 Fuel Injector Cleaning
L67GAMSE93
rivcop
Brad95Riv
NO 4 EVR
Sag
24 posters
Fuel Injector Cleaning - Page 3 Empty
PostSubject: Re: Fuel Injector Cleaning   Fuel Injector Cleaning - Page 3 EmptyWed Sep 04, 2013 10:07 pm
155000thou...they toast
PostSubject: Re: Fuel Injector Cleaning   Fuel Injector Cleaning - Page 3 EmptyTue Sep 10, 2013 10:17 pm
Before
Fuel Injector Cleaning - Page 3 HPIM1814_zps28bc5f13
day after tomorow I'll have the after fotos.Bill sed they cleaned up real good.They had some flow issues with erratic spray patterns.
PostSubject: Re: Fuel Injector Cleaning   Fuel Injector Cleaning - Page 3 EmptyTue Sep 10, 2013 11:31 pm
Just sent my extra set in yesterday, along with 4 Honda injectors. Bet he has them all done by Fri.
PostSubject: Re: Fuel Injector Cleaning   Fuel Injector Cleaning - Page 3 EmptyThu Sep 12, 2013 7:32 pm
And after
Fuel Injector Cleaning - Page 3 HPIM1817_zps78dd94d5
no pic of the Cherry Rancher as it's in me maw allready
I'm just a little stumped on the 80% flow?  what happened to 100% flow?  are my injectors bad?
PostSubject: Re: Fuel Injector Cleaning   Fuel Injector Cleaning - Page 3 EmptyThu Sep 12, 2013 7:49 pm
I think the 80 is in relation to volume of the cylinders they were spraying into. I think Injector 3 was 80 before because it was your best flowing injector. The best will always be at 80 before and then you can compare what the others did in that time. All being at 80 after just means they moved the same amount of volume in the same amount of time! The LBS/ HR is whats important if you know they are all flowing the same! At least thats what Im getting from the summary!
PostSubject: Re: Fuel Injector Cleaning   Fuel Injector Cleaning - Page 3 EmptyThu Sep 12, 2013 7:51 pm
No kiddin!? how many lbs are the series 1 injectors supposed to flow? I'm guessing 30.4 lbs/hr is optimal,right?
PostSubject: Re: Fuel Injector Cleaning   Fuel Injector Cleaning - Page 3 EmptyThu Sep 12, 2013 8:00 pm
No idea! They probably made sure one was brought to within spec or whatever the optimal flow was and matched the rest!
PostSubject: Re: Fuel Injector Cleaning   Fuel Injector Cleaning - Page 3 EmptyThu Sep 12, 2013 8:28 pm
According to a bonnevillePRO.com thread I found, Series I L67 injectors have a flow spec of 29 lb/hr.
PostSubject: Re: Fuel Injector Cleaning   Fuel Injector Cleaning - Page 3 EmptyThu Sep 12, 2013 8:29 pm
wow! well,I'm looking into it.It seems that for the 95 s/c the injectors are fine.According to a source,we wouldnt need anything bigger until the Riv starts making 500hp or more.So, I guess I'm good.I'm still confused about other members posted pics of their injectors flowing 100%. what gives?
PostSubject: Re: Fuel Injector Cleaning   Fuel Injector Cleaning - Page 3 EmptyThu Sep 12, 2013 9:30 pm
My Series II L67 injectors flow 36 lb/hr, but whether or not that's needed, I'm not sure. INTENSE Racing claims their 42.5 lb/hr units are recommended for 420 HP, and 60 lb/hr units support 720 HP.
Btw, mine came back with max flow at 95, so I don't think it's a percent. I wouldn't worry about them being 100. As long as they're matched and the output is within spec (in your case better), it's all good!
PostSubject: Re: Fuel Injector Cleaning   Fuel Injector Cleaning - Page 3 EmptyThu Sep 12, 2013 9:58 pm
ah,ok. makes sense I guess. Got 'em all installed.I'll post a tutorial for anyone interested.
Merit : 63
PostSubject: Re: Fuel Injector Cleaning   Fuel Injector Cleaning - Page 3 EmptyThu Dec 05, 2013 10:43 pm
Sorry to dig up an old thread, but I have a question. Are the O-rings for the Series II injectors the same on the top and bottom of the injectors? I want to pull mine to do a home-made cleaning and wanted to make sure they weren't two difference sized between the manifold o-rings and fuel rail o-rings. Thanks!
PostSubject: Re: Fuel Injector Cleaning   Fuel Injector Cleaning - Page 3 EmptyFri Dec 06, 2013 9:35 am
I'm pretty sure the upper and lower O-rings are different.
Merit : 63
PostSubject: Re: Fuel Injector Cleaning   Fuel Injector Cleaning - Page 3 EmptyFri Dec 06, 2013 9:20 pm
Yeah I thought so too. I'll probably get a bunch for when I go to do my dad's Regal. It's probably due for LIM gaskets soon, it recently hit 103,000 miles.
» Fuel Injector Q&A
» Is my fuel injector bad?
» Can oil leak out of fuel injector grommets?
» Fuel injector leak... weird
» fuel line leak. need to disable fuel pump. Fuse or relay?
