| FAQ: Steering Column Slop, Problems & Replacement | |
+639ty7rivi EyeDoc1 Yardley kylan_13 sloppyriv brutusk1 Z-type 71stagegs edward harmon matt270avian premature jack jbird ratnfested billfrank85 JOE RIV 1 GreenJeanS stan laddieboy1 al_roethlisberger saintsnsinners 2000ws6transam Karma nvsteve Spin Derek GreenMonster 97SC_CALI_RIV turtleman jenkkijussi moldymac Mr.Riviera Abaddon Eldo Mikel ibmoses robotennis61 Rickw deekster_caddy albertj sburch23 99Rivman BMD duster_do_little SuperRiv07 skuchin LARRY70GS Steve98 ewolfe0050 Jack the R SC95Riv rivcop heyzelchi AA racinfan ¤DoughBoy¤ SpaceBar zebster okiedrifter 96 pearl rivi on 22's jax95riv 1998 Riv NO 4 EVR HirohataMerc 67 posters |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Sun Jun 24, 2007 6:53 pm | |
| Thanks for the pic! Do you have any more info on this? I'm thinking of pulling my column apart soon. Mine's getting bad... _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
jax95riv Aficionado
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Sun Jun 24, 2007 8:12 pm | |
| It would be great to have a write up for this issue. How long did it take you Tyler? | |
okiedrifter Member
Name : Tyler Age : 37 Location : Tulsa, Oklahoma Joined : 2007-04-04 Post Count : 68 Merit : 2
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Mon Jun 25, 2007 4:25 pm | |
| well about two-3 hours. and most columns are basically the same, so if you look anywhere there is a step by step coloumn teardown the basics will be there. unfourtunatly, i took no more pics, as i have recently broke my collarbone and was not to happy about laying on my back in the floorboard to pull the coloumn (wich most of you won't have to do but i had a special case where i didn't need to tear down the coloumn again, just pull it out.). i took that pic because i knew at least it would help you guys understand what you are up against. by the way, if you go to a buick dealer they can print out an exploded view of the coloumn, which also puts things into perspective. if you have any questions i can answer them though. hope i can be more help, tyler | |
okiedrifter Member
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Mon Jun 25, 2007 4:32 pm | |
| by the way, if your coloum is only slightly loose, either the piece is not totally broke, or, if you look right behind and below the screw driver, there is a round black lookin thing. this is one of two pins that hold the tilting part of the coloumn to the stationary bracket. these pins will come loose, and if you catch them in time, they can simply be ran back in with a screw driver and hammer. good luck | |
heyzelchi Amateur
| Subject: steering column help Mon Nov 19, 2007 1:36 pm | |
| I have an 95 buick riviera sc I notice that I when I drive my steering wheel has alot of play in it it almost to the point that it is undriveable I was thinkin that I need a new steering column, the steering wheel is of the tilt and wobbling from left to right anyone have any advice
thanks | |
rivcop Amateur
Name : Kevin Age : 45 Location : Cincinnati, Ohio Joined : 2007-10-27 Post Count : 22 Merit : 0
| Subject: steering column help Tue Nov 20, 2007 3:20 am | |
| Very common on older GM cars. There is a "Knuckle joint" between your steering wheel and the column itself. It is because of your tilt steering that this "Knuckle joint" has came loose. It is an easy fix. Locate your tilt lever and go from there. I'm not sure on how hard to torque it, but some of the guys on here can probably tell ya. Dont torque it down to hard cause it still needs to function in an up and down manner. Hope this helps. | |
jax95riv Aficionado
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Tue Nov 20, 2007 5:38 pm | |
| It's a PITA to fix but it is fixable. I need to repair mine too. | |
heyzelchi Amateur
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Wed Nov 21, 2007 2:46 pm | |
| - zebster wrote:
- Hi again, well my husband took it apart to see what was the problem with the steering wheel and yes there was a pin missing and the housing thing where the pin goes in was broke. From all the reading about this, the best and cheapest way to go was to find a steering column from a salvage yard. Finally found one for $100 + $40 shipping. My car is a 97 and the column I bought was a 95. He got it in and hooked everything up. Everything worked (interior lights, antenna, everything electrical, batttery), but the car would not start. Any info on this?
A zebster could you give me the phone # of the salvage yardyou brought your steering column from if you could find it I"m not having no luck in finding one | |
heyzelchi Amateur
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Wed Nov 21, 2007 2:48 pm | |
| anyone have any links to online salvage yards I"m in need of an steering column | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Wed Nov 21, 2007 2:51 pm | |
SC95Riv Enthusiast
Name : Chris Location : New York Joined : 2007-10-20 Post Count : 134 Merit : 0
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Thu Nov 22, 2007 2:58 am | |
| Add me to the list of playful steering wheels Mine wobbles up and down, kind alike the wheel is loose, but yet, 1 it hasnt fallen off in my lap, and 2 it still drives fine. From the sound of things, this repair is a real PITA....so it'll either stay the way it is until it falls off in my lap, or I'll have to suck it up and break out the wallet for someone to do it. | |
heyzelchi Amateur
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Mon Dec 03, 2007 10:06 am | |
| Ok I just brought an steering column I today I took it to my mechanic and he told me that he could not put the column on with the old steering wheel, I would like to know if there's any truth to that or do I need to buy and whole new steering column with the wheel | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Thu Dec 06, 2007 8:25 pm | |
| Could it have something to do with airbags? You could always get an aftermarket wheel without the airbag. Just don't ever hit your head against it | |
ewolfe0050 Aficionado
| Subject: Steering Column Problems & Replacement Sat Mar 15, 2008 2:58 pm | |
| Anyone have a expanded diagram of the sterring wheel column? The shop said today that the intermediary bushing is shot and I would like to see if this is something I can tackle myself. | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Sat Mar 15, 2008 3:15 pm | |
| I've seen it posted here previously, not sure of the thread though. I don't know if a 97 is identical or not, but I could take a pic of my service manual page and post it later or email it to you. The steering column can be a real PITA to work on. I'm not familiar with the item he's referring to, but if their price isn't too high, I'd let them do it, IF it is really needed. ???? | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Sat Mar 15, 2008 4:09 pm | |
| 1998 Riv,
If you could email me a picture, I would appreciate it. I found a general diagram but I'd like Riv specific. I looked back into the old threads and found mention of removing slop due to the pivot joint but nothing on the intermediate shaft.
The mechanic told me she thought Buick issued a bulletin at one point. And after surfing the web, it sounds like it is a problem for heavier cars and trucks and it's not that uncommon. | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Sat Mar 15, 2008 5:54 pm | |
| I'll try to get it done tonight, right now we're working on getting my wife out the door for a Hungary trip. PM your email address in the meantime. | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Sat Mar 15, 2008 10:54 pm | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Sun Mar 16, 2008 11:24 pm | |
| Dave,
Thanks for the diagrams! I can't find an autopart store that carries the bearing or the intermediat shaft so I will have to check with Buick tomorrow. | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Sun Mar 16, 2008 11:29 pm | |
| You're welcome, happy to help. | |
jax95riv Aficionado
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Mon Mar 17, 2008 7:36 am | |
| Dave, can the diagrams be posted? Many of us need to tackle this job. That information would be very useful! | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Mon Mar 17, 2008 8:44 am | |
| Agree^^^ Post them up! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Mon Mar 17, 2008 9:46 am | |
| I'll try to get them on photobucket today and post them here. Pretty busy at work right now, and the diagrams are currently on my laptop at home, though I can do them here too. | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement | |
