I want to eventually mount a couple of gauges in the ashtray area also. Where do you get the black plastic or ABS to make a gauge panel.??? I was thinking of going to where they do custom car stereo installs and ask for a small piece of the necessary size. Would that be the place to go.???
Hometown Hero Junkie
Name : Klix Age : 45 Location : Barrhead, Alberta Canada Joined : 2009-11-18Post Count : 807 Merit : 16
I haven't yet decided on ABS plastic or just a custom metal plate. We have a fabrication shop in town here & my buddy works there called Breal Metal. I think I'll have him whip up something crisp lookin. Maybe get Riviera stamped or etched in, paint it black but leave the scribe machined. Shouldn't be crazy expensive its only a small piece. I just think plastic looks so cheap is all. Doesn't suit a loaded car.
Name : Rick Location : Lancaster, MA Joined : 2008-09-13Post Count : 6282 Merit : 119
When you decide to do that, let me know what you've decided on. I may want to duplicate the order if you don't mind. That would definitely look more classy. Rick
yeah 4 sure I can get a better a deal that way on them 2. do you want the etching or stamped Riviera badge aswell on yours? If any1 else is thinking of it or interested let me know we can piece together a decent order for him at least then.
I don't know about etching or stamped yet. Will have to give it a little thought. What are you leaning toward. When you say etching, are you referring to a mechanical etch that is computer controlled for accuracy or hand etching.??? I'm serious about getting this done though and you have the car up there to provide all the correct dimensions needed. I think it will be cool. What type of material are you leaning toward, Aluminum, Stainless, or just plain steel. I just re-read your idea on painted steel and then etched, that could be cool looking also. Please let me know what your ideas are.?
You have a 95, I'll have to measure my 98 and make sure they are the same dimensions.!!!!!!!!
It would be laser etched. If Breal Metal for some reason cannot do it there is a place about 20 minutes away called Danik Machine they specialize in machining billet aluminum, etc. Pretty sure it'd be a breeze for them. As for the Riv logo I had thought either the standard Riviera handwritten style badging etched in, or maybe a the classic R logo, maybe even Rivperformance.com, or Riviera Performance if the boss approves lol? Really I hadn't decided on material but aluminum would be pretty narley. Will probably be doing it as soon as the car hits the road this spring so we got time to get something concrete hammered out. Pm me with dimensions to verify they are the same, and any ideas you may have as well. 2 minds are better than 1 maybe you have somthing in mind as well I'm all ears. If any1 else is interested just pm me.
I kinda like the classic -R- logo as well. Tasteful and understated, just like all the other logo's on the car. Just some initial thoughts, like you said we have time to figure this out and sketch it up.
A plate the width of the ashtray will hold 3 gauges, if we only install 2 on the outside edges and put the -R- in the middle.
Subject: Re: Write-Up: Installing Boost Gauge Sat Feb 06, 2010 4:22 pm
I think that would look sharp!
Subject: Re: Write-Up: Installing Boost Gauge Sat Feb 06, 2010 6:00 pm
Klix, I like the gauges you chose, the Autometer Cobalts. I'm leaning toward the Autometer Nexus line. I have a brand new Nexus Boost-Vacuum gauge that was just about given to me. Guy owed me some money, so I took the gauge in payment. Still in original box with all hardware and wiring, etc. The only problem with the Nexus line is you have to buy the controller (sensor module w/remote) to operate any of them. So I would have to invest in the controller plus one more gauge, probably a voltmeter or oil pressure gauge. I'll keep my eyes open on Ebay for a deal or just sell this one on Ebay. It Retails new for $249.00 the last time I checked. Have you had a look at their Nexus stuff, it's a very nice product but very pricey. Can't wait to finish the design of this mounting plate. I think it will look very good on the interior. Nice Custom Touch.
My plan was I had hoped to keep the existing flip up / hide away "dummy panel" covering the ashtray and lighter socket in the car. I will really only need these gauges part time, so I had thought it'd be cool to have a kind of stow away set-up. Flip the lid when your ready to use em and behind the lid you would have the machined billet plate n gauges where the ashtray n lighter used to be. I am sure the guys at breal or Danik will also have some good ideas. I will get mine made up and photo graph it before install, you can tell me what you would like the same, and what differences you'd like on yours. Then I will have that 1 made and can ship it out to you. Sound good?
My plan is to keep the flip up door as well. So keep me/us posted on what you come up with. That all sounds good to me.
GMFreak8 Addict
Name : Kyle Age : 35 Location : Malone, New York Joined : 2009-03-15Post Count : 638 Merit : 15
Subject: Re: Write-Up: Installing Boost Gauge Wed Feb 10, 2010 10:57 am
Its a car part now wrote:
The gauge you linked to is a vacuum gauge. The gauge in the write up is a boost/vacuum gauge. A vacuum gauge shows how much the pressure in manifold is below barometric( at idle, part throttle, cruise, n/a motor). A boost gauge shows how far above barometric the supercharger is pushing into engine. A vacuum/boost shows both with zero in middle.
The site you linked to has a vacuum/boost gauge in the "black styleline" line. There is also a amp, oil pressure and volt gauge in same style. The vacuum/boost is 270* sweep, others are 60* sweep (oil gauge is available in 270*, but is mechanical, so there is risk of hot, pressurized oil spraying in interior if leak starts). Besides sweep they look the same.
Thanks so much for clarifying that. I appreciate it.
Subject: Re: Write-Up: Installing Boost Gauge Wed Mar 24, 2010 11:02 am
There are lots of ways to do it, but a simple way is to make a flat panel out of a thin piece of plastic or metal and mount the gauge(s) in holes. Then you mount the panel where the CD player was. A plastic material that's easy to work with is styrene sheet. .080" or .100" thickness would work. It's easy to cut, you can paint it, and can even bend it if you heat it up. It won't kink or crease like metal.
AA, where would I or anyone else be able to buy Styrene sheet stock from.??? I need some for my upcoming stereo and gauge install as well as a project for my motorcycle.
Well, I was gunna take my Riv in to get that gauge plate machined for it a week ago. Unfortunately we had a tragic death in the family, and I am left in charge of my Uncles estate. Pretty well gobbled up the next 4-6 months of my personal time and gave me a few extra bills.
Now its snowing again for the last 3 days after it just finished melting away for the winter. The Rivi is sitting under a nice white blanket in the driveway. Once the snow melts again, & I get everything squared away with the lawyers and everything I will get the ball rolling again. Talked to the machinist when he came in yesterday he said it prolly won't be that expensive 2 make, its just such a small piece.
I order large quantities (4'x8' sheet) from American Plastic Distributors here in Columbus, OH:
http://www.americanplasticdistributors.com/
Or, you can visit a local hobby store like Hobby Land (not Hobby Lobby). They sell smaller quantities for model railroaders, usually 12x6" pieces. Many thicknesses are available. Here's a place online that sells the same:
Klix, I am so sorry to here about your Uncles passing. Obviously you have more important things to tend to than installing some gauges in the car. If I get a little further along and make one out of plastic material I will still want to replace it with what we have discussed. Once again, so very sorry about your loss. Rick
Thanx Rick, I will definately keep you posted as things move along. Gotta pick up and carry on as they say, just wanted to put it out there that there may be a little delay on the gauge plate. I know you were interested and I haven't forgotten about ya.
Thanx again for your condolences.
Snowdog Addict
Name : Timo Age : 38 Location : Finland Joined : 2008-10-04Post Count : 732 Merit : 24
Good catch Larry, was looking at it and didn't think of that. I'm sure you saved someone the possible mistake of thinking they could get both.
Yes, they mention it in the first 2 pages of this thread, but of course, I discovered it the hard way way back when
7901mark Enthusiast
Name : Mark Joined : 2010-04-22Post Count : 127 Merit : 6
AHAHAHAHAHA, that is so funny. I found this out on the first drive...all vac no boost. LOL, so shoot me, Im new to the riv . What is there a check valve in there or something?
Karma Aficionado
Name : Andrew Age : 39 Location : Ontario, Canada Joined : 2008-01-14Post Count : 1949 Merit : 123
