| Radiator / Coolant Leaks | |
+39charlieRobinson 98riv sniperdude pbrktrt Z-type llamalor2112 95rivy Ridin-Rivi flyineagle96 Eldo robotennis61 Abaddon black shadow BMD jonly BrianEsser Karma playa jeffyd123 98inSFl 96riv #1BearsFan lionfish deekster_caddy xxsupergman25xx 6spd Rickw albertj vendetta BillBoost37 96RIVMANN 1wickedninja Chicken 1996RIV CALI Mr.Riviera AA RhinoFLA dreww mcgusto82 43 posters |
6spd Amateur
 | Subject: Re: Radiator / Coolant Leaks Wed May 20, 2009 2:08 pm | |
| 3 drops seems to be a small amount compared to what I have to keep adding in there after a short drive. If it is leaking internally, where would it be going? I have put a new radiator in there already, it is leaking more under the motor | |
 | Subject: Re: Radiator / Coolant Leaks Wed May 20, 2009 2:39 pm | |
| You need to get it pressure tested to know exactly where it's going. If it's ingesting it internally it is most likely the lower intake manifold gaskets. | |
 | Subject: Re: Radiator / Coolant Leaks Wed May 20, 2009 6:26 pm | |
| 3 drops is not much, but if you are seeing any drops, odds are good that under higher pressure is leaking more... you don't reach full pressure until you are driving for a while. That's why you need to have it pressure tested to see where it's going. | |
6spd Amateur
 | Subject: Re: Radiator / Coolant Leaks Thu May 21, 2009 6:24 pm | |
| Thanks for your help. I guess i'll have to find a place to PT it. | |
 | Subject: Re: Radiator / Coolant Leaks Fri May 22, 2009 10:56 am | |
| Any radiator shop should have a pressure tester. | |
#1BearsFan Enthusiast
Name : Bill Location : North Carolina Joined : 2008-07-28 Post Count : 231 Merit : 4
 | Subject: Re: Radiator / Coolant Leaks Fri Sep 11, 2009 9:59 pm | |
| I have had a leak for a while, but it was minmal and I couldn't find it. A couple of weeks ago I took it to the shop, my mechanic pressure tested it, and HE didn't find it. Well, I stopped in to have him change the oil last week and it let out a couple of drops while the oil was draining. My mechanic tells me that my coolant leak (small leak) is coming from the elbow by the alternator. Can anyone tell me how big of a job it is to change that elbow? Parts required? | |
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 8545 Merit : 181
 | Subject: Re: Radiator / Coolant Leaks Fri Sep 11, 2009 10:24 pm | |
| IIRC changing it is not that big a deal - it's *getting* one that is tough.
 | Subject: Re: Radiator / Coolant Leaks Fri Sep 11, 2009 10:39 pm | |
| I found a pair of those plastic elbows with o-rings attached at Advanced Auto Parts in the section of the store that has all those "HELP" products. Cost me less than $5.00 IIRC. I grabbed a set just to have on hand in case I need them in the future. HELP P/N 47065 Heater Hose Fitting GM Application: various GM Models with 3.8L 1995-2007 | |
 | Subject: Re: Radiator / Coolant Leaks Fri Sep 11, 2009 10:43 pm | |
| Yes, the plastic elbows are readily available in the 'help' section, they are very popular! You do have to remove the alternator to get the bracket off that contains the elbow. Be sure he has a good O-ring assortment on hand as well, there's another O-ring that should be replaced on the back of that alternator bracket/coolant manifold thingy while you have it out. | |
 | Subject: Re: Radiator / Coolant Leaks Mon Sep 14, 2009 2:22 pm | |
| Thanks Deekster... Is there a write up for the removal/reassembly here somewhere? | |
 | Subject: Re: Radiator / Coolant Leaks Mon Sep 14, 2009 2:51 pm | |
| I haven't seen a writeup, but it's only held on by a few bolts. Not that hard to figure out once you have the alternator out of the way. | |
 | Subject: Re: Radiator / Coolant Leaks Mon Sep 14, 2009 2:59 pm | |
| - Rickw wrote:
- I found a pair of those plastic elbows with o-rings attached at Advanced Auto Parts in the section of the store that has all those "HELP" products.
Cost me less than $5.00 IIRC. I grabbed a set just to have on hand in case I need them in the future. HELP P/N 47065 Heater Hose Fitting GM Application: various GM Models with 3.8L 1995-2007 I'll add this to my Zone List. Albertj | |
96riv Fanatic
 | Subject: Front cover leak. Wed Feb 17, 2010 5:23 pm | |
| I have a coolant leak between the front cover and the block, any tips on changing it out? I have changed a water pump on the car so I know how to get that far. Thanks | |
 | Subject: Re: Radiator / Coolant Leaks Wed Feb 17, 2010 7:45 pm | |
| One thing you should determine first - is it the plastic coolant elbow that goes from just under the alternator into the lower intake manifold, or is it the timing cover gasket? That will make a big difference in your instructions  | |
96riv Fanatic
 | Subject: Re: Radiator / Coolant Leaks Wed Feb 17, 2010 9:27 pm | |
| When I did a pressure test it sprayed out between the cover and block on the grill side of the block. | |
 | Subject: Re: Radiator / Coolant Leaks Wed Feb 17, 2010 9:36 pm | |
| Okay, so you need to remove the timing cover to fix it. In a nutshell you'll need to pull the alternator, tensioners, coil mount, front motor mount, harmonic balancer and timing cover. I'm not positive if you'd need to remove the A/C bracket, but I don't think so. Use a torque wrench on reassembly. I highly recommend a service manual to follow along step by step instructions. | |
96riv Fanatic
 | Subject: Re: Radiator / Coolant Leaks Wed Feb 17, 2010 9:50 pm | |
| It is sure is a bitch working on the Riv compared to my 87 limited. I thought getting rid of the Dexcool 30,000 miles ago was soon enough. Do not have the service manual so I will just have to figure it out like when the water pump was replaced. That power steering pump was tough. | |
 | Subject: Re: Radiator / Coolant Leaks Wed Feb 17, 2010 9:53 pm | |
| Dennis, For the Phoenix area I recommend a 180* thermostat be installed before you finish up the job. Before you reinstall coolant. That is if you haven't already installed one. Even without reprogramming the PCM for different coolant fan turn on settings you will still see a small benefit in lower coolant temps while cruising. Stuck in traffic you will probably still see the higher or normal temp of 195* to 210*F in the summer without some PCM programming. | |
96riv Fanatic
 | Subject: Re: Radiator / Coolant Leaks Wed Feb 17, 2010 10:09 pm | |
| Have the 180 already. My PCM is the bastard 96 version, not sure if I could make that change. | |
96riv Fanatic
 | Subject: Re: Radiator / Coolant Leaks Sat Feb 20, 2010 5:34 am | |
| Got the bolt out of the crank, how do you get the pulley off? did not want to force off with a screwdriver because of the plastic piece surronding the pulley. | |
98inSFl Enthusiast
Name : Ed Location : WPB Florida Joined : 2010-01-16 Post Count : 249 Merit : 14
 | Subject: Re: Radiator / Coolant Leaks Sat Feb 20, 2010 9:43 am | |
| You will need to borrow the proper puller from the auto parts store.
The proper puller has special bolts using threaded holes inside 3 of the openings in front of the balancer. | |
 | Subject: Re: Radiator / Coolant Leaks Sat Feb 20, 2010 10:14 am | |
| - 96riv wrote:
- Got the bolt out of the crank, how do you get the pulley off? did not want to force off with a screwdriver because of the plastic piece surronding the pulley.
It requires a harmonic balancer puller. Most of them don't come with the right bolts, so you'll need to get your own bolts with the correct metric thread (sorry, I can't remember the size. Memory says it's something around 6x1.25 and long but I'm not positive, it's a rather small bolt size but has to be long to reach the puller) | |
96riv Fanatic
 | Subject: Re: Radiator / Coolant Leaks Sun Feb 21, 2010 9:12 pm | |
| Rented the puller and it worked great except now the cover needs to be replaced because one corner where it was not leaking looks like shit. This job never will end. Now I have to remember how to put it back together. Hopefully I can find a replacement, because all of the local parts places did not have one. I used 1/4x 28x 3.5 grade 8 bolts and they were perfect. I hate this car. | |
98inSFl Enthusiast
 | Subject: Re: Radiator / Coolant Leaks Sun Feb 21, 2010 9:33 pm | |
| Is it corrosion damage? Pitting could be fixed with JB weld and a flat file.
I am pretty sure the cover fits more then rivs . | |
96riv Fanatic
 | Subject: Re: Radiator / Coolant Leaks Sun Feb 21, 2010 10:44 pm | |
| - 98inSFl wrote:
- Is it corrosion damage? Pitting could be fixed with JB weld and a flat file.
I am pretty sure the cover fits more then rivs . This is more than pitting, there is a chunk missing and the Dex Cool did a number on other spots also. I will buy new, do not want to ever work on this again. | |
 | Subject: Re: Radiator / Coolant Leaks  | |
