| Write-Up: AC Compressor & Clutch Replacement | |
+31LARRY70GS The Roadmaster 98riv urbanski_m rivordie KnottyEagle gunmetalRED duster_do_little nebstewart07 joshuadalegrimes al_roethlisberger Uplink Hometown Hero Rod.G dboydakid IBx1 robotennis61 Mr.Riviera BMD Sweepspear VJD2 Abaddon moldymac albertj AA deekster_caddy Eldo L67 DEMonte1997 Rickw GMFreak8 35 posters |
DJROBJ Amateur
Name : Rob J Joined : 2022-11-23 Post Count : 24 Merit : 1
| Subject: Re: Write-Up: AC Compressor & Clutch Replacement Tue Nov 29, 2022 9:48 am | |
| [quote="Jack the R"] - LARRY70GS wrote:
- I replaced my A/C compressor about 6 months ago because the clutch was making a ringing noise, and the pressures were low. It also leaked out over a 6 month period. Replacing the compressor seems to have fixed all 3 problems. A/C blows very cold and the compressor is quiet. I used the Denso,
I'm strongly considering picking this Denso up and having the UAC replaced. I'm afraid the UAC's bearings aren't getting oiled and it's going to seize, shred the belt and leave me stranded. As well as fill the rest of the system with metal, which it could already be doing for all I know.
edit - The UAC is supposed to be pre-filled with oil though - perhaps it wasn't from the factory? Any update on this? I'm about to change out the compressor, drier, orifice on my car soon. I ordered the Delphi compressor off of Rock Auto, along with the GM variable orifice for climates less then 105. I'm in Miami, FL, so I'm certainly looking forward in having cold AC. | |
Name : Larry Age : 67 Location : Oakland Gardens, NY Joined : 2007-01-23 Post Count : 2187 Merit : 149
| Subject: Re: Write-Up: AC Compressor & Clutch Replacement Tue Nov 29, 2022 3:06 pm | |
| The first paragraph in your quote is me. The rest of it, not sure where that came from.
The Denso compressor blew cold air for me right through the summer. It still cycles on and off with my climate control in "Auto". I guess the test will be next summer. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: Write-Up: AC Compressor & Clutch Replacement Tue Nov 29, 2022 3:15 pm | |
| - LARRY70GS wrote:
- The first paragraph in your quote is me. The rest of it, not sure where that came from.
The Denso compressor blew cold air for me right through the summer. It still cycles on and off with my climate control in "Auto". I guess the test will be next summer. The 2nd part is mine. Looks like the "close quote" tag got deleted after your part. | |
DeepFrozen Fanatic
Name : Dmitry Joined : 2016-08-28 Post Count : 252 Merit : 11
| Subject: Re: Write-Up: AC Compressor & Clutch Replacement Wed Sep 13, 2023 3:01 am | |
| Quick question. I know that our A/C should be filled with PAG 150, all spec sheets say so. But my Denso A/C compressor came prefilled with PAG 46. So what PAG oil should I use in the system?
| Subject: Re: Write-Up: AC Compressor & Clutch Replacement Wed Sep 13, 2023 12:47 pm | |
| I wouldn't replace the oil. Wouldn't that void the warranty? | |
DeepFrozen Fanatic
| Subject: Re: Write-Up: AC Compressor & Clutch Replacement Thu Sep 14, 2023 6:14 am | |
| I'm long past the warranty ) Now I want to do what's best for the system.
And I have to replace the oil one way or another. Leaving PAG 150 in the system means I have to replace the oil in the compressor. And vice versa. | |
| Subject: Re: Write-Up: AC Compressor & Clutch Replacement Thu Sep 14, 2023 8:31 am | |
| I meant the warranty on your compressor. | |
DeepFrozen Fanatic
| Subject: Re: Write-Up: AC Compressor & Clutch Replacement Sat Sep 16, 2023 10:22 am | |
| I know. I got the compressor 3 years ago, filled the system with PAG 150 and it worked Ok. Recently I started to think than compressor became noisier. Or maybe I was just paranoic ) Anyway, in August I disassembled the system to fix the failed hose. And while I was on it, I decided to flush the system, replace dryer and orifice tube. And I found old manual/leaflet from the box the AC compressor came in, it says the compressor was prefilled with PAG 46. So the original question came up. What PAG oil should I use?
| Subject: Re: Write-Up: AC Compressor & Clutch Replacement Fri Sep 22, 2023 3:21 am | |
| My compressor is also getting noisy "in my head"... LOL However, since the original system is R-134, which so far is still readily available, I don't see any problem in trying to make your system run on 134 AND the original Oil.... | |
| Subject: Re: Write-Up: AC Compressor & Clutch Replacement | |
