| Identifying and Correcting Disc Brake Judder | |
+15norsky86 98inSFl albertj robotennis61 Mr.Riviera Rickw deekster_caddy TType_Riviera urbsnspices jax95riv T Riley HirohataMerc SoCal Riv AA 98riv65lark 19 posters |
Name : Rick Location : Lancaster, MA Joined : 2008-09-13 Post Count : 6281 Merit : 118
 | Subject: Re: Identifying and Correcting Disc Brake Judder Sun Jan 24, 2010 7:52 pm | |
| Yes, the Riv is especially sensitive to torque of the wheels. I keep an extra torque wrench and socket in the trunk, so if it goes in the shop for anything i can't do and it requires them to remove the wheels I insist on an even torque up to the recommended max of 100 ft/lbs and supply the torque Wrench to do it. When they try to argue and say the torque sticks are what they use, I just insist or ask them to allow me to torque the wheels. It doesn't take much to warp the rotors. | |
98inSFl Enthusiast
Name : Ed Location : WPB Florida Joined : 2010-01-16 Post Count : 249 Merit : 14
 | Subject: Re: Identifying and Correcting Disc Brake Judder Sun Jan 24, 2010 8:07 pm | |
| what does the f body conversion require? Camero rotors and calipers? do they just bolt on? | |
 | Subject: Re: Identifying and Correcting Disc Brake Judder Sun Jan 24, 2010 8:11 pm | |
Last edited by AA on Sun Jan 24, 2010 9:34 pm; edited 3 times in total (Reason for editing : Added Link) | |
 | Subject: Re: Identifying and Correcting Disc Brake Judder Sun Jan 24, 2010 9:59 pm | |
| Matt, I would use something of quality, but not too expensive. The Royalty rotors I bought last year have performed admirably for over 14k miles. No cracks except some roughness near the drill holes, but this is minor and not really of any concern. If you get concerned, Royalty offers a lifetime warranty against cracking and warping, IF you follow their installation instructions. More: https://rivperformance.editboard.com/brakes-suspension-f6/rotors-and-pads-t2081-135.htmMine are wearing down, so I will replace them eventually. If they don't crack or warp, I'm not going to take advantage of their warranty. I may buy another set, or I may get a set of slotted only, although these seem to be more expensive. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
norsky86 Amateur
Name : dylon Location : Eau claire Joined : 2009-11-30 Post Count : 25 Merit : -2
 | Subject: need some info Fri Mar 26, 2010 12:02 pm | |
| i toke my car into the shop and found out my rotors are warped and im looking to get some crossed drilled rotors or sumthing that will handle the driving i give my riv any imput on websites and prices for performance rotors and brake pads | |
Name : Mark Age : 58 Location : West Salem, Oregon... FINALLY Joined : 2009-04-09 Post Count : 3104 Merit : 104
 | Subject: Re: Identifying and Correcting Disc Brake Judder Fri Mar 26, 2010 5:30 pm | |
| These rotors warp easily... Do a search for 'rotors' - you'll find a couple of long discussions. | |
 | Subject: Re: Identifying and Correcting Disc Brake Judder Fri Mar 26, 2010 5:49 pm | |
| If you are really hard on brakes, I recommend Hawk HP Plus street/track pads. They are a bit noisy and will wear (thin) down your rotors after 20k miles or so, but they will not shake or warp in that time, and they stop your Riv quick. Unlike all-out race pads, they grip really well when cold.
Cross-drilling helps keep the rotors cool, but does not guarantee you won't get some judder - track cars usually run solid rotors to lower the risk of cracking. The important things are to use good iron and abrasive pads to keep the compound deposits from building up unevenly - and that costs money. I run slotted & drilled rotors now, and will probably run slotted only next time.
• Pick a set of rotors in the $150/pair range. • Use high-temp, abrasive street/track pads. • Be prepared to replace after 20-30k miles. • Upgrade to F-Body front calipers if you can. • Don't drag on your brakes when you drive. • Don't stop completely with hot brakes.
That's the price paid to stop a 2-ton Buick from high speed over and over again. On the plus side, it's a much lower price than a big brake kit, which can be $4-6k. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
Name : Matthew Age : 36 Location : Florida Joined : 2007-01-17 Post Count : 4394 Merit : 101
 | Subject: Re: Identifying and Correcting Disc Brake Judder Fri Mar 26, 2010 6:26 pm | |
|  i've done some serious experimenting with pads and rotors over the past year and i think i finally found a combo that works for my driving style. powerslot rotors and HPS pads. ($300 for front rotors and pads for my f-body setup) _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily  | |
soulbladexll Amateur
Name : Jon Age : 32 Location : Toledo/oh Joined : 2010-05-20 Post Count : 30 Merit : 0
 | Subject: Car is shaking Mon May 31, 2010 10:57 pm | |
| If I am going over 60 or 70 and brake my car does this horrible shaking and makes this loud bumping noise... I replaced the the struts/shocks although my elc is acting up. It seems like after I get it to shake it does it for awhile afterwards even at lower speeds. I cant tell if its abs acting up or rotors or maybe something else.
plan to replace all rotors here soon because i dont know when they were changed last and the fronts have some nice grooves in them. But does anyone have a suggestion or experience with what it could be? | |
 | Subject: Re: Identifying and Correcting Disc Brake Judder Mon May 31, 2010 11:17 pm | |
| Sounds like you have a few problems happening at the same time. - horrible shaking when braking at high speed: rotors are warped. They may stay warped until they cool down again, and then seem to improve. I had this problem when I used a cheaper pad compound. When you replace the rotors, also replace the pads - use a quality pad: ceramic or semi-metallic (not organic). - loud bumping noise: did it happen before you replaced the struts? Is it more of a bumping, or clanking, or is it grinding? Does it happen when you go over bumps, or only when you brake? Only at high speed? - ELC acting up: see ELC thread... https://rivperformance.editboard.com/brakes-suspension-f6/electronic-leveling-control-elc-problems-t2995-180.htm#110711- ABS acting up: do you ever see the ABS light come on? - grooves in rotors: this happens when either the pads are the rotors get too old. Replace both and you should be fine. If the grooves are very deep, it means the pads are worn out and you are grinding metal to metal. In this case, fix ASAP! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^
 | Subject: Re: Identifying and Correcting Disc Brake Judder Mon May 31, 2010 11:27 pm | |
| When you have the wheels off again and are inspecting or replacing your brakes, make sure you take the time with a crow bar and check the front lower control arm bushings and ball-joint as well. Also, check hub bearings for wear. Pretty much inspect everything you can possibly think of that Rotates or moves up and down. You need to find that noise. There's plenty to read here on brakes. Aaron has authored a lot of very valuable info on brakes. So, even if you should choose to replace your brakes with Stock type or perforfamce brakes, everything you will need to know is already been published. Do a little searching and you'll find a huge amount of info.
Good Luck | |
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 8517 Merit : 181
 | Subject: Re: Identifying and Correcting Disc Brake Judder Tue Jun 01, 2010 1:15 am | |
| I wonder at what mileage it's a good bet to just replace the front control arms? (to get new ball joints and bushings ) | |
 | Subject: Re: Identifying and Correcting Disc Brake Judder Tue Jun 01, 2010 1:31 am | |
| I wouldn't get new arms - just replace the ball joints and bushings, right? At 204k miles, the right side ball joint is loose (cracked boot). The left is fine, and all of the bushings seem okay (as checked by front end mechanic last week). _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: Identifying and Correcting Disc Brake Judder Tue Jun 01, 2010 1:46 am | |
| AA, Do most of the roads you travel have no potholes or any other defects that would account for such high mileage without what would be considered normal front end component wear. 200K and only needing a right balljoint is a bit remarkable even with the Riv.
At what year are the parts no longer available individually and you have to replace the whole control arm to get new bushings and balljoints.
Short of trying to find the compatible equivalents, which after reading on here for quite a while, I haven't seen anyone post a specific P/N of a known manufacturer of aftermarket parts like Moog, etc that will fit.
I have seen guys, especially overseas, mention they have taken a part made for another vehicle and machined it down to fit, as far as bushings go. But I don't have the P/N's of those either.
Has anyone documented the parts that are usable for the later model Riv's and I have missed it possibly.? | |
 | Subject: Re: Identifying and Correcting Disc Brake Judder Tue Jun 01, 2010 2:16 am | |
| - Quote :
- AA,
Do most of the roads you travel have no potholes or any other defects that would account for such high mileage without what would be considered normal front end component wear. 200K and only needing a right balljoint is a bit remarkable even with the Riv. I do live in the snow belt, and we have salted roads in the winter. The result is a lot of cracks and potholes. It's not as bad as MI, but Ohio roads are always being patched and resurfaced. I have cracked a rim before hitting a chuck hole. I've also lost control and hit a curb. But I can count these 'high impact' events on one hand. I do my best to avoid hitting surface irregularities at all costs. I also plan my routes around certain stretches of road - if I can, I'll slow down for tracks and other obstacles. It's just not worth the risk, imo. I usually don't go too fast over unfamiliar road, for more reasons than avoiding bumps. Partly it's good luck, too, I guess. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
Name : Derek Age : 50 Location : Reading, MA Joined : 2007-01-31 Post Count : 7717 Merit : 109
 | Subject: Re: Identifying and Correcting Disc Brake Judder Tue Jun 01, 2010 9:56 am | |
- I wouldn't get new arms - just replace the ball joints and bushings, right? At 204k miles, the right side ball joint is loose (cracked boot). The left is fine, and all of the bushings seem okay (as checked by front end mechanic last week).
I would get the whole arm, to save on the labor. It comes with bushings and ball joint already installed and doesn't cost much more, maybe even less than the labor to get the bushings swapped out. At least get a price. | |
 | Subject: Re: Identifying and Correcting Disc Brake Judder Tue Jun 01, 2010 9:58 am | |
| Hmm, all right. I'll check into it. Thx for the info. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Car is shaking Fri Jun 04, 2010 9:08 pm | |
| The Riv is shaking really bad at even slow braking when 65mph+ It seems to shake the steering wheel a lot, and i dont think its my rotors because I have no pulsing in the pedal. Anyone have This problem before?
-Jon | |
 | Subject: Re: Identifying and Correcting Disc Brake Judder Fri Jun 04, 2010 9:24 pm | |
| I don't understand shaking with no pedal sensation. Please explain further.
 | Subject: Re: Identifying and Correcting Disc Brake Judder Fri Jun 04, 2010 9:36 pm | |
| shaking as in almost like anti lock brakes kicking on... and its really loud. | |
 | Subject: Re: Identifying and Correcting Disc Brake Judder Fri Jun 04, 2010 9:59 pm | |
| You would feel ABS in the brake pedal.
FIrst thing to do it put the car on a lift or jackstands and inspect the suspension.
 | Subject: Re: Identifying and Correcting Disc Brake Judder Mon Jun 07, 2010 9:45 am | |
| Sounds like you have warped front rotors. Take the wheels off, put a few lug nuts back on, and measure rotor runout with a dial indicator. You aren't getting any pedal feedback because it's shaking the steering wheel instead. If the steering was rock solid you would feel it in the pedal also. | |
 | Subject: Re: Identifying and Correcting Disc Brake Judder Mon Jun 07, 2010 9:56 am | |
| I agree it's likely the rotors, but they may not be warped... yet. Have you used the brakes very hard lately? Do you see any marks on the rotors? Have the pads been changed in a while?
Read back through this thread for more info on the causes of brake rotor judder. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: Identifying and Correcting Disc Brake Judder Tue Jun 08, 2010 1:21 am | |
| thanks guys i was planning to do 4 new rotors anyways... i might be selling the riv soon and it makes me cry to think of what i will be driving if i do sell it... a geo metro... | |
 | Subject: Re: Identifying and Correcting Disc Brake Judder Tue Jun 08, 2010 10:00 am | |
| Do the front rotors first. The rears may be ok. Easy way to check the rears is to engage the parking brake while car is rolling. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: Identifying and Correcting Disc Brake Judder  | |
