highwaywarrior Fanatic
 | Subject: Changing Air Filter (Intake) Sat Feb 02, 2013 10:32 am | |
| How the hell do I get the tube off( th one that goes from throttle body to air filter ugh
I mean the stock onr | |
 | Subject: temp Sat Feb 02, 2013 11:44 am | |
| There should be a screw clamp on both ends of the tube. Just loosen the clamps! | |
Name : Aaron Age : 46 Location : C-bus, Ohio Joined : 2007-01-13 Post Count : 18440 Merit : 248
 | Subject: Re: Changing Air Filter (Intake) Sat Feb 02, 2013 12:15 pm | |
| Once clamp is loose, pull hard on the tube and twist back and forth. It can get stuck on there, but it will come off. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: Changing Air Filter (Intake)  | |
