duster_do_little Enthusiast
Name : Dustin Age : 36 Location : Midland, MI Joined : 2008-11-15 Post Count : 171 Merit : 4
 | Subject: Re: PCM / Chip Upgrade? Sat May 15, 2010 2:31 pm | |
| okay, gotcha.
Cold air is good because it's dense which allows more into the engine, but a warmer running engine will produce more power. Therefore, if you can get your motor to run reliably at a higher temperature you will get higher hp gains (ie adiabatic). Heat is energy, and loss of heat is loss of energy. | |
 | Subject: Re: PCM / Chip Upgrade? Sun May 16, 2010 12:51 pm | |
| I don't know if I'd go that far. Cold air is good, but hot engines are not, especially not in the case of our supercharged engines. Our engines will not make more power when hot, because of knock. I know they used to say the more heat you could keep inside the engine (referring to the NA type), the more power you could make, so it makes more sense to use cast iron parts rather than aluminum. But I read about a test done a couple years ago where they compared a couple cast iron V-8s, swapping out the block and heads from iron to aluminum, and the result was the engines made the exact same power. However, the aluminum engines are much lighter, and they radiate heat much more efficiently, so they run cooler - these are key advantages in racing, and in any performance car, really. The reasons you see cast iron stay around so long is long-term durability, and manufacturing costs. There are probably other reasons, but making power is not one of them. Aluminum engines make just as much power without trapping in the heat, and they are lighter, cooler running = better all around. For the supercharged 3800, it's all about flow of air molecules in, through, and out of the engine (good breathing, boost, and keeping the air cool), and also keeping knock in check. This means heat is bad, always. You want to engine to get warm so that it works most efficiently, but above 180ºF you won't get any extra power from increased combustion temps. If an L67 used aluminum block and heads, you would likely see more power from it. So as a rule, keep intake air temps as cool as possible, or intercool. Keep engine and transmission temps as close to 180ºF as possible. Modify for better breathing. Doing these things will help your engine live longer, make more power, and perform better overall. More on engine air flow: https://rivperformance.editboard.com/series-ii-engine-transmission-f4/why-is-air-flow-important-t194.htm_________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
flyineagle96 Junkie
Name : James E Age : 54 Location : Dalton,Mass Joined : 2009-12-21 Post Count : 915 Merit : 23
 | Subject: Re: PCM / Chip Upgrade? Tue Sep 28, 2010 10:45 pm | |
 | Subject: Re: PCM / Chip Upgrade?  | |
