 Engine Swap + Gen V
BillBoost37
manofmany
19 posters
Engine Swap + Gen V - Page 5 Empty
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V - Page 5 EmptyWed Aug 12, 2009 12:50 pm
My Gen V is on.. and running just waitin to get outta the hospital to start tuning
BillBoost37
Merit : 26
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V - Page 5 EmptyWed Aug 12, 2009 1:01 pm
Derek's tip of the week for you is not to pour water into your gas tank. Do that and tuning should be a snap.
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V - Page 5 EmptyWed Aug 12, 2009 1:09 pm
hmm what about corn cyclops
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V - Page 5 EmptyWed Aug 12, 2009 3:10 pm
So for now I'm running the open cone single elbow "HAI" that came with the motor. I am seriously thinking of keeping it... the sound really is incredible! It's only there under <50% throttle, and it really does sound awesome!
I'm not one for sounds, I much prefer a quiet car, but this thing sounds GREAT when you get on it!
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V - Page 5 EmptyWed Aug 12, 2009 3:35 pm
How did you run your EVAP on the gen V deek? block off plate and delete the code? or did you use that gen v evap?
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V - Page 5 EmptyWed Aug 12, 2009 3:45 pm
The EVAP is hooked to the fitting right after the IAC/TB. The PCV is hooked into a little pipe in the intake tube, after the MAF and before the TB.
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V - Page 5 EmptyWed Aug 12, 2009 3:58 pm
what about your evap sensor? you know that little thing right after the inlet of the gen v? there is that little hole with the single bolt to hold it on?
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V - Page 5 EmptyWed Aug 12, 2009 4:03 pm
I'll have to take some pics if my above description doesn't cover it... I don't know what the ports are called, I just knew where to hook them up.
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V - Page 5 EmptyWed Aug 12, 2009 4:30 pm
lol its ok... i would like pics man.. thanks brosef!!
BillBoost37
Merit : 26
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V - Page 5 EmptyThu Aug 13, 2009 1:28 pm
I think Derek blocked off the stock evap port on the GV because if you tried to use the stock Gen V valve, the TB hit it.
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V - Page 5 EmptyThu Aug 13, 2009 2:25 pm
Ya im' runnin my TB upside down.. it comes like 1/2 inch away from the cross over
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V - Page 5 EmptyThu Aug 13, 2009 2:49 pm
How come your running the TB 180* out (up side down) ? I'm clueless!!!!
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V - Page 5 EmptySat Aug 15, 2009 11:11 am
uhh hey deek...any idea how much the 3.8 weighs? shes gotta weigh at least 500 lb or more no?
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V - Page 5 EmptySat Aug 15, 2009 2:33 pm
No idea. I don't think it weighs 500 lbs.
Because.. the EVAP sensor on the GEN V hits the TB if ran properly!!!
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V - Page 5 EmptySat Aug 15, 2009 7:21 pm
Have you got any pic's of what you are talking about.?
I'll be installing my GenV possibly next month so I'd like to know what it should look like and how it should be setup / installed.
I'll be buying the ZZP N* kit.
I've seen the deekster's engine but didn't take any pic's of the set-up.
Maybe next time I go over there I can look a little more and take some pic's. I always forget to bring a camera though. And it would be good to have the photo's on here for other people to reference.
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V - Page 5 EmptySat Aug 15, 2009 7:25 pm
ya i'll take some pics early this week!!! no prob
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V - Page 5 EmptySun Aug 16, 2009 6:17 pm
update today:
Fixed all the 1/8 vacuum lines, made a brass T for the EVAP/PCV, made some new Taylor 8mm spiro pro wires (custom length style, looks great), filled up with a new CLEAN tank of 93 shell.
Result: running AWESOME, even in the 92 degree heat! STFTs and LTFTs are all close to 0, so my old tune is pretty damn close to my new motor.
Several WOT runs up to 85, O2s at 920-940, timing at 14-15, no KR. Pulls like crazy and whines like a bastard! I opened some eyes on the highway that's for sure. I can't wait to go to the track!!
Woohoo!!
Needs a fresh oil change and fuel filter before too much more whipping, but still it's alllll there.
happy happy happy happy happy happy happy
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V - Page 5 EmptySun Aug 16, 2009 7:47 pm
What does the EVAP and PCV have in common. I thought they were separate lines.
Maybe after Travis takes some pic's it will be more clear...or maybe you could take some pic's of your set-up and post them here.
I would appreciate it. Congrat's on the "NEW" car !!!!!!!!
Did you use the intake set-up i saw while I was there or did you put the FW/OEM/Modded set-up in.?
Thanks
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V - Page 5 EmptySun Aug 16, 2009 8:07 pm
Rick, it's stil running the hot air open cone intake. Underhood temps today were scanning as about 140!
The evap and Pcv both want intake vacuum on a large port, so I teed them off the throttle body port and capped the hole in my intake tubing. I'll try to get some pics up soon (tmrw)
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V - Page 5 EmptySat Aug 22, 2009 11:23 am
So, after having solved all the little glitches how is it running now.
Have you run out of fuel using the 42.5# injectors with cam and other mod's?
Should I expect to increase the capacity of my injector's when I install the Gen V.??
Currently running stock injectors. What is the flow rate for stock injectors anyway.?
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V - Page 5 EmptySat Aug 22, 2009 12:12 pm
Stock injectors are 36#. I upgraded to 42.5s long ago be ause I was trying to lick kr on the 3.2 pulley on the gen3and dumping in fuel to compensate. I am not close to maxing out the 42.5s and to my surprise, the new motor had stock injectors in it! So, I would say you should wait and see if we are maxing out your injectors befor upgrading. It's not difficult to do later and might turn out to be unnecessary.
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V - Page 5 EmptySat Aug 22, 2009 12:15 pm
I've stayed away from 42.5# injectors because I fear they would decrease my fuel efficiency.
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V - Page 5 EmptySat Aug 22, 2009 3:01 pm
i can vouch they wont make ur MPG go down. but its all about how you drive. the last few tank fulls i have been light on the gas. just crusing around town, with a few WOTs here and there i get about 23-24 MPG average for a gas tank. BTW thats with 3.29 gears, and im cammed.
PostSubject: Re: Engine Swap + Gen V   Engine Swap + Gen V - Page 5 EmptySat Aug 22, 2009 3:08 pm
How are you measuring this MPG? By average, do you mean combined? Do you have fuel records from pre-cam/42.5# to compare?
Engine Swap + Gen V
Page 5 of 6Go to page : Previous  1, 2, 3, 4, 5, 6  Next
» Series III 3 engine swap
» what other parts do i need for my engine swap?
» 97 SC Engine swap
» ls4 engine swap?
» FAQ: Series II Supercharged V-6 Engine
