 Radiator / Coolant Leaks
sniperdude
pbrktrt
95rivy
Ridin-Rivi
black shadow
jonly
BrianEsser
playa
jeffyd123
98inSFl
96riv
lionfish
6spd
vendetta
BillBoost37
96RIVMANN
1996RIV CALI
mcgusto82
43 posters
Radiator / Coolant Leaks - Page 6 Empty
PostSubject: Re: Radiator / Coolant Leaks   Radiator / Coolant Leaks - Page 6 EmptyThu Jun 17, 2010 12:00 am
Yeah, regular 3800 parts are a dime-a-dozen. The place we deal with has it stocked in their warehouse, takes a day to get. The Alternator is about $130 with tax (my price).
As far as the For Sale sign.....lol. NEVER! It's 12 years old, I love it, and shit happens. It's just ironic that the timing these parts have for Fa!Ling. It seems every time I fix one thing, something completely unrelated goes.....pretty soon, the whole damn thing will be new, and then the process starts over lol.
it's the warranty-period-or-10-year-150,000-mile-engineering-design-life thing.
Merit : 104
PostSubject: Re: Radiator / Coolant Leaks   Radiator / Coolant Leaks - Page 6 EmptyThu Jun 17, 2010 12:21 am
And/or the bean-counters and sales types over the engineering and "car guys"...
PostSubject: Re: Radiator / Coolant Leaks   Radiator / Coolant Leaks - Page 6 EmptyThu Jun 17, 2010 11:04 am
Thx again for the heads up on that 150A Rick. Got one comin. It will be here tomorrow (not stocked). $147 for that bad boy (again, my price). The stock 140A was like $125. I'll pay the extra $12 for 10A more!
EDIT: NAPA called back, the Alternator will be here by 5pm today! joy
EDIT #2:Alternator in. All is well....now to fix them leaky trans cooler lines.
PostSubject: Re: Radiator / Coolant Leaks   Radiator / Coolant Leaks - Page 6 EmptySat Jun 19, 2010 11:02 pm
Ya know, I always thought it was a characteristic of the Riv with it's mods, to make it to 215* sitting at a light with a 160* thermostat. I've been wrong lol. Given that our Radiator has a gap between it and the Condensor, but yet appears to be "sealed" with no possible way of intrusion, I find this.....
Radiator / Coolant Leaks - Page 6 100616_163355
Not to forget the cigarette butts and leaves/sticks that were embedded on the core support. The car barely reaches 200* now, and runs about 175* cruising.
It's crazy what good airflow can do bonk
Merit : 104
PostSubject: Re: Radiator / Coolant Leaks   Radiator / Coolant Leaks - Page 6 EmptySat Jun 19, 2010 11:07 pm
You're so right... Mine wasn't that bad, but for some reason I pulled the top support not long after I bought my car, and found the same thing. After I cleaned it out, it started obeying the thermostat.
Those dam mice,shoot"em. LOL shoot
Merit : 104
PostSubject: Re: Radiator / Coolant Leaks   Radiator / Coolant Leaks - Page 6 EmptySat Jun 19, 2010 11:41 pm
Or put them in tiny electric chairs, inside a gas chamber, with lethal injection tubes... lmao
PostSubject: Re: Radiator / Coolant Leaks   Radiator / Coolant Leaks - Page 6 EmptySun Jun 20, 2010 12:38 pm
Would that be as simple as pulling the top panel off and using a wetdry vac with a nozzle, or do I have to drain/pull the radiator for this cleanout?
PostSubject: Re: Radiator / Coolant Leaks   Radiator / Coolant Leaks - Page 6 EmptySun Jun 20, 2010 1:05 pm
You'd have to pull the radiator out to clean it good. The space between the Rad and Condenser is only about 1/2". That's why I'm surprised all that chit built up in there like that.
PostSubject: Re: Radiator / Coolant Leaks   Radiator / Coolant Leaks - Page 6 EmptySun Jun 20, 2010 1:08 pm
OK thanks. I think I will pull the panel and inspect then decide.
Merit : 104
PostSubject: Re: Radiator / Coolant Leaks   Radiator / Coolant Leaks - Page 6 EmptySun Jun 20, 2010 3:42 pm
I didn't pull the radiator... I think I just blasted in through the radiator & condenser fins, then down and out from the top, with a garden hose nozzle.
Ridin-Rivi
Ridin-Rivi
PostSubject: Leaking Coolant - Any Ideas?   Radiator / Coolant Leaks - Page 6 EmptyTue Apr 05, 2011 9:45 am
Whats going on everyone. Here my little/major problem.
I have a coolant leak from which appears to be in the front of the motor. I replaced the radiator about 2 years ago and that seems fine as there is no coolant directly under the radiator and all of the hoses seem dry and ok. The coolant reservoir is clean and doesn't appear to be mixing with oil. Does anyone have any ideas what this could be? Whats located in the front of the motor that would leak coolant?
Thanks
PostSubject: Re: Radiator / Coolant Leaks   Radiator / Coolant Leaks - Page 6 EmptyTue Apr 05, 2011 10:02 am
take a picture.........
Ridin-Rivi
Ridin-Rivi
PostSubject: Re: Radiator / Coolant Leaks   Radiator / Coolant Leaks - Page 6 EmptyTue Apr 05, 2011 10:17 am
I dont think a picture would help much but this may give some of you a clue.
I let the car warm up for awhile and the top radiator hose is warm but the bottom one is as cold as when I started the car.
jonly
jonly
PostSubject: Re: Radiator / Coolant Leaks   Radiator / Coolant Leaks - Page 6 EmptyTue Apr 05, 2011 10:39 am
I'd try bleeding the system once, there's a valve on top of the thermostat housing. I ran into this with mine as well
Ridin-Rivi
Ridin-Rivi
PostSubject: Re: Radiator / Coolant Leaks   Radiator / Coolant Leaks - Page 6 EmptyTue Apr 05, 2011 10:46 am
Whats the proper procedure for doing that? Also where is the thermostat located?
Thanks
jonly
jonly
PostSubject: Re: Radiator / Coolant Leaks   Radiator / Coolant Leaks - Page 6 EmptyTue Apr 05, 2011 10:49 am
I opened it up, ran the car until it stopped belching and spitting air out of the valve, closed the valve when it was spraying straight coolant, turned the car off.
I don't do anything right though, I'm sure someone will correct my procedure for you.
what was happening with mine was the coolant was ending up in the overflow, and then onto the ground, once I got the air out it stopped leaking.
PostSubject: Re: Radiator / Coolant Leaks   Radiator / Coolant Leaks - Page 6 EmptyTue Apr 05, 2011 5:57 pm
Thanks
Follow the top rad hose to where it meets the engine, that is the thermostat housing and on top of that is the bleeder valve.
95rivy
95rivy
PostSubject: Re: Radiator / Coolant Leaks   Radiator / Coolant Leaks - Page 6 EmptyTue Apr 05, 2011 7:20 pm
could it be at bad thermostat , not allowing the coolant to flow??
PostSubject: week old coolant leak, gettin bigger   Radiator / Coolant Leaks - Page 6 EmptyWed Oct 17, 2012 5:53 pm
So I didn't realize I had this leak until today. For about a week, coincidentally about the time I took out my stock airbox for my spectre filter. After driving I'd notice a sort of rich cornoil scent and occasionally see white smoke seep out my hood at a stop. I'd always stop to check n it always appeared to be from tge drivers side so I figured the oiled filter was just breaking in or something....obviously not though. Yesterday my low coolant light came on for a minute or so, so I added some dexcool. Now today the leak is clearly visible. It seems to be pooling here at the end of this hose (not from the hose but rather the metal mount?? Though not 100% on that) it pools there and overflow drips down the side of the engine down to the bottom....
Radiator / Coolant Leaks - Page 6 IMAG2271
My first reaction is just take it to my mechanic to fix...no idea the cost though confused
Merit : 63
PostSubject: Re: Radiator / Coolant Leaks   Radiator / Coolant Leaks - Page 6 EmptyWed Oct 17, 2012 6:05 pm
Looks like you're about right on where it's leaking from. It seems a new thermostat seal and gasket is in order. Perhaps even a new thermostat, just in case?
One quick suggestion though, since I know my 3800 engines pretty good at this point. Check and make sure you're lower intake gaskets aren't at fault too. This happened to my Series II L67 in my Bonneville. Turned out the bolts weren't torqued down, causing coolant to pool in a similar spot.
Though, I think you just have a bad thermostat housing seal or gasket, or both.
pbrktrt
PostSubject: Re: Radiator / Coolant Leaks   Radiator / Coolant Leaks - Page 6 EmptyWed Oct 17, 2012 8:34 pm
Have to agree with Andrew, you can clearly see the leak path in the photo. An easy, inexpensive fix.
PostSubject: Re: Radiator / Coolant Leaks   Radiator / Coolant Leaks - Page 6 EmptyWed Oct 17, 2012 9:05 pm
Under $15 to fix, and you can do it yourself in less than an hour. While you're at it, replace with a 180º t-stat - your first mod!
Question: if you are adding dexcool, why does the coolant look green? Might be good time for a coolant flush.
PostSubject: Re: Radiator / Coolant Leaks   Radiator / Coolant Leaks - Page 6 EmptyWed Oct 17, 2012 9:15 pm
Did a flush while I was at it to rectify the mix of coolant. (Old was not dexcool but was so low when I added the other day, I couldn't see to know) Ran to napa to get a new tstat, seal and gasket. Did the swap (my old seal had a gnarly chunk missing on one side!) and found that mine didn't now, nor ever had a gasket. In fact, the "correct" gasket won't even line up to fit. So we're gonna see if everything seals as it should be or not. If not, will have to make a gasket for it but I'm pretty confident that won't be necessary.
PostSubject: Re: Radiator / Coolant Leaks   Radiator / Coolant Leaks - Page 6 EmptyWed Oct 17, 2012 9:44 pm
There is a gasket available and you can cut your own gasket from a sheet of gasket material but many RivPerformance members have found that the rubber ring that the thermostat (well, the OE thermostat) comes with is enough, if the mount surfaces are clean.
Page 6 of 8Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
» Write-Up: Flushing Radiator Coolant
» FAQ: Dexcool / Coolant / Antifreeze Types
» 95 Radiator replacement missing "Coolant Sensor"?
» Trunk Leaks
» common oil leaks
