| Crunching/Clunking/Roaring noise on takeoff and turning | |
+10Rickw 99Rivman deekster_caddy GMFreak8 woggy Snowdog xxsupergman25xx robotennis61 AA RivGuy 14 posters |
RivGuy Member
Name : Bob Norton Joined : 2009-06-14 Post Count : 76 Merit : 0
![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | Subject: Crunching/Clunking/Roaring noise on takeoff and turning Fri Nov 06, 2009 3:50 pm | |
| I have a 97 SC with 23000 miles, dealer put new belts on for me and now when make a right turn under power I get what sounds like a bad wheel bearing, but it did not do it till the belts were changed. When you turn right with no power it sounds OK Left turn OK. | |
![Go down](https://2img.net/i/empty.gif) | |
![AA](https://2img.net/u/3215/30/10/37/avatars/1-6.jpg)
Name : Aaron Age : 47 Location : C-bus, Ohio Joined : 2007-01-13 Post Count : 18448 Merit : 252
![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | Subject: Re: Crunching/Clunking/Roaring noise on takeoff and turning Fri Nov 06, 2009 4:40 pm | |
| I wonder if this could have something to do with the engine mount that needs removed to access the belts? Was it correctly replaced and tightened?
To confirm, you can take a right turn hard with no throttle, and there's no noise, right? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ ![frown](/users/3215/30/10/37/smiles/icon_sad.gif) | |
![robotennis61](https://2img.net/u/3215/30/10/37/avatars/342-35.jpg)
![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | Subject: Re: Crunching/Clunking/Roaring noise on takeoff and turning Fri Nov 06, 2009 5:04 pm | |
| whats a roar? maybe its more of a grinding noise? | |
RivGuy Member
![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | Subject: Re: Crunching/Clunking/Roaring noise on takeoff and turning Sat Nov 07, 2009 4:56 pm | |
| No noise when turning right without power, and the roaring noise is not grinding but a low level roaring kinda like a bad bearing but steady opposed to spaced out, hard to discribe, but all was done was R&Ring the engine mount to replace the 2 belts | |
![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | Subject: Re: Crunching/Clunking/Roaring noise on takeoff and turning Tue Nov 17, 2009 3:02 am | |
| ... ![cat](https://2img.net/i/fa/i/smiles/icon_cat.png) | |
RivGuy Member
![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | Subject: Re: Crunching/Clunking/Roaring noise on takeoff and turning Tue Nov 17, 2009 11:29 am | |
| robotennis61 Did you foget include a construtive comment in your reply? would appreciate some helpfull info. | |
xxsupergman25xx Aficionado
![xxsupergman25xx](https://2img.net/u/3215/30/10/37/avatars/68-55.jpg)
Name : Scotty Age : 37 Location : Pittsburgh, PA Joined : 2007-03-03 Post Count : 1251 Merit : 13
![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | Subject: Re: Crunching/Clunking/Roaring noise on takeoff and turning Tue Nov 17, 2009 11:38 am | |
| lol could it be ur power steering is going bad? | |
Snowdog Addict
![Snowdog](https://2img.net/u/3215/30/10/37/avatars/656-51.jpg)
![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | Subject: Re: Crunching/Clunking/Roaring noise on takeoff and turning Tue Nov 17, 2009 12:06 pm | |
| roaring?...could be a hiden tiger...lol:D
well if your bearing is bad you can hear the noise when you drive straight and when you turn then it should go aweay...depending which side bearing is bad....normaly the bearing goes bad in the 'midle'...and when you turn right or left inside the bearing the balls move on right or left side of the bearing ring where it has not cone so bad yet...then it would not make a sound. and the bearing sound you could hear on +40miph.
i dont think its bearings fault when you say that the sound comes only on turning?. are the belts correctly on pulleys? well its a small chance but maybe the belt isent fully on the power steering pulley what will start to make a sound when you turn hard cos the pump slows the belt movement...
(i know my english suck but i truy my best...lol) | |
![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | Subject: Re: Crunching/Clunking/Roaring noise on takeoff and turning Tue Nov 17, 2009 2:23 pm | |
| - Quote :
- well if your bearing is bad you can hear the noise when you drive straight and when you turn then it should go aweay...depending which side bearing is bad....normaly the bearing goes bad in the 'midle'...and when you turn right or left inside the bearing the balls move on right or left side of the bearing ring where it has not cone so bad yet...then it would not make a sound.
I've always experienced the opposite - quiet on the straight, and growling when putting load on the bad bearing in a hard turn. But I don't think a bearing is Bob's problem, as he's said it corresponds with throttle + turn. A bearing wouldn't do that. Maybe check CV joints for a rip in the boot? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ ![frown](/users/3215/30/10/37/smiles/icon_sad.gif) | |
woggy Enthusiast
![woggy](https://2img.net/u/3215/30/10/37/avatars/861-19.jpg)
Name : Paul Age : 62 Location : Altoona, Florida (Somewhere in the ocala national forest) Joined : 2009-04-28 Post Count : 201 Merit : 7
![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | Subject: Re: Crunching/Clunking/Roaring noise on takeoff and turning Tue Nov 17, 2009 2:32 pm | |
| with 23k on the car I doubt a bearing is failing, as for a cv it would make a loud clicking sound when turning, so prolly not a cv joint. I would check belt alignment with all pulleys. I suspect a tensioner pulley to be the culprit. also check that motor mount to see if it straight and the bolts are tight. | |
![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | Subject: Re: Crunching/Clunking/Roaring noise on takeoff and turning Tue Nov 17, 2009 2:43 pm | |
| Good point about the low mileage. I'm still thinking it's the motor mount. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ ![frown](/users/3215/30/10/37/smiles/icon_sad.gif) | |
![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | Subject: Re: Crunching/Clunking/Roaring noise on takeoff and turning Tue Nov 17, 2009 5:28 pm | |
| a similiar sound,not exactly a roar,could come from the power steering rack or pump when the wheel is turned to full lock, it can make a whiring sound ![cat](https://2img.net/i/fa/i/smiles/icon_cat.png) | |
![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | Subject: Re: Crunching/Clunking/Roaring noise on takeoff and turning Tue Nov 17, 2009 5:46 pm | |
| like roboslammer said....it makes an ALARMING whirrrr noise. heard more at slower turns. colder temps also seems to aggrivate the hell out of it. | |
GMFreak8 Addict
![GMFreak8](https://2img.net/u/3215/30/10/37/avatars/813-62.jpg)
Name : Kyle Age : 36 Location : Malone, New York Joined : 2009-03-15 Post Count : 638 Merit : 15
![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | Subject: Crunching/Clunking on takeoff and turning. Engine Mounts? Thu Dec 10, 2009 7:19 pm | |
| So I brought the Riviera in for an oil change yesterday. For the last month or so I've heard what amounts to cold snow crunching under the wheels on harder takeoffs and especially when making a turn onto a street that is higher up or lower than the one you are turning off from if that makes sense. Also occasionally I'll hear it when taking a turn from a stop. It seems to be less pronounced when the car warms up. I can also feel it in the gas pedal and the steering when it does occur.
Anyway, I talked to the guy I have do my oil changes, and he works on race cars, and does body work and engine building as a side job. I thought it might have been ball joints or something, but he's telling me he suspects that the engine and tranny mounts are causing the noise.
My question is, I know that these can be problematic on these cars, but I'm wondering what you all think of his idea. Also where can I get replacement mounts? I've looked and I can't find any definitive answer.
Any direction or input would be greatly appreciated. Thanks, Kyle. | |
![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | Subject: Re: Crunching/Clunking/Roaring noise on takeoff and turning Thu Dec 10, 2009 8:05 pm | |
| I wouldn't be surprised if it were front and/or rear tranny mounts. My front is shot and it makes some funky clunking when I put it in gear or switch to reverse. | |
99Rivman Aficionado
![99Rivman](https://2img.net/u/3215/30/10/37/avatars/4-33.jpg)
Name : Randall Location : North Carolina Joined : 2007-01-16 Post Count : 2009 Merit : 90
![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | Subject: Re: Crunching/Clunking/Roaring noise on takeoff and turning Thu Dec 10, 2009 8:26 pm | |
| - deekster_caddy wrote:
- I wouldn't be surprised if it were front and/or rear tranny mounts. My front is shot and it makes some funky clunking when I put it in gear or switch to reverse.
I had the same problem on my '99, and getting lots of vibrations, and ended up replacing both the front and rear mounts. | |
![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | Subject: Re: Crunching/Clunking/Roaring noise on takeoff and turning Thu Dec 10, 2009 10:24 pm | |
| Kyle, Try www.monsterpartsonline.com They are only available new from GM and are not cheap. | |
![albertj](https://2img.net/u/3215/30/10/37/avatars/149-76.gif)
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 8658 Merit : 181
![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | Subject: Re: Crunching/Clunking/Roaring noise on takeoff and turning Thu Dec 10, 2009 10:39 pm | |
| RockAuto.com sells an insert for the tranny mount.
![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | Subject: Re: Crunching/Clunking/Roaring noise on takeoff and turning Thu Dec 10, 2009 10:43 pm | |
| Albert, never heard of an insert for the mounts. Do you have a link. | |
![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | Subject: Re: Crunching/Clunking/Roaring noise on takeoff and turning Thu Dec 10, 2009 10:53 pm | |
| Kyle, The OEM GM P/N's are: For 95-98 Front Trans = #22201114 Rear Trans = 22201115
There are two other mounts but are not normally a problem with the miles you have. I have replaced both of the above at about 85K miles. They were junk. | |
![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | Subject: Re: Crunching/Clunking/Roaring noise on takeoff and turning Fri Dec 11, 2009 12:32 am | |
| my front control arm vertical bushing makes the same noise and is totally shot i found out today.. | |
![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | Subject: Re: Crunching/Clunking/Roaring noise on takeoff and turning Fri Dec 11, 2009 12:37 am | |
| Aren't you one of the lucky ones with the replaceable bushings.? How many miles on your car? And how come it wasn't noticeable when you were changing springs, etc. ??? | |
![Eldo](https://2img.net/u/3215/30/10/37/avatars/842-2.jpg)
Name : Mark Age : 59 Location : West Salem, Oregon... FINALLY Joined : 2009-04-09 Post Count : 3164 Merit : 104
![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | Subject: Re: Crunching/Clunking/Roaring noise on takeoff and turning Fri Dec 11, 2009 12:51 am | |
| - Rickw wrote:
- Kyle,
Try www.monsterpartsonline.com They are only available new from GM and are not cheap. Jeezus, you guys aren't kidding... $500 worth of mounts to hold this thing in?!? Is that 4th one on the driver's side a Series 1 only? I can't find it in this manual. | |
![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | Subject: Re: Crunching/Clunking/Roaring noise on takeoff and turning Fri Dec 11, 2009 12:57 am | |
| I didn't know about this site or optional sources for parts when I needed trans mounts and paid GM Dealer Retail. Can you say..Bend Over.
There are 4 mounts total. We talk about front and rear when the manual calls them left and right. Because the engine is transverse. I have a parts sheet showing all of them. I can list the P/n's of the other two if you wish. | |
![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | Subject: Re: Crunching/Clunking/Roaring noise on takeoff and turning Fri Dec 11, 2009 1:04 am | |
| No thanks, the Monster chart for the factory diagram describes them rationally: Passenger engine mount; Front, rear, and driver transaxle mounts. I've just never noticed the driver's side mount before, I thought we only had front, rear and passenger side. ![oops](https://2img.net/i/fa/i/smiles/icon_redface.gif) | |
![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | Subject: Re: Crunching/Clunking/Roaring noise on takeoff and turning ![Crunching/Clunking/Roaring noise on takeoff and turning Empty](https://2img.net/i/empty.gif) | |
