will it just fall out if i pull the timing gear? i literally dont have a car until that 1/2" piece comes out _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Broken crank pulley leads to timing cover removal Fri May 08, 2009 2:30 pm | |
| I'm not a welder, but could a professional tack a small rod of metal to the key, then use the leverage to pull it out? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Broken crank pulley leads to timing cover removal Fri May 08, 2009 2:34 pm | |
| IDK, but i dont have a welder nore the ability to get it to a welder right now.
the drill bit doesnt even touch it though. btw, i can move the piece up and down a little, but not out. this is sooo frustrating. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Broken crank pulley leads to timing cover removal Fri May 08, 2009 3:00 pm | |
| I think you need to remove the timing cover and lower gear to get that out.
Why did you start changing the keyway anyway? (it's besides the point now, feel free to ignore and answer later)
It's just the timing cover... get started!! It shouldn't take that long to remove. | |
| Subject: Re: Broken crank pulley leads to timing cover removal Fri May 08, 2009 3:02 pm | |
| after all this I really hope this solved your problem!! | |
| Subject: Re: Broken crank pulley leads to timing cover removal Fri May 08, 2009 3:11 pm | |
| the keyway was broken to begin with, or else i would have left it. it got it half way out again. running out to get some needle nose vise grips. wish me luck, timing cover doesnt look like it comes off easily. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Broken crank pulley leads to timing cover removal Sat May 09, 2009 11:42 am | |
| ok i got the timing cover off. chain looks good, dampener looks good. but do i need to have a cylinder at TDC to get the chain off or can i just pull the tensioner and remove the lower gear? i dont want to F up my cam timing. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Broken crank pulley leads to timing cover removal Sat May 09, 2009 12:23 pm | |
| ok i figured out TDC with the 2 dots. now i just need to break loose the cam bolt. what a PITA! _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
L8-2BNGO Enthusiast
Name : Devin Age : 37 Location : Orlando Joined : 2009-03-28 Post Count : 135 Merit : 2
| Subject: Re: Broken crank pulley leads to timing cover removal Sat May 09, 2009 6:21 pm | |
| holy crap i just fiund this post..... dang man main seal again....
trying to cam it?.... | |
| Subject: Re: Broken crank pulley leads to timing cover removal Sat May 09, 2009 7:15 pm | |
| lol no time to buy a cam this time. RR's still in the future.
this time it wasnt the main seal, but the defective advance auto parts harmonic balancer that broke.
just now getting everything back together. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
L8-2BNGO Enthusiast
| Subject: Re: Broken crank pulley leads to timing cover removal Sat May 09, 2009 7:35 pm | |
| dnag bro! if u were here id help ya. i was going to ask you, have you ever thought about 1.8 rr? i say those because becasue you can keep the stock springs, and less wear on dampner? | |
| Subject: Re: Broken crank pulley leads to timing cover removal Sat May 09, 2009 11:12 pm | |
| got a brand new gm dampener in there, and my chain looks to be in pretty good shape. i'm going with 1.9's, but i dont know what springs yet.(LS6 90's or comp 105's)
project update (day 5, hour 11) : finally got the cam bolt undone (had to be 200 ft-lb on that thing) pulled off the chain, both gears and the damn key still wouldnt come out easily! what i'm guessing happen (bases on the marring of the crank) if the key broke when the balancer shaft cracked. a piece of the key spun with the balancer around the crank making a lip and burring up the rest of the key. after the crank gear was pulled i had to take a screw driver and hammer to chissel out the key, but it finally came out. i filled down some of the lip and burs to allow the new key to slide right in. took a look at my old dampener and saw it was not only pretty worn down, but the back side ha broken off(not really a big deal), so i knew i had to get a new one. probelm is only one store in town had ONE. across town at a dealer. sent the parents to get it while i carved off parts of the old gaskets. i then pieced everything back together, no screws left over, used thread sealant on all the screws that went into coolant or oil passages, and bolted everything down. all was good until i test fitted the new ballancer and it somehow siezed up on there! went to the parts store and rented a ballancer puller. i thought it was going to be easy since i had done this like 4 times now. NOPE! the bolts that came with the kit stripped out, but now it is too late to get new ones.
so... tomorrow morning i'll be off to the hardware store to get 3 new bolts so i can pull the ballancer, put the new front main seal in, and bolt up the ballancer. then an oil change, replace coolant, and cross my fingers that it fires up with no leaks.
fuck this week! _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
TonySmooth89 Aficionado
| Subject: Re: Broken crank pulley leads to timing cover removal Sat May 09, 2009 11:18 pm | |
| Damn dude...sorry about you're luck,
Hope it all goes well tommorow...
Look on the bright side , after all this , helping me install rockers should seem easy. | |
| Subject: Re: Broken crank pulley leads to timing cover removal Sat May 09, 2009 11:30 pm | |
| yea, at least i feel confident pretty much rebuilding a 3800 motor now. i've seen how most of it goes together at one time or another. i know i'll eventually blow this motor for good and build one outside the car, then drop it in. i have to admit, i called up my uncle around noon to come over and help since he has built many of motors, rebuilt tons of trannys, and was a mater tech. he supervised and help find all the bolts on the timing cover. so far the total cost (after the defect parts were returned) ~300 including the $70 tow down the street. could have cost well over $1000 in a shop though. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Broken crank pulley leads to timing cover removal Sat May 09, 2009 11:40 pm | |
| What kind of balancer are you getting? GM this time I hope??? | |
L8-2BNGO Enthusiast
| Subject: Re: Broken crank pulley leads to timing cover removal Sat May 09, 2009 11:45 pm | |
| im jealous of your know how. thats my goal to eventually learn how to build/rebuild a motor. | |
| Subject: Re: Broken crank pulley leads to timing cover removal Sat May 09, 2009 11:46 pm | |
| - deekster_caddy wrote:
- What kind of balancer are you getting? GM this time I hope???
god yes. everything going in or on the car is made by gm except the aluminum gaskets by felpro. forgot to mention that i got the front end gasket kit so all the seals and gaskets on that side of the car have been replaced. (heater hose o-rings were bad too) _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Broken crank pulley leads to timing cover removal Sun May 10, 2009 12:08 am | |
| Subject: Re: Broken crank pulley leads to timing cover removal Sun May 10, 2009 12:41 am | |
| Thanks for the pics, and good luck!! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Broken crank pulley leads to timing cover removal Sun May 10, 2009 9:57 am | |
| IT'S ALIVE!!!!!!! ...no leaks, no CEL, more low end torque (guessing the new dampener made a small difference in the chain tension? ) _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
1wickedninja Addict
Name : Josh Age : 36 Location : port saint lucie, Fl Joined : 2008-07-30 Post Count : 647 Merit : 5
| Subject: Re: Broken crank pulley leads to timing cover removal Sun May 10, 2009 10:14 am | |
| Subject: Re: Broken crank pulley leads to timing cover removal Sun May 10, 2009 12:13 pm | |
| - Mr.Riviera wrote:
- (guessing the new dampener made a small difference in the chain tension? )
No. Good work! A bit more than you thought you were getting into, huh? | |
| Subject: Re: Broken crank pulley leads to timing cover removal Sun May 10, 2009 12:18 pm | |
| Glad you go it together! Are you sure you its not because you haven't driven it in a while? I know when i drive around almost anything for a few days that the rivs torque seems much more impressive when i get back into it. | |
| Subject: Re: Broken crank pulley leads to timing cover removal Sun May 10, 2009 2:53 pm | |
| that very well could be. i rarely go a day without driving my car, so to go 5 days in a Camry and then jump in the riv for a test drive... _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Broken crank pulley leads to timing cover removal | |
