| Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation | |
+40Johnny5 69GSColorado al_roethlisberger highwaywarrior charlieRobinson RidzRiv Natesriv pbrktrt J. Chris Davis flyineagle96 brutusk1 Jamax 97 park ave ghpcnm Karma LARRY70GS Ash albertj Abaddon robotennis61 TonySmooth89 sdconcepts Mr.Riviera DEMonte1997 EatDirtFartDust turtleman napalmpt Rickw Buapo deekster_caddy Face ewolfe0050 jax95riv Jack the R oldsman105 racinfan 1998 Riv 98riv Jason AA 44 posters |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Wed Aug 12, 2009 1:54 pm | |
| Yes, If you can sketch the dimensions or make a small blueprint sort of, it would be helpful. Then I can make up the spacers ahead of time, buy the greasable bushings and install new sway bar without much down time. Thanks. | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Wed Aug 12, 2009 2:58 pm | |
| Rick, didn't I give you the extra ones I got from Addco? They had the plates in them, didn't they? | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Wed Aug 12, 2009 4:41 pm | |
| No, I'll have to make the plates. No big deal. I've got some 1/8" stock here that I can cut and drill.
OBTW, what's the diameter of the rear STS bar, That will determine what mount bushings you need. I don't know if Energy Suspension has those bushings. I know they don't have the brackets, you have to use the stock ones for that bar. If your getting a used bar it may have the OEM brackets and bushings still attached. Otherwise you can use the stock Riv. brackets and get larger diameter bushings for them. I think that's how others have dealt with the rear STS bars. | |
sdconcepts Rookie
Name : Jerry Age : 46 Location : warren, Mi Joined : 2009-08-18 Post Count : 16 Merit : 0
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Fri Aug 21, 2009 12:17 am | |
| so are the part numbers for the addco bars 2018 and 2015? these supposedly fit the aurora and the caddy sts. my riv is a 96 and these bars are not listed for it. any help would be great.
thanks
Jerry | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Fri Aug 21, 2009 6:16 am | |
| They don't list the bars for the riv, because they may not come with the proper bushings. Two years ago when I got mine they came with the right bushings, but I think they stopped doing that for some reason. | |
TonySmooth89 Aficionado
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Sun Aug 23, 2009 7:26 pm | |
| Do you happen to have the PN for the rear endlinks and bushings? I just ordered an STS rear bar. | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Wed Nov 04, 2009 12:37 am | |
| just a quick question for those who know. i read somwhere that the front bar on the riv is hollow,is this true? i tapped on it and it did not feel hollow...are the later years different? | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Wed Nov 04, 2009 6:29 am | |
| I believe it is a hollow bar. Most stock bars are hollow. | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Wed Nov 04, 2009 9:20 am | |
| My OEM bar was much lighter than the Addco - it had to be hollow, imo. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
DEMonte1997 Aficionado
Name : Rick Age : 46 Location : CT Joined : 2009-03-03 Post Count : 1429 Merit : 37
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Wed Nov 04, 2009 10:14 am | |
| If they are like the w-bodies then they are hollow. I snapped the Regal's a couple years ago just going over uneven pavement. What a joke. lol | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Wed Nov 04, 2009 4:34 pm | |
| ahh ok. i installed the rear bar mon and it makes a tremendous difference.
i have the rear bar installed and it works great. i was disapointed to find that the oem bar is hollow! i could not believe it. a small diameter bar and hollow? cheap s..t!. but the question i have for some of you who have the front and rear bars installed together,does the car steer neutral? or dos the car under or oversteer? the reason i ask is because the addco rear bar being a smaller diameter than the addco front bar,would not this cause understeer? reason being,on a front drive car it is preferable to stiffen up the rear.and with the addco front bar being bigger, in my mind this would lead to understeer. anyone with the two installed feel this way?
Last edited by robotennis61 on Sat Mar 30, 2013 1:02 pm; edited 1 time in total | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Sat Nov 07, 2009 8:26 pm | |
| i have the sts front bar installed right now and the car has pretty bad under-steer in a hard corner. i plan on getting the rear bar when i have $150 to spend on it. If i enter a corner really hard, the front 2 tires will be screaming and the back end just drags around slowing me down. its fine in normal driving and i noticed an improvement in the body roll and overall composure of the car. I dont see any reason not to do the front one too. if you are really worried about the front being stiffer than the rear you could go with the caddy sts bar which is slightly smaller than the addco. _________________ 1996 with 254k miles, L32Â 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Sat Nov 07, 2009 8:45 pm | |
| good advise MR.Riv. i would hate to upset the balance as it is with the rear addco installed. it oversteers ever so little with this set up. a addco front bar would have the opposite effect and just understeer flatter with bigger bars. whew! | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Sat Nov 07, 2009 11:46 pm | |
| I have front and rear addco bars. Understeer? Oversteer? I don't know but it holds a corner nicely and I think it's pretty even. It will eventually plow the front tires if I'm trying to turn hard enough (and it's pretty hard cornering at that point), but it never gets squirelly. | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Sun Nov 08, 2009 12:17 am | |
| interesting deek. I'm going to find out if i can find an adjustable bar. they make em for older muscle cars and if they cost the same and maybe a few $ more ill get it. ill keep any interested posted. | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Sun Nov 08, 2009 6:29 am | |
| - robotennis61 wrote:
- interesting deek. I'm going to find out if i can find an adjustable bar. they make em for older muscle cars and if they cost the same and maybe a few $ more ill get it. ill keep any interested posted.
An adjustable sway bar? I don't think you'll find anything like that for this car. The sway bar is a very odd shape and there's really not much room for options... | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Sun Nov 08, 2009 2:18 pm | |
| i see that now. ill look into custom. might not be that much over aftermarket | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Sun Nov 08, 2009 7:53 pm | |
| Does the addco bar not meet your needs? It's solid, thick and pretty darn good IMO. What are you looking to do that would require a custom bar? | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Sun Nov 08, 2009 9:02 pm | |
| i want a car that has a higher degree of oversteer. not much higher just more. i don't like neutral steering cars. the rear bar can be fabricated fairly easily. a 1 1/4" rear would be perfect. with a 1" or 7/8" for the front. imo this would be the perfect balance. oversteer is controllable. understeer is frustrating. im looking into it. | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Sun Nov 08, 2009 11:32 pm | |
- i want a car that has a higher degree of oversteer. not much higher just more. i don't like neutral steering cars. the rear bar can be fabricated fairly easily. a 1 1/4" rear would be perfect. with a 1" or 7/8" for the front. imo this would be the perfect balance. oversteer is controllable. understeer is frustrating. im looking into it.
That sounds like it would be a quite radical change from stock. Why don't you just get an addco for the back with the stiffest stuff to hold available then go to like an FE2 bar up front with better shocks? That's really what I want to do but I don't yet have the means. Sounds like you could do it | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Sun Nov 08, 2009 11:55 pm | |
| i have the rear addco installed already and i like it. I'm looking into fabricating solid steel brackets instead of the rubber or poly available ,this would give the rear more stiffness. for the front whats a " FE2" as for the front the kybs are way soft. ill be looking into a bilstein cartridge set up real soon. | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Mon Nov 09, 2009 12:03 am | |
- i have the rear addco installed already and i like it. I'm looking into fabricating solid steel brackets instead of the rubber or poly available ,this would give the rear more stiffness. for the front whats a " FE2" as for the front the kybs are way soft. ill be looking into a bilstein cartridge set up real soon.
FE2 is 30mm on the front, stiffer than stock but not as much as Addcos. It aught to flatten the front a bit but not create much understeer - compromise I have a FE2 bar in the rear which is a 22mm bar and I noticed the difference - not what I'd call night and day but I'm happy with the change - I'd love to step the rear up to the Addco though. | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Mon Nov 09, 2009 12:20 am | |
| where can i find an FE2? the addco rear is a 7/8 bar. thats 22mm. 30mm would be bigger. that might lead to the same scenario.. | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Mon Nov 09, 2009 6:42 am | |
| Sorry, are you talking about making a stiffer REAR bar? | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Mon Nov 09, 2009 12:58 pm | |
| that might be a better idea deek. it would be easier to match the front addco with a bigger rear bar. if the front addco is bigger,and the rear addco is smaller,this would lead to understeer. but if i can fab a rear bar from 1 1/4 1/4 wall tubing i would have,on paper at least, a nice handling car with just a nice acceptable amount of oversteer the way i like it. sticky tires and bilsteins for the front. and im done. besides replacing the rubber bushings for nylon...that would bring the riv into sport car handling territory without a doubt. the rear bar with it's simple 2 bends is dead easy to fabricate. the front bar ..i dont even want to think about it. i just found out the front bar is 1 1/4". the rear would have to be bigger. i dont know if a 1 1/2" or a 1 3/4" would fit in the rear? gotta check... | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation | |
