| | FAQ: Steering Column Slop, Problems & Replacement | |
+639ty7rivi EyeDoc1 Yardley kylan_13 sloppyriv brutusk1 Z-type 71stagegs edward harmon matt270avian premature jack jbird ratnfested billfrank85 JOE RIV 1 GreenJeanS stan laddieboy1 al_roethlisberger saintsnsinners 2000ws6transam Karma nvsteve Spin Derek GreenMonster 97SC_CALI_RIV turtleman jenkkijussi moldymac Mr.Riviera Abaddon Eldo Mikel ibmoses robotennis61 Rickw deekster_caddy albertj sburch23 99Rivman BMD duster_do_little SuperRiv07 skuchin LARRY70GS Steve98 ewolfe0050 Jack the R SC95Riv rivcop heyzelchi AA racinfan ¤DoughBoy¤ SpaceBar zebster okiedrifter 96 pearl rivi on 22's jax95riv 1998 Riv NO 4 EVR HirohataMerc 67 posters | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Wed Apr 14, 2021 9:01 am | |
| From the same site,
https://www.steeringcolumnservices.com/steering-column-repair-how-to-instructions/gm-buick-cadillac-chevrolet-oldsmobile-pontiac/pivot-pin-removal.pdf
Honestly, I think my solution might be a lot easier. It's a crappy design. I never use the tilt at all. I think it would just wear again even with oversize pins. I'd be afraid of cracking the piece that the pins press into. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| | | denim Junkie
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Wed Apr 14, 2021 9:06 am | |
| Yes, agreed. Depends on what I find when I get into it. I have the tilt set where I want it and that won't change I see now there is a retracting tool available if I choose to spend the money and replace with new or oversized pins. Thanks, Larry. | |
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Wed Apr 14, 2021 9:25 am | |
| Yeah, I just pushed my pin back in. I only did the right side as that was the one that had popped out. The other side is covered by the multi function switch. At the time, I just didn't feel like doing the extra work as the column tightened up enough where I never even notice it.
If you just want to push the pin in, that R/S pin is reachable from underneath if you remove that panel underneath, the one that mounts the OBD connection and lamp for the foot well. I was able to wiggle the steering wheel and shove the pin back in. You do have to disassemble everything to use my solution though. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| | | EyeDoc1 Enthusiast
Name : Christen Location : Vancouver, WA Joined : 2016-03-30 Post Count : 125 Merit : 5
| Subject: How do U take the steering column apart to replace that lower support. Fri Jun 25, 2021 10:52 pm | |
| My son broke the "Lower Support (#8 on page 2 of this long thread). The P/N is 26039534. Supposedly this fits both Rivieria's and Aurora's, 1995-99. What I don't see is any write up on how to replace this part. As in, Step 1, disconnect battery, Step 2-9 is removing lower knee bolster and instrument panel trim...that long 6' piece of plastic and then removing 6-7 E-torx screws to get the plastic column housing parts that cover the ignition key lock. OK...plastic parts removed...what's next. Silver pot metal lower support (AKA Support Arm Strg Col Jacket) is clearly broken, both pins are popped out...what do I do next??? Pull steering wheel with airbag off? What? Anyone know a start to finish write up? Read from pages 1-13 and need a little help. | |
| | | EyeDoc1 Enthusiast
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Thu Jul 29, 2021 8:38 pm | |
| OK...I've successfully replaced the whole steering column under the dash. A true PITA to be sure but it had to be done since the knucklehead that towed the car to my place decided to try and pivot the wheels WHILE THE CAR WAS ON THE GROUND and wouldn't start. Broke the housing where the pivot pins sit. Anyway, it's all back together now but I can't figure out how to tilt the steering wheel DOWN to reinstall the dash trim, and as forums have spoken, you've got to "lower the tilt wheel to the bottom" in order to get the plastic trim pieces to fit. I can't lower the steering wheel downward, and don't know if this is electrically controlled to disengage a lock. Since the car won't start, I haven't found a way to lower the steering column manually. The bracket with the black lever doesn't release any lock that I'm aware of. Any ideas if this can be done without the car running or something. I did hook up the battery, but nothing engaged or disengaged. Any ideas? if someone has a Riv, can you pop on outside, put the key in, NOT START THE CAR and see if you can raise or lower your steering wheel. That might help. | |
| | | EyeDoc1 Enthusiast
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement Thu Jul 29, 2021 9:07 pm | |
| D'oh! Disregard. PULL the tab toward you and the wheel tilts. Got it working! | |
| | | Sponsored content
| Subject: Re: FAQ: Steering Column Slop, Problems & Replacement | |
Similar topics | |
