| Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation | |
+40Johnny5 69GSColorado al_roethlisberger highwaywarrior charlieRobinson RidzRiv Natesriv pbrktrt J. Chris Davis flyineagle96 brutusk1 Jamax 97 park ave ghpcnm Karma LARRY70GS Ash albertj Abaddon robotennis61 TonySmooth89 sdconcepts Mr.Riviera DEMonte1997 EatDirtFartDust turtleman napalmpt Rickw Buapo deekster_caddy Face ewolfe0050 jax95riv Jack the R oldsman105 racinfan 1998 Riv 98riv Jason AA 44 posters |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Thu Oct 13, 2011 2:59 pm | |
J. Chris Davis Aficionado
Name : Chris Davis Age : 43 Location : Dixon, IL Joined : 2010-04-14 Post Count : 1008 Merit : 19
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Thu Oct 13, 2011 3:07 pm | |
| Not sure I want to hassel with selling them on there and shipping them, but I might. | |
Jason Aficionado
Name : Jason Age : 41 Location : Comox, BC, Canada Joined : 2007-01-23 Post Count : 1378 Merit : 66
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Thu Oct 13, 2011 6:56 pm | |
| They are worth nothing. Toss them. I couldn't give my set away. | |
pbrktrt Enthusiast
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Thu Oct 13, 2011 7:18 pm | |
| Set them out by the road. The scrappers will fight over them. | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Thu Oct 13, 2011 7:52 pm | |
| I turned my rear bar into a serpentine belt remover.took an old 15mm cut the end off,cut the bends off the bar,stuck the wrench into one end.voila.free tool.
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Thu Oct 13, 2011 8:18 pm | |
| That's not to bad of an idea there Robo. | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Thu Oct 13, 2011 8:23 pm | |
| yap.the secret is to flatten the tube where the wrench fits.otherwise the round of the tube will interfere with belt removal.if ya got a torch,you can put a bend in her. | |
Name : Larry Age : 68 Location : Oakland Gardens, NY Joined : 2007-01-23 Post Count : 2193 Merit : 150
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Sat Dec 10, 2011 12:57 pm | |
- Good luck on your install, Larry. Doing this repair + the F/R mounts was one of the things that make me want to drive this car forever. It really makes the car feel new again. Doing the sway bar mod F/R was one of the best things I've done to the suspension for this car. Because of the increased forces exerted on the stiffer bars, you'll want to use energy suspension insulators, at least on the fronts. Also, the front links should be upgraded for the extra load (I've popped an OEM link with these bars). Write-up:
https://rivperformance.editboard.com/t7376p30-write-up-stabillizer-anti-sway-bar-link-upgrade Thanks Aaron. When you say front insulators, are you referring to the bar bushings that bolt to the cradle? I did intend to do that also. I'll have to look through the sway bar write up for the part numbers. Do you know if Addco supplies that flat metal strip that goes between the sway bar bushing and the cradle? Is that also necessary for the Energy Suspension bushings? _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: temp Sat Dec 10, 2011 1:39 pm | |
| - Quote :
- They have polyurethane instead of rubber. When you say front insulators, are you referring to the bar bushings that bolt to the cradle? I did intend to do that also.
Yes, GM calls them insulators, but they do work more like bushings in the form produced by ES. The supplied bushings from Addco are acceptable, but noisy if not greased every now and then. ES makes them with a greasable fitting, which I grease about once per year. Never heard a noise from them, and they are much stiffer than OEM. - Quote :
- Do you know if Addco supplies that flat metal strip that goes between the sway bar bushing and the cradle? Is that also necessary for the Energy Suspension bushings?
Yes, Addco supplies the strips, but ES supplies them as well as part of the bushings kit. Use the ES kit parts - it's worth the $20 or so, imo. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Thu Dec 22, 2011 2:58 am | |
| I'm trying to get my stock bar out and I just can't get it clear enough on either side to get it out. I have the engine and downpipe out, the tire rod ends disconnected from the spindles, rear trans mount completely out and the steering rack loose. What am I missing here? Eek, I'll try again tomorrow | |
Jason Aficionado
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Thu Dec 22, 2011 1:12 pm | |
| With the "wheel" turned all the way, the bar should wiggle out. | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Thu Dec 22, 2011 2:50 pm | |
| Got it. My problem was I wasn't directing the left side of the bar in front of the driver strut, I kept going behind. And yeah, the new one went in easy aside from me discovering I need to work out. That thing is damn heavy when you're trying to shove it through the car without scratching it. | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Thu Dec 22, 2011 2:51 pm | |
| Oh so did you guys using greasable bushings like finger in grease or did you just tighten it down dry and pump it or what. And I remember you said the red mobil1 synthetic grease is best right? | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Thu Dec 22, 2011 3:17 pm | |
| I pumped mine in after installation, but lubing it first couldn't hurt. It'll be a little more messy. I think I used a Marine grade grease, nothing too special.
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Fri Dec 23, 2011 12:06 pm | |
| Got my Addco sway bars from Never Enough, via EBay yesterday. They shorted me one end link bushing (7 instead of 8), and the rear bar did not come with the GM orange insulators (25666235). I believe the group buy guys got the insulators, but I guess Addco no longer includes them. I'm going to be doing the Cradle mounts and sway bars at the same time.
The front bar looks as if it lays nice and flat, so I'm relieved that I won't have the problem that Codith had. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| I bought mine about 6 months ago from summit racing and they came with all the right stuff. | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Fri Dec 23, 2011 2:11 pm | |
| - J. Chris Davis wrote:
- I bought mine about 6 months ago from summit racing and they came with all the right stuff.
My rear bar came in a box by itself with no hardware. I called Never Enough, and they checked with Addco. Addco will send me the 1 front endlink bushing I am missing, but they said the rear bar does not come with anything. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Fri Dec 23, 2011 2:49 pm | |
| Oh, you know. I"m sorry I was wrong. The rear bar I had to get energy suspension end links and I thought it came with the bushings. You have to reuse the original hold downs to the body though. | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Fri Dec 23, 2011 2:57 pm | |
| The end link part number I used for the rear end links was 9.8123G. Got them from autozone. | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Fri Dec 23, 2011 4:51 pm | |
- Oh, you know. I"m sorry I was wrong. The rear bar I had to get energy suspension end links and I thought it came with the bushings. You have to reuse the original hold downs to the body though.
OK, I know you have to re use the rear bar brackets, but the stock insulators need to be replaced, correct? I see the GM "orange" insulators( GM part # 25666235) mentioned in this thread. I was going to use those. The end links, front and rear, I am getting from Aaron. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Fri Dec 23, 2011 4:53 pm | |
| Yes you need new insulators. The one I got from Summit Racing did come with those. | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Fri Dec 23, 2011 5:38 pm | |
- Yes you need new insulators. The one I got from Summit Racing did come with those.
Looking back on page 19 of this thread, Jason also got them with his rear bar. The GM 25666235 insulators. That was 9 months ago. Maybe I'll try to call Addco. Jody at Never Enough said the rear bar doesn't come with them from Addco. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Sat Dec 24, 2011 6:32 pm | |
| I think a couple of years ago they didn't include them. Maybe they had old stock? | |
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Sun Dec 25, 2011 10:33 am | |
- I think a couple of years ago they didn't include them. Maybe they had old stock?
I don't know, but I have messaged Never Enough again through E-Bay. I linked the Summit Racing catalog page showing the rear bar with the insulators, and asked, why Summit includes them, but Never Enough does not? NE has them dropped shipped to the customer, not sure about Summit. http://www.summitracing.com/parts/ACO-2015/ Seems to me that they should include everything just like the front bar, but I think the insulators are a bare minimum. It's not like you can just use anything, and the GM bushings are expensive for what they are. I also tried to message Addco through their website, but that is a waste of time. Every time I try, I get a message that an error has occurred and that I haven't fully filled out the form. I'm not really impressed by Addco as a company. If there was any other manufacturer to get the parts from, I would order it from them. The bars I received seem to be perfect, but reading through this thread, it seems it took Derek and Codith 3 times to get a good front bar. Derek got the wrong bar the first time, a bar that was bent wrong the second time, and the third time was the charm. Codith got a bar that was bent wrong, then Addco tried to straighten it, then finally sent him another. Not exactly confidence inspiring. Seems like they do the right thing, then they don't, and they have other problems in between. My front bar seems to lay flat on the ground, so I'm sure I won't have a problem with it, other than the normal install pain. http://addco.net/ _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation Sun Dec 25, 2011 3:24 pm | |
| Looking on Addco's website, I noticed a link to e mail their marketing director at nathan@addco.net. I noticed that we were dealing with John on the bushing issue. I figured I would try John@addco.net and see if that works. Worth a shot. If I don't hear anything, I'll try Nathan. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: Write-Up: Front/Rear (Addco) Stabilizer/Sway Bar Installation | |
