| Write-Up: Changing Engine Oil | |
+24playa Rickw Derek florence_x rivman96 TonySmooth89 3.8 Riviera Mr.Riviera Ironclad-454 Sweepspear Eldo Rivette 1wickedninja EatDirtFartDust 1998 Riv ibmoses deekster_caddy albertj 96RivSCMI Ash AA ewolfe0050 Snowdog IBx1 28 posters |
Ironclad-454 Enthusiast
Name : Nate Age : 40 Location : Oklahoma Joined : 2008-11-22 Post Count : 162 Merit : 9
 | Subject: Re: Write-Up: Changing Engine Oil Tue May 26, 2009 10:13 pm | |
| Its an Acronym for Wide Open Throttle or full throttle.
This whole thread has me curious, I'm gonna have to test this on mine, just for giggles.
Last edited by Ironclad-454 on Tue May 26, 2009 10:15 pm; edited 1 time in total (Reason for editing : added/spelling) | |
TonySmooth89 Aficionado
Name : Anthony Age : 34 Location : Florida Joined : 2007-11-14 Post Count : 2410 Merit : 16
 | Subject: Re: Write-Up: Changing Engine Oil Tue May 26, 2009 11:19 pm | |
| - Mr.Riviera wrote:
- mine reads 99.6% on the floor too.
i'll have to see if i can get it to read 100 sometime. Yeah mine reads 99.69 at the floor too. I'd say it was a 96 thing , but i'm not using a 96 tb anymore... | |
rivman96 Enthusiast
Name : Cameron Age : 34 Location : Asheville, NC Joined : 2008-09-15 Post Count : 100 Merit : 1
 | Subject: Re: Write-Up: Changing Engine Oil Wed May 27, 2009 4:22 pm | |
| I have noticed that when if I drain my oil with my car on ramps that not all of the oil will come out... now I just climb under there | |
Name : Mark Age : 58 Location : West Salem, Oregon... FINALLY Joined : 2009-04-09 Post Count : 3113 Merit : 104
 | Subject: Re: Write-Up: Changing Engine Oil Wed May 27, 2009 5:30 pm | |
| - Ironclad-454 wrote:
- Its an Acronym for Wide Open Throttle or full throttle.
This whole thread has me curious, I'm gonna have to test this on mine, just for giggles. OK guys, I have the last piece of this puzzle - I think I just did the 3rd test with my '97, parked overnight. Yesterday I did it at 140 and 185 degrees. -If the key is in the 2nd unlocked position (Run) when I floor the gas, the car still starts. -If the key is in the 1st unlocked position (Off), when floored, I get "WOT flooded-mode". -If the key is in the Lock position when I floor it, I get "WOT flooded-mode". I reproduced these results pretty faithfully all 3 times. Hopefully Burt, Aaron or Nate can also... | |
 | Subject: Re: Write-Up: Changing Engine Oil Wed May 27, 2009 8:24 pm | |
| - Eldo wrote:
- -If the key is in the 2nd unlocked position (Run) when I floor the gas, the car still starts.
Ding Ding!! I remember now - that's how I remember it working on our '86... still haven't tried it on the '98 but I will soon. It's also how my old Holley ProJection worked. | |
 | Subject: Re: Write-Up: Changing Engine Oil Wed May 27, 2009 8:40 pm | |
| - deekster_caddy wrote:
Ding Ding!! I remember now - that's how I remember it working on our '86... still haven't tried it on the '98 but I will soon. It's also how my old Holley ProJection worked. Well don't keep us in suspense, get out there!  | |
 | Subject: Re: Write-Up: Changing Engine Oil Fri May 29, 2009 2:58 am | |
| Well c'mon... Somebody get out there and test the final theory! Surely some of you drive your cars...  | |
 | Subject: Re: Write-Up: Changing Engine Oil Fri May 29, 2009 1:07 pm | |
| Every day!! I'll try to remember next time I get in. I usually have other things to think about... | |
Name : Dave Age : 62 Location : In The AZ Oven Joined : 2007-01-17 Post Count : 4502 Merit : 44
 | Subject: Re: Write-Up: Changing Engine Oil Fri May 29, 2009 1:11 pm | |
| - rivman96 wrote:
- I have noticed that when if I drain my oil with my car on ramps that not all of the oil will come out... now I just climb under there
I have mine up on a floor jack to change oil. I let it drain a few minutes jacked up, then I lower it almost to the floor and let it drain a while longer. There's ALWAYS going to be more old oil missed if you only drain it when it's raised way up. | |
 | Subject: Re: Write-Up: Changing Engine Oil Fri May 29, 2009 1:15 pm | |
| That's more reason to change oil every 3k instead of waiting 5k or longer. You never get all the old out, so might as well dilute it with more frequent changes of fresh oil. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: Write-Up: Changing Engine Oil Fri May 29, 2009 3:40 pm | |
- That's more reason to change oil every 3k instead of waiting 5k or longer. You never get all the old out, so might as well dilute it with more frequent changes of fresh oil.
I settled on 4,000 miles a long time ago, even with the ever-improving conventional oil, and the semi or full synthetics... Also, I noticed something a couple years ago: When Mobil-1 came out they were always advertising 25,000 miles between oil changes, and even as a kid I told people, A) show me a car that won't burn or leak 1 quart in 5,000 miles, thus slowly 'changing' the whole crankcase over 25,000, and, B) the oil may last that long, but both the oil and the filter will be full o' shit by that time! Now, they've cut their claims back by 10,000 miles - the most you see advertised on the bottles is 15,000... | |
 | Subject: Re: Write-Up: Changing Engine Oil Fri May 29, 2009 3:42 pm | |
- Every day!! I'll try to remember next time I get in. I usually have other things to think about...
ExCUSE me? You have things to think about beside your RIVIERA? What kind of sick fcuk are you!?!  | |
 | Subject: Re: Write-Up: Changing Engine Oil Fri May 29, 2009 4:47 pm | |
ExCUSE me? You have things to think about beside your RIVIERA? What kind of sick fcuk are you!?!  Oh shit. Well now I'm called out. I'm going to do it tonight when I leave work for sure maybe I think. If I'm not too preoccupied with fending off all the hot chicks who luv my pimp ride. | |
 | Subject: Re: Write-Up: Changing Engine Oil Fri May 29, 2009 8:31 pm | |
ExCUSE me? You have things to think about beside your RIVIERA? What kind of sick fcuk are you!?!  Oh shit. Well now I'm called out. I'm going to do it tonight when I leave work for sure maybe I think. If I'm not too preoccupied with fending off all the hot chicks who luv my pimp ride. ...and does your wife know about all those hot chicks?!? | |
 | Subject: Re: Write-Up: Changing Engine Oil Tue Jun 09, 2009 8:42 pm | |
| I'm quite surprised these things are fairly easy to change the oil on. The filter is readily accessible and theres no obstructions to the filler neck. My dad likes Chrysler LHSs and I occasionally help him out and do it for him, those are a pain to get to the filter sometimes they seize up and you have to literally screw the socket to bottom of the filter. lots of fun  I used Castrol GTX 10W-30 and a PF-52 filter, great idea guys thanks. And to make Eldo happy I tested his theory and low and behold, no start with the pedal to the floor. I also changed the spark plugs, which turned out to be originals. It seems to have better throttle response now although that may just be my imagination. That #6 hole is a bitch to get to, lol.
Last edited by Ironclad-454 on Tue Jun 09, 2009 8:42 pm; edited 2 times in total (Reason for editing : Continuity) | |
 | Subject: Re: Write-Up: Changing Engine Oil Tue Jun 09, 2009 9:15 pm | |
| [quote="Ironclad-454"My dad likes Chrysler LHSs and I occasionally help him out and do it for him, those are a pain to get to the filter sometimes... And to make Eldo happy I tested his theory and lo and behold, no start with the pedal to the floor. [/quote]
1- Thanks for testing the WOT-mode
2- If your dad ever talks about changing his battery in that LH-car, run for the hills! Anyone who doesn't like the battery location in our cars should change one in the Chryslers - They buried 'em behind the starboard headlights... you gotta' pull the wheel to get to 'em. | |
 | Subject: Re: Write-Up: Changing Engine Oil Wed Jun 10, 2009 1:42 am | |
2- If your dad ever talks about changing his battery in that LH-car, run for the hills! Anyone who doesn't like the battery location in our cars should change one in the Chryslers - They buried 'em behind the starboard headlights... you gotta' pull the wheel to get to 'em. Anytime. Yeah I already found that one out, lol. It was the first last and only time, he gets to do it by himself. | |
 | Subject: Re: Write-Up: Changing Engine Oil Wed Jun 10, 2009 1:35 pm | |
| Mine wouldn't start at first with the pedal to the floor, but did on the second try. I think it's not because of a fuel cutoff, but rather that there's just too much air and it won't run that lean. Mine coughed a little and tried to start the first time I tried it but chugged out and ended up just cranking. The second time I hit the key with my foot still at the floor, it started and revved quickly (the reason I didn't want to try this in the first place!) | |
 | Subject: Re: Write-Up: Changing Engine Oil Wed Jun 10, 2009 1:43 pm | |
| - Quote :
- it started and revved quickly (the reason I didn't want to try this in the first place!)
Me too! Thanks for sparing me the wear to cylinder walls. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: Write-Up: Changing Engine Oil Wed Jun 10, 2009 3:10 pm | |
| I didn't let it crank for more than, I'd say 5 sec at a crack. I didn't want the starter getting too hot. So that might have had something to do with it. | |
 | Subject: Re: Write-Up: Changing Engine Oil Wed Jun 10, 2009 3:23 pm | |
| - Quote :
- I didn't want the starter getting too hot.
Yes, that too! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: Write-Up: Changing Engine Oil Wed Jun 10, 2009 4:06 pm | |
| Well, I suppose the important thing isn't whether the WOT-trick works for everyone, but whether or not I'm RIGHT! Buried in our factory manuals, under diagnostics for an engine that cranks but won't start, is an instruction to test the TPS because "If the TP angle is more than 80 percent, the PCM may operate in clear flood mode. The PCM will not allow fuel delivery while operating in clear flood mode..."A little research on the web also found that there is an RPM limit on "clear flood mode", which might explain some of the variability we're finding, when combined with temperature, battery condition, oil, etc.  One last note: It appears that most of the people who can't make the clear flood mode work have re-tuned their PCM's....... | |
 | Subject: Re: Write-Up: Changing Engine Oil Wed Jun 10, 2009 4:13 pm | |
| As far as I know, PCM tuning only affects selected parameters. It only re-writes the areas of the memory that have been selected by the tuning application. There are many, many portions of the PCM that tuning software can't even access, let alone reprogram. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: Write-Up: Changing Engine Oil Wed Jun 10, 2009 5:37 pm | |
| - Eldo wrote:
One last note: It appears that most of the people who can't make the clear flood mode work have re-tuned their PCM's....... Well that's true, and I have altered the 0 and 400 RPM areas of the VE table. | |
 | Subject: Re: Write-Up: Changing Engine Oil  | |
