| LIM coolant elbow! | |
+34bunchabuix brutusk1 stan 96_Juggernaut bmcd9179 joshuadalegrimes 96rivie AA charlieRobinson DEMonte1997 1998 Riv LARRY70GS Natesriv crstump Dave1998riv chitown_riv98 2000ws6transam turtleman robotennis61 96scriviera Abaddon Eldo Rickw BrianEsser deekster_caddy Nez Jason albertj moldymac Joby70739 BillBoost37 98riv palermocorey90 T Riley 38 posters |
| Subject: Re: LIM coolant elbow! Sat Apr 24, 2010 2:08 pm | |
| Actually, it's halfway down the radiator tank on that side... You'll probably need a flashlight to see it. If the radiator is anywhere near full, you've either got a bad sensor or a short to ground somewhere. I'd give it a few days to turn itself off, then try unplugging it...
BTW: You are checking the radiator itself, not just the overflow tank, right? | |
Joby70739 Member
Name : Tori Age : 48 Location : Louisiana Joined : 2010-02-10 Post Count : 64 Merit : 4
| Subject: Re: LIM coolant elbow! Sun Apr 25, 2010 1:00 am | |
| I'm checking the radiator, you know the big thing in the front of the car.... Sorry about that I get asked questions like that all the time just because I am female. It gets old quick, I do all the work on my car. | |
| Subject: Re: LIM coolant elbow! Sun Apr 25, 2010 2:09 am | |
| - Joby70739 wrote:
- I'm checking the radiator, you know the big thing in the front of the car....
Sorry about that I get asked questions like that all the time just because I am female. It gets old quick, I do all the work on my car. I assure you, your sex had nothing to do with that last question - I assume that everyone is a moron... Thank you, thank you, I'm appearing here all week! But seriously folks, after several decades of manufacturers warning buyers to never EVER open the radiator, only the recovery tank, it really is a fair question. | |
96scriviera Amateur
Name : steve b Joined : 2011-02-13 Post Count : 23 Merit : 0
| Subject: coolant elbow Sun Feb 20, 2011 12:46 am | |
| my plastic elbow coming off the intake manifold is leakin<96 sc> the replacment comes with two plastic elbows anyone know where the other one is? if its close by ill change it while im their,thanks steve | |
| Subject: Re: LIM coolant elbow! Sun Feb 20, 2011 12:50 am | |
| Im pretty sure you can find them in steel. look for those.as to the location,i dont know. I have a 95 | |
| Subject: Re: LIM coolant elbow! Sun Feb 20, 2011 1:37 am | |
| Depending on what style tensioner your car has, you may only need one. I know my 97 only has the one plastic elbow. (2001 gtp I worked on has two) The other is non-removable; it's part of the tensioner casting. You can probably get a new o-ring for it though although my o-ring lasted basically the life of the tensioner itsself. | |
96scriviera Amateur
| Subject: Re: LIM coolant elbow! Sun Feb 20, 2011 2:03 am | |
| im pretty sure he replaced the tensioner..so i dont think its needed on this car...thanks! i know he put new belts and idler | |
| Subject: Re: LIM coolant elbow! Sun Feb 20, 2011 7:50 am | |
| The second elbow is for a different 3800. Our tensioner assy has that elbow built in, if you ever have to take the tensioner assy off you'll find the post. If you look at a W-body you'll see where the other elbow is used. | |
Name : Scott Location : Macomb, Michigan Joined : 2010-02-24 Post Count : 4316 Merit : 185
| Subject: Re: LIM coolant elbow! Sun Feb 20, 2011 12:31 pm | |
| Yep. The only elbow you need is the one that's fat on both ends, given that you bought the HELP! kit. | |
96scriviera Amateur
| Subject: Re: LIM coolant elbow! Mon Feb 21, 2011 1:49 am | |
| josh got it fixed and the new green SC coupler in. gonna order some rockers here soon and replace he LIM gaskets while im at it | |
2000ws6transam Enthusiast
Name : steve Age : 47 Location : Indy Joined : 2011-10-29 Post Count : 181 Merit : 6
| Subject: coolant leaking think its from the plastic elbow Fri Jun 08, 2012 2:22 pm | |
| how hard is it to replace this? and what all do i need to remove i actaully have all the parts to do it i was going to wait till i did my heads but im loseing almost 1/2 a gallon a day and i only drive maybe 35 miles a day | |
| Subject: Re: LIM coolant elbow! Fri Jun 08, 2012 3:01 pm | |
| It's easiest to pull the alternator bracket off. (it contains the coolant passages to the hoses). Give yourself 2 hours start to finish. The elbows are in any self respecting auto parts stores, in the 'Help' section. | |
| Subject: Re: LIM coolant elbow! Fri Jun 08, 2012 3:02 pm | |
| Be VERY SURE you got all of the old broken plastic pieces out. You may need to root around inside the intake manifold and the alternator bracket with a pick or very small screwdriver. | |
chitown_riv98 Fanatic
Name : Ruben Age : 43 Location : Illinois Joined : 2008-03-10 Post Count : 399 Merit : 4
| Subject: Re: LIM coolant elbow! Fri Jun 08, 2012 5:14 pm | |
| When I had this problem on the riv I went ahead and replaced the belt tensioner assembly along with the 2 coolant elbows. The original elbows were baked on and were giving me trouble but once removed it was a breeze. I noticed that there was play in the belt and decided it was a good time to replace the tensioner. | |
98riv Moderator
| Subject: Re: LIM coolant elbow! Fri Jun 08, 2012 5:31 pm | |
| - chitown_riv98 wrote:
- When I had this problem on the riv I went ahead and replaced the belt tensioner assembly along with the 2 coolant elbows. The original elbows were baked on and were giving me trouble but once removed it was a breeze. I noticed that there was play in the belt and decided it was a good time to replace the tensioner.
If you go this route the tensioner comes with the two coolant elbows that you will need. Check out this thread https://rivperformance.editboard.com/t7519p15-write-up-replacing-accessory-belt-tensioner. _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
| Subject: Re: LIM coolant elbow! Sat Jun 09, 2012 12:28 am | |
| l purchased the elbows from the Help section at Advance as well as the belt tensioner assembly. I didn't realize that the tensioner came with the elbows.I have an extra set of coolant elbows in my spare Rivi parts drawer. I don't see how they didn't make the elbows from some type of metal. | |
Dave1998riv Special
Name : Dave d Joined : 2012-06-11 Post Count : 6 Merit : 0
| Subject: Plastic Coolant Elbow question?!?!? Mon Jun 25, 2012 8:00 am | |
| The hose that ls directly below the supercharger dry rotted and managed to blow its self to pieces!!! My question is what is it and what do I ask for at the parts store to replace it???? Would love some input!! Thanks | |
| Subject: Re: LIM coolant elbow! Mon Jun 25, 2012 8:07 am | |
| Do you mean the plastic elbow? Or the lower radiator hose? What year is your car?
The plastic elbow comes out of the lower intake manifold, makes a 90 degree turn into the alternator bracket on '96-'99 cars. Not sure how the '95 does it but it's a whole different motor.
Those plastic elbows are in stock in just about every auto parts store, usually in the "Help" section. Most of the time it will be in a two-pack, one with a slightly different shape.
Unfortunately you'll have to remove the alternator bracket (or the lower intake manifold) to replace the elbow. If this is it, MAKE SURE you get all the old pieces out. This is not as easy as it sounds. They can be really stuck in there, you'll need a good pick, an inspection mirror and light, and a lot of patience to make absolutely sure you got all the pieces of the old elbow. | |
| Subject: Re: LIM coolant elbow! Mon Jun 25, 2012 12:17 pm | |
| - Dave1998riv wrote:
- The hose that ls directly below the supercharger dry rotted and managed to blow its self to pieces!!! My question is what is it and what do I ask for at the parts store to replace it???? Would love some input!! Thanks
As Derek says the plastic elbows are available in the HELP section at most auto parts stores. You have a 1998. This SC arrangement was used for several years after 1998; to avoid uncertainty you can ask at a dealer. The GM P/N is probably 24503423 and it's definitely less than $15. However, if you just go buy the Dorman HELP kit 260608 it's $3 to $5. If it is one of the radiator hoses you are looking for they are widely available, just get it from a parts store or a dealer. Given the age of the car, the dealers probably just get them (elbows and hoses) from a local NAPA or CarQuest anyway. | |
crstump Member
Name : Corey Age : 29 Location : carrollton ky Joined : 2012-02-22 Post Count : 92 Merit : 1
| Subject: Re: LIM coolant elbow! Tue Jul 17, 2012 6:17 pm | |
| my elbo peice busted on me just 15 min ago. right at the elbo. i was not sure if it ran directly to the intake or not cause i couldnt find any other broken peices laying around. so the elbo runs from the belt tensioner to the intake??? if you can post a pic of this so im 100% sure were on same subject | |
| Subject: Re: LIM coolant elbow! Tue Jul 17, 2012 10:38 pm | |
| - crstump wrote:
- my elbo peice busted on me just 15 min ago. right at the elbo. i was not sure if it ran directly to the intake or not cause i couldnt find any other broken peices laying around. so the elbo runs from the belt tensioner to the intake??? if you can post a pic of this so im 100% sure were on same subject
There should be a write up on elbow replacement on the site. You should check to see if any pieces are still in. You might want to check your tensioner and see if it needs to be replaced anyway, now would be a good time. I kinda doubt you need a picture; that's the only place on the manifold having a coolant line. | |
| Subject: Re: LIM coolant elbow! Thu Jul 19, 2012 1:42 pm | |
| Be very very sure you get all the old pieces of elbow out. It will take a small pick, some patience, and a small mirror to see inside the holes. | |
| Subject: Re: LIM coolant elbow! Thu Jul 19, 2012 2:45 pm | |
| Don't know if i'm too late with this but there was a defective batch of those help/dorman coolant elbows that were kept stocked as I found out earlier this year when my 3 week old one started warping and pulling its self out. I think they took care of the problem but there's still bad ones out there. I got my replacement from the dealer. | |
| Subject: Re: LIM coolant elbow! Sun Jul 22, 2012 7:08 pm | |
| I ended up replacing the belt tensioner assembly when i needed to replace the coolant elbows. I believe that the elbows are included with the assembly. It wasn't too bad. I did encounter some issues along the way
Natesriv Addict
Name : Nate Age : 54 Location : KCMO Joined : 2007-01-18 Post Count : 509 Merit : 16
| Subject: leaking coolant from this L-Shaped tube Wed Nov 07, 2012 2:33 pm | |
| guys...what is this tube? I'm leaking coolant pretty bad, car is at work and I'm stranded! What is this L shaped tube coming out of the idler pulley arm there at the top (the black L-Shape)??? How does it come out? Single piece?? Whole new idler pulley?? Thanks!! | |
| Subject: Re: LIM coolant elbow! | |
