 FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)
zip_tie
DaveE_95Riv
MFFDVR
LT1Squirrel
2000ws6transam
96riv
rk0ehn
Sweepspear
rivman96
GMFreak8
Vista Cruiser
Natesriv
curious riv
EASHER
arttu80
BillBoost37
Buickman104
mr.19982tone
46 posters
Go to page : Previous  1, 2, 3 ... 9, 10, 11, 12  Next
Merit : 123
FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 10 Empty
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 10 EmptyWed May 23, 2012 1:27 pm
You say its a rebuilt SC. Who did the rebuild and did they strip the rotor coating?
The next thing is who ported the blower and whats the outlet look like?
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 10 EmptyWed May 23, 2012 2:43 pm
Steve, first thing you want to be sure of - is AutoTap reading boost or MAP? Are units set to PSI or In-Hg? Reason I ask is because 25 In-Hg just happens to be the same as 12.28 PSI. I didn't think AutoTap will read boost, but maybe you have a different version than I do.
If your units are set to kPA, and you are reading MAP, then approx baro pressure would be 101 kPA + 25 kPA = 126 kPA, or 18.27 PSI boost. That seems quite high, so I doubt you are reading in kPA.
2000ws6transam
2000ws6transam
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 10 EmptyThu May 24, 2012 12:34 am
its reading the MAP, but does the conversion to PSI it says raw value 33 coverts it to 4.78 psi. max with the old SC was 22.64 with 60- 80 intake temps with the new S/c machined outlet and ported and polished intake 3.4 pulley 25.08 PSI at intake temps from 72 - 90 (min / max) temp 1.4 degrees of knock max MAF was readin 10406 Hz coolant temp average 181 max 190 stil need to get my fans re programmed for the T stat.
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 10 EmptyThu May 24, 2012 8:54 am
Intake temps aren't going to make a big difference unless you are comparing winter to summer.
Just machining the blower and TB shouldnt yield that much gain in boost, IMO. Check your MAF numbers (not MAFF) to know how much increase in air flow you have. 1.4 KR is not bad. What did you see before?
2000ws6transam
2000ws6transam
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 10 EmptySun Jun 03, 2012 11:44 pm
before was 0 KR with 7.9 LBS boost stock with the S/c ported inlet and outlet and 3.4 pulley making 10.4 LBS with 1.4 KR
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 10 EmptySun Jun 03, 2012 11:49 pm
where was the vac leak?
2000ws6transam
2000ws6transam
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 10 EmptyMon Jun 04, 2012 12:00 am
went to the 98+ SC from a 97. its missing the vac line to the lowwer intake on the front side. its a totally different set up so i ended up drilling a hole in the stock elbow and got the factory vac line from the junkyard that raps around and stuck it in with some silicone. Seems to work fine and nothing acting weird like before... althought i still hear some weird noise from the air box sounds like a door keeps moving. but the air still works fine. Now i have a leak at the elbow from the lowwer intake.
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 10 EmptyMon Jun 04, 2012 12:01 am
hhmm
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 10 EmptyMon Jun 04, 2012 9:27 am
You are running a 3.4 pulley with no airflow mods besides the three angle valve job? 1.4 is not bad, and really not enough to worry about. Go to a 3.5 and that will go away. I couldn't get my 3.4 pulley to run KR free until I added 1.9 rockers.
2000ws6transam
2000ws6transam
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 10 EmptyMon Jun 04, 2012 11:01 am
yeah, i decided to wait and do the heads and lowwer intake because i wanted to get a tune after its all done. no mods besides the S/c 104's and K$N . i would like to get headers/ exaust full 3" that is simmilar to stock sound levels. and then go with a N* set up for the intake side.
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 10 EmptyMon Jun 04, 2012 12:28 pm
Will be difficult to do full 3" exhaust at stock sound level, nor do you really need to change anything downstream the headers until you are making 400+HP.
I agree with deekster that 1.4º KR at WOT is more than acceptable.
LT1Squirrel
PostSubject: Sudden loss of power, boost, CFM   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 10 EmptyThu May 09, 2013 10:32 pm
So i noticed recently my car was running a little sluggish, but with work and school, i havent had much time to investigate, but tonight i skipped the gym and went to play on the SS Buick instead... took out my trust torque app, and right off the bat i saw the problem...
Background: Bone stock car with a homemade cai, 180 stat, stock everything else, was about 60 degrees out, IAT's were 70-75 during the runs... did 3 runs all showing the same results vaccuum and timing looked normal, .7 max degrees of knock on the initial hit on one run, none on the others, i ran the car to the limiter in 2nd gear (6000) all 3 times and looked at the maxes, max boost: 3.8, 3.9, 4.2... max cfm all in the high 1400's.... on my timeslips from the track i always right down my maxes and they usually show max boost of 8-9psi with a max cfm well in to the 1900's sometimes eclipsing the 2k barrier... now this is my first supercharger car and i honestly dont know much about boost leaks and all that jazz... but any ideas on what would cause this?
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 10 EmptyThu May 09, 2013 11:09 pm
Sounds like the BBV is disconnected. Check all your vacuum lines. The T fitting under the SC snout can become brittle and break and then there is no vacuum to actuate the BBV. (Boost Bypass Valve)
LT1Squirrel
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 10 EmptyTue May 14, 2013 12:57 pm
Deek, you were right on the spot, good man... the T was just kind of hanging on there, and when i took it off the hard line going from the T to the other T on the front valve cover snapped... so i went to all the auto parts store and none have seen anything like that... so im assuming they're special order from GM?... and thats if they even still make them, is there a better fix?
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 10 EmptyTue May 14, 2013 2:32 pm
They are pretty much made of unobtanium, sorry to say. I think you can try to order a "vacuum harness". I seem to recall that somebody sells that tee separately now but I can't remember who. Cobbling together with universal tees really sucks and looks like shit.
Also try Morad's...
LT1Squirrel
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 10 EmptyTue May 14, 2013 5:01 pm
Yeah, right now its pretty hacked together, it works... but it just looks plain fugly haha
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 10 EmptyWed May 15, 2013 8:43 am
No worries, go to a dealer and order the vacuum harness for the 3800 engine. It will take a while to find because I think the P/N has been superseded more than once. I did this around a year ago, I might have posted the P/N but I don't remember. Point is just go buy the harness.
MFFDVR
MFFDVR
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 10 EmptyWed May 15, 2013 6:49 pm
I got the T from rockauto, I think. May have been GMpartscounter.com.
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 10 EmptyThu May 16, 2013 11:48 am
Any chance you have a part number?
LT1Squirrel
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 10 EmptyThu May 16, 2013 1:23 pm
So i constructed some lines, and its actually pulling more vacuum than it ever has at all RPM's lol... but now i think the BBV may be the culprit for the low boost, is there a way to diagnose or bypass it to see if that is causing the problem?
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 10 EmptyThu May 16, 2013 4:30 pm
Pull a vacuum on it with a vacuum pump and see if it holds. You should see it actuating when you quickly snap the throttle to rev the engine.
MFFDVR
MFFDVR
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 10 EmptyThu May 16, 2013 7:19 pm
I'll try to find the shipping reciept. It's been a while, but I do keep that stuff, somewhere.
LT1Squirrel
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 10 EmptyThu May 16, 2013 9:32 pm
i would run to my bro's shop and grab it, but all the boys are in OCMD for the cruise this weekend... any other way to check it? haha
LT1Squirrel
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 10 EmptyWed May 22, 2013 8:48 pm
so i did exactly what post 16 in this thread: http://www.grandprixforums.net/booooost-68178.html
and full boost has returned, but knock is now erratic, so the control valve is the culprit.... now the problem is finding the most up to date part number for it, because i dont like the way it looks under the hood
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 10 EmptyWed May 22, 2013 10:25 pm
Knock is erratic because you have full boost all the time. I wouldn't run like that besides the test.
Morad's probably has plenty of BBVs.
Page 10 of 12Go to page : Previous  1, 2, 3 ... 9, 10, 11, 12  Next
» Boost Bypass Valve Mod
» boost control solenoid??
» FAQ: Starter/Solenoid Info
» Armored boost control valve filter!
» boost control silenoid
