 O2 sensor replacement and MPG gains
5 posters
Mikel
O2 sensor replacement and MPG gains Empty
PostSubject: O2 sensor replacement and MPG gains   O2 sensor replacement and MPG gains EmptyThu Jul 12, 2012 8:40 pm
Hello,
My '97 Riviera has 125K miles and as far as I know, both O2 sensors are original. I get about 21-22MPG with my heavy foot and was wondering if replacing the O2 sensors would give me any noticeable MPG changes. They appear to be about $60 a piece...
Thank you.
Mikel
PostSubject: Re: O2 sensor replacement and MPG gains   O2 sensor replacement and MPG gains EmptyThu Jul 12, 2012 10:01 pm
Hard to tell... 22 MPG sounds like heavy foot and winter gas.
PostSubject: Re: O2 sensor replacement and MPG gains   O2 sensor replacement and MPG gains EmptyFri Jul 13, 2012 1:33 pm
O2 sensors are the #1 oversold part in the industry. If the O2 sensor is working, it works. If it does not work, the computer will tell you so. In addition, sometimes the computer throws an O2 sensor code for a different problem (vacuum leak, leaky injector, etc). Usually the problem is NOT the O2 sensor to begin with.
Replacing the O2 sensor is not a preventative maintenance task. The OEM sensor is capable of lasting a very long time.
Merit : 149
PostSubject: Re: O2 sensor replacement and MPG gains   O2 sensor replacement and MPG gains EmptyFri Jul 13, 2012 2:32 pm
Derek,
I agree, but don't old sensors become somewhat "Lazy" in response time. There is also the heater element that can throw a code when they don't get up to temperature fast enough for the ECM.
PostSubject: Re: O2 sensor replacement and MPG gains   O2 sensor replacement and MPG gains EmptyFri Jul 13, 2012 3:52 pm
LARRY70GS wrote:
Derek,
Your right and that's the correct word LAZY!!!
PostSubject: Re: O2 sensor replacement and MPG gains   O2 sensor replacement and MPG gains EmptyFri Jul 13, 2012 5:02 pm
When they do become too "lazy" the PCM will report a code related to crosscounts too low. Until then it's still good enough.
» O2 sensor replacement
» Crankshaft sensor replacement
» 95 Radiator replacement missing "Coolant Sensor"?
» FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)
» FAQ: Mass Air Flow (MAF) Sensor Issues?
