 Engine Swap + Gen V
BillBoost37
manofmany
19 posters
Go to page : 1, 2, 3, 4, 5, 6  Next
Engine Swap + Gen V Empty
PostSubject: Engine Swap + Gen V   Engine Swap + Gen V EmptySat Jul 11, 2009 7:30 am
so my radiator has been leaking for a few weeks now. I finally decided last night when I got home from work 6:30 ish to remove it and go have it fixed. Started by draining the coolant and removing the front header. Innocent enough...
The car was already jacked up off the ground.
The coolant was drained.
The front header was off.
stopped at 10:30 last night, radiator is still in the car, but well... ummm.
Engine Swap + Gen V 6613_1167997714204_1055785180_30520142_8194737_n
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V EmptySat Jul 11, 2009 7:33 am
So, you decided to go ahead with the engine swap a little earlier than scheduled.
Good Luck with it and can't wait to take a ride in it when it's all tuned.
Speaking of tuning after your done wrestling with your car I've got to get mine over there for some tuning.
manofmany
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V EmptySat Jul 11, 2009 9:10 am
Start with the intention of removing the radiator and pull the whole damn engine. I like that concept lol
Is it tricky at all to get to the bolts mating the tranny/engine? I've always pulled the two as one assembly.
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V EmptySat Jul 11, 2009 10:01 am
You did damn good time on pulling the motor, 4 hours or so.
You'll have the new one in today and running.
Sorry i can't get over to help. I'm going to start my Rocker , valve spring and pulley swap today, probably finish tomorrow.
Taking it slow. Oh the pain of it all, but I can't wait any more and the weather here is great this weekend.
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V EmptySat Jul 11, 2009 11:24 am
Ooo i have never seen anyone removing the whole engine to get the radiator out...
oka okay joking...
what are you going to do whit the engine?
change leaking gaskets sealings? clean/paint the engine?
port/polish anything?
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V EmptySat Jul 11, 2009 12:27 pm
I have a built engine w/ ZZP VS cam, head work, Gen V blower all assembled on my engine stand... should be in this afternoon but I won't have a radiator until wednesday. Cracked tank, $85 to get a new tank put on.
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V EmptySat Jul 11, 2009 1:09 pm
WOW!
That is so cool, and should be a blast.
Bert tavis
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V EmptySat Jul 11, 2009 2:25 pm
awsome deek! how difficult was it to remove the engine from the top? its been recomended that the engine be removed from the bottom. but since i dont have a lift...wheew thats not how im going to remove mine!
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V EmptySat Jul 11, 2009 8:29 pm
Derek,
How about some installed pic's.
How far along did you get today?
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V EmptySat Jul 11, 2009 9:27 pm
the 'backwards bolt' or 'bastard bolt' as it's known is really not that bad. Remove the bracket holding the pass. side transmission to engine, then you have a clear path from the pass. side wheel well, with a whole bunch of extensions just take it out like a normal bellhousing bolt. Don't make a big deal about it, except that you do need to remove the pass side wheel and inner wheel well plastic liner.
As far as top vs bottom - for just the transmission, it's easier to drop the cradle away from the trans, and drop the trans after supporting the engine. For just the engine it's easier to separate the two and remove the engine from the top. If you are replacing both do it from underneath.
On the donor car for my engine, I dropped the cradle, struts and engine and transmission to the floor, then lifted the car with my engine crane by the front bumper, and slid the whole shebang out through a wheel well. It was easy, but it was also a wrecked car and I didn't have to worry about it. I wouldn't recommend this for your 'good' car.
Today I got the necessary accessories swapped over - A/C brackets were a little different, ground the back of my alternator down a little to clear the GenV blower, exchanged the oil filter adapters (different angle than the donor GP), water outlets and alternator bracket, and got the belts routed through that front bracket, swapped my good idler pullies over, etc etc. Dropped the engine into the bay, most bellhousing bolts and the front motor mount in place, and that was all the time I had. I used the morning to run errands (drop off broken radiator, etc), and didn't really get started until 12:30 or so, and had to stop at 4:30, so I was happy to get the block dropped into place. Tomorrow is busy, so Monday night I'll do the bastard bolt and bracketry etc, headers, valve covers (new ones are painted blue, no thanks!), starter etc. I won't have the radiator back until Wednesday, but I'll have it ready to start as soon as I have the radiator.
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V EmptyThu Jul 16, 2009 7:22 pm
Well I got the radiator back today. Had a little trouble after startup, wrong MAF table at first, then discovered a broken coolant elbow, then a bad hose clamp... but other than those minor things, it runs pretty good and just needs some tuning time!
Gen V and cam woohoo!!
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V EmptyThu Jul 16, 2009 7:30 pm
Congrats, can't wait to hear it, see it and ride in it.
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V EmptyThu Jul 16, 2009 8:22 pm
Good deal, I am sure you were glad to get her going.
I bet its a Hoss!
Bert tavis
BillBoost37
Merit : 26
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V EmptyFri Jul 17, 2009 7:57 am
Glad to hear it's up and runnin. Great job, and good turn around time.
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V EmptyFri Jul 17, 2009 8:07 am
Thanks! The whole job was about 18 hours of labor, would have been less except for the little annoyances on reassembly. Good news also is I cured my header tick exhaust leak while it was apart.
I took a whole bunch of pictures, not a writeup, really more reference shots as it went on. Pasting a link to the photo gallery instead of individual pictures:
Photo Gallery
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V EmptyFri Jul 17, 2009 8:09 am
Signature picture!
Engine Swap + Gen V Web
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V EmptyFri Jul 17, 2009 10:21 am
Photo Gallery
Hey, can anybody tell me if the link to photos worked? Somebody told me it was asking for a password, and it shouldn't be...
thanks!
Merit : 123
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V EmptyFri Jul 17, 2009 10:23 am
It works fine for me.
thanks
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V EmptyFri Jul 17, 2009 11:14 am
Sweet!
How does the car feel?
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V EmptyFri Jul 17, 2009 11:59 am
oldsman105 wrote:
Sweet!
It's totally different - just going to the N* throttle body makes a big difference, the throttle response is changed just from the throttle cable bracket/progressive throttle thingy being different. I haven't punched it yet, watching my tune first, want to be safe!!
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V EmptyFri Jul 17, 2009 12:14 pm
SWEEEEEET! I can't wait to see a timeslip for that thing once its dialed in!
Were there headers that came one the wrecked GP? If they're not pacesetters and you're interested in selling them , shoot me a pm.
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V EmptyFri Jul 17, 2009 12:37 pm
They are TOGs. I'm not sure if they are for sale yet. I am still cataloging all the leftover parts...
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V EmptyFri Jul 17, 2009 12:42 pm
Gotcha. Just LMK if you wanna get rid of them.
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V EmptyFri Jul 17, 2009 3:01 pm
thats a mans job for sure deek! im happy for you. my engine is going to be ordered a little later than i had planned...so..wow! big job! i bet that engine feels smooth...did you go overbore on the pistons? and if so is there extra tourque?
Engine Swap + Gen V
Page 1 of 6Go to page : 1, 2, 3, 4, 5, 6  Next
» Series III 3 engine swap
» what other parts do i need for my engine swap?
» 97 SC Engine swap
» ls4 engine swap?
» FAQ: Series II Supercharged V-6 Engine
