 FAQ: Big Wheels Question.............Will they fit?!
abchuuch
jbird
Riviboi95
norsky86
Rosario
sqrivi
YO MUDA
brians74x
VJD2
Tank
ghost88
97rivsc
millerje18
98RIV7777
BoattailBob
captshiner
texasfan010
'96reese
jrocha
mcgusto82
Ridin-Rivi
2toneRivi
Pearl Riv
96riv
Darko
¤DoughBoy¤
pwmin
71 posters
¤DoughBoy¤
¤DoughBoy¤
FAQ: Big Wheels Question.............Will they fit?! - Page 4 Empty
PostSubject: Re: FAQ: Big Wheels Question.............Will they fit?!   FAQ: Big Wheels Question.............Will they fit?! - Page 4 EmptyThu Jun 21, 2007 12:09 am
I have a question man...........when u got your 22's put on did u have to get your ride lifted?
or u just got some cutting done...............
¤DoughBoy¤
¤DoughBoy¤
PostSubject: Big Wheels Question.............HELP!   FAQ: Big Wheels Question.............Will they fit?! - Page 4 EmptySun Jun 24, 2007 6:05 pm
Would these rims fit on the Rivi?
http://biggwheels.com/POPUPS/ABYSSPOP.htm
The Reason why I ask is because I'm going to get them from my friend for $900..........thats if they fit, but I thought I'll ask on here first.............And the car there comming off of is a 2004 Dodge Intrepid.............
Merit : 66
PostSubject: Re: FAQ: Big Wheels Question.............Will they fit?!   FAQ: Big Wheels Question.............Will they fit?! - Page 4 EmptySun Jun 24, 2007 6:15 pm
that link supplies no information re: fitment. I would try them on because intrepids used a 5x114 bolt pattern, whereas the riv uses 5x115.
FWIW, I have used steel wheels from a dodge (5x114) on a GM (5x115).
¤DoughBoy¤
¤DoughBoy¤
PostSubject: Re: FAQ: Big Wheels Question.............Will they fit?!   FAQ: Big Wheels Question.............Will they fit?! - Page 4 EmptySun Jun 24, 2007 10:36 pm
5 x 114........So they would go right on with no problem?
Thanks for the reply............
PostSubject: Re: FAQ: Big Wheels Question.............Will they fit?!   FAQ: Big Wheels Question.............Will they fit?! - Page 4 EmptySun Jun 24, 2007 11:27 pm
Whoa! Hold up, it depends on the offset. The riv has a 30 offset, not sure if it's + or - though. Camaros are 5X114 and I know they won't fit. Be careful, I had some rims bolt up just fine but when I jumped on the highway I thought the car was going to shake apart. I had to replace 18 of my 20 wheel studs and I only drove about a mile up the road.
¤DoughBoy¤
¤DoughBoy¤
PostSubject: Re: FAQ: Big Wheels Question.............Will they fit?!   FAQ: Big Wheels Question.............Will they fit?! - Page 4 EmptyMon Jun 25, 2007 2:09 am
Damn that sucks..........I'm going to find out the offset and all that from the dude probably tommorow.........Thanks for your reply.........
Ridin-Rivi
Ridin-Rivi
PostSubject: Re: FAQ: Big Wheels Question.............Will they fit?!   FAQ: Big Wheels Question.............Will they fit?! - Page 4 EmptyMon Jun 25, 2007 10:57 am
Rims that are 5x114.3 will fit bolt pattern 5x115. You only have to worry about offset..
Merit : 66
PostSubject: Re: FAQ: Big Wheels Question.............Will they fit?!   FAQ: Big Wheels Question.............Will they fit?! - Page 4 EmptyMon Jun 25, 2007 1:24 pm
I didn't say the wheel will fit with no problem. I said there is practically no information about the wheels and that you should try them before purchasing them. Check out the wheel calculator in the suspension subsection
Merit : 66
PostSubject: Re: FAQ: Big Wheels Question.............Will they fit?!   FAQ: Big Wheels Question.............Will they fit?! - Page 4 EmptyMon Jun 25, 2007 1:26 pm
mcgusto82
mcgusto82
PostSubject: Re: FAQ: Big Wheels Question.............Will they fit?!   FAQ: Big Wheels Question.............Will they fit?! - Page 4 EmptyMon Jun 25, 2007 1:31 pm
900$ for rims from an intrepid seems high. check out your local craigslist.org or ebay. You can find a better deal.
PostSubject: Re: FAQ: Big Wheels Question.............Will they fit?!   FAQ: Big Wheels Question.............Will they fit?! - Page 4 EmptyMon Jun 25, 2007 1:38 pm
They aren't intrepid rims they are aftermarket rims on an intrepid.
I believe he wanted 20s so $900 for 20" rims and tires aren't bad if they are in decent shape. Considering something like that new goes for about $2,000+ depending on the rim.
Having them fit is the harder part. wink
¤DoughBoy¤
¤DoughBoy¤
PostSubject: Re: FAQ: Big Wheels Question.............Will they fit?!   FAQ: Big Wheels Question.............Will they fit?! - Page 4 EmptyMon Jun 25, 2007 4:17 pm
Exactly.........He only had them for a year..........and yes I am going to try them on and drive on them for a bit to see how it feels before I purchase them...........
mcgusto82
mcgusto82
PostSubject: Re: FAQ: Big Wheels Question.............Will they fit?!   FAQ: Big Wheels Question.............Will they fit?! - Page 4 EmptyMon Jun 25, 2007 7:29 pm
well, color me stupid then... lol
Make sure you post pictures. i've thought about 18's just got new tires so...
PostSubject: Re: FAQ: Big Wheels Question.............Will they fit?!   FAQ: Big Wheels Question.............Will they fit?! - Page 4 EmptyMon Jun 25, 2007 7:50 pm
What makes a rim fwd or rwd? I mean surely if it can support 1000 lbs of car plus force changes through bumps and curves it can handle the comparitively puny torque forces from the engine.
¤DoughBoy¤
¤DoughBoy¤
PostSubject: Re: FAQ: Big Wheels Question.............Will they fit?!   FAQ: Big Wheels Question.............Will they fit?! - Page 4 EmptyMon Jun 25, 2007 10:09 pm
^^Good Question............IDK Man.........they make it so complicated.........
PostSubject: Re: FAQ: Big Wheels Question.............Will they fit?!   FAQ: Big Wheels Question.............Will they fit?! - Page 4 EmptyTue Jun 26, 2007 12:14 am
AFAIK the offset determins if it is for FWD or RWD applications.
those are made for FWD cars so it should work if the bolt pattern works. 5x114.7 will fit the 5x115 on our cars, but you may have a slight ballancing issue or vibration. hubcentric rings may help also.
look at wheels on say, a BMW 7 series or high end wheels for RWD cars like lamborghini's (Gallardo that is, the Murcielago is AWD wink ) you will see the hub bolts up almost in the center of the wheel so it has close to 0 offset. our wheels bolt up at almost flush with the lip so it has a high offset +34 i think. (for the 12 spokes IIRC, and the 12 spokes are .5" wider than the other wheels for the riv)
you can change the offset slightly, but be careful of clearance.
btw a quick search pulled up some pages with good info on wheels. http://www.1010tires.com/tech.asp?type=wheels
FAQ: Big Wheels Question.............Will they fit?! - Page 4 Dsc_0110
I'm no expert, but FWD rims typically have a positive offset, while RWD rims have a negative offset.
¤DoughBoy¤
¤DoughBoy¤
PostSubject: Re: FAQ: Big Wheels Question.............Will they fit?!   FAQ: Big Wheels Question.............Will they fit?! - Page 4 EmptyTue Jun 26, 2007 9:30 am
Hubcentric Rings?
This helps so the wheel won't vibrate?
because I don't want to put them on and they mess up my studs.......
¤DoughBoy¤
¤DoughBoy¤
PostSubject: Re: FAQ: Big Wheels Question.............Will they fit?!   FAQ: Big Wheels Question.............Will they fit?! - Page 4 EmptyWed Jun 27, 2007 4:08 pm
ITS OFFICIAL..............I'M RIDING DUBS.........WILL POST PICS SOON IN A NEW THREAD!
Ridin-Rivi
Ridin-Rivi
PostSubject: Re: FAQ: Big Wheels Question.............Will they fit?!   FAQ: Big Wheels Question.............Will they fit?! - Page 4 EmptyThu Jun 28, 2007 1:32 pm
Many different offsets fit many different cars. I believe my 20's are a +20 offset. I have also put 20" rims off of my buddy's RWD comaro and they fit on my Buick Lesabre no problem.
PostSubject: Re: FAQ: Big Wheels Question.............Will they fit?!   FAQ: Big Wheels Question.............Will they fit?! - Page 4 EmptyThu Jun 28, 2007 2:28 pm
clap clap clap clap clap clap
bow bow bow bow bow bow
now go and RIDE ride ur "DUMBS"
jrocha
jrocha
PostSubject: Tire sizes and rims   FAQ: Big Wheels Question.............Will they fit?! - Page 4 EmptySun Aug 26, 2007 11:39 pm
Hey everybody,
I'm looking into getting some new tires for my Riv. Now my question to you (whoever is listening) is..... My Riv is a 97 and comes with the chrome rims which are 6.5" wide, I'd like to keep the original rims, but go with a wider tire and still stay as close to the original total diameter of the factory spec tires. Now because the rims are 6.5" wide, is it a big deal if I go with tires rated for a 7" rim? Will they blow-up on me or fall off the rims or something?
I'd like to go with a 245/55R16, but I'm not sure if I can because they are rated for a 7" rim. The stock tires are 225/60R16 which give me 8.85" of width, if I buy the 245/55R16 they will give me 9.64 of width, but maintain the same overall diameter.
What are your thoughts, of course keeping in mind that I don't want to switch out my rims, I want to keep the factory rims.
Thanks smile
PS: I just found out that depending on the tire manufacturer, tires are rated for different widths so my next question would be how thick can I go before I get interference problem with anything in the wheel well.
http://www.24quilates.net
PostSubject: Re: FAQ: Big Wheels Question.............Will they fit?!   FAQ: Big Wheels Question.............Will they fit?! - Page 4 EmptyTue Aug 28, 2007 12:55 am
what rims do you have? my stock are 7 wide
Merit : 66
PostSubject: Re: FAQ: Big Wheels Question.............Will they fit?!   FAQ: Big Wheels Question.............Will they fit?! - Page 4 EmptyTue Aug 28, 2007 12:07 pm
there is a sticky about tires in the suspension and handling section.
your tire won't blow up or fall off. You may find that it bulges (i.e. looks too big for the wheel) and if you eventually have problems with your tires, expect the manufacturer to say you weren't supposed to use it.
245/55-16 isn't a common size. I don't know who makes it, but you may be better off with a narrower, but better quality tire. Personally, I would use a 245 tire.
jrocha
jrocha
PostSubject: Re: FAQ: Big Wheels Question.............Will they fit?!   FAQ: Big Wheels Question.............Will they fit?! - Page 4 EmptyTue Aug 28, 2007 1:15 pm
The chrome rims are 6.5" and the others, like yours, are 7" wide.
Mine are chrome (6.5")
Page 4 of 10Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
» 98 riv wheels
» Pics of my riv - New rims on page 6 and 7
» FAQ: Rims, Wheels that Look Good on the Riv
» my wheels
» 71 gs wheels
