 FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)
zip_tie
DaveE_95Riv
MFFDVR
LT1Squirrel
2000ws6transam
96riv
rk0ehn
Sweepspear
rivman96
GMFreak8
Vista Cruiser
Natesriv
curious riv
EASHER
arttu80
BillBoost37
Buickman104
mr.19982tone
46 posters
Go to page : 1, 2, 3 ... 10, 11, 12  Next
mr.19982tone
mr.19982tone
FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 Empty
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 EmptyThu Feb 14, 2008 5:31 pm
have not done anything with it its been shitty out so i have not been drivin it
https://s273.photobucket.com/albums/jj211/mr19982tone/
arttu80
arttu80
PostSubject: NO BOOST in tha RIV!!!   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 EmptyThu May 15, 2008 3:07 pm
Today I hooked up boost gauge and so it was, no boost. Max 3psi at WOT!
I suspect control solenoid, but I would appreciate tips on troubleshooting.
In the picture below is control solenoid, and one port is open, WHY? May it be the culprit? Please help!
FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 Img1104348
The car is 1997 Riviera.
Btw, I already replaced supercharger coupler and nose bearings, and I hear supercharger whine at WOT, so its not stuck or anything. I also checked that boost valve is moving, when I start the car.
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 EmptyThu May 15, 2008 8:33 pm
that port should be open. and it is suposed to have a little filter on it but w/e.
still sounds like it could be the control valve or a vac line. does the arm on the BBV fully open/close?
FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 Dsc_0110
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 EmptyThu May 15, 2008 11:54 pm
mine did that the other day.
dont know what it was. Just chalked it up to the PCM cutting boost off because of a fueling problem. Normal boost now.
arttu80
arttu80
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 EmptyFri May 16, 2008 12:29 am
Well, I checked that BBV lever is going up when car is started and when it shut down, lever resting on intake plenum. So it is moving.
What's the good place to shop around for new boost control solenoid? I checked rockauto.com but they doesn't seem to have one...
BillBoost37
Merit : 26
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 EmptyFri May 16, 2008 7:24 am
Find one from other members for $10-15. GM wants about $30-40 IIRC.
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 EmptyFri May 16, 2008 3:12 pm
mine is only getting about 7psi at WOT
is my BCS going out? Or do you really lose that much boost with a ported SC?
arttu80
arttu80
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 EmptyFri May 16, 2008 5:28 pm
Well, 7psi would be normal. According to 1997 Riviera/Aurora shop manual it should be around 7-9psi, so its ok. Mine is only about 2-3psi at WOT, so its not charging. My PA Ultra is Series I SC engine, and it feels much more quicker than 97 Riv with Series II SC motor, because of low boost.
I tried to eliminate bypass solenoid and even disconnected vacuum line from bypass valve, but its still 2-3psi. I'm hearing some "hissing" sound maybe from under blower, I guess it may be faulty plenum to supercharger gasket or something? I dunno yet.
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 EmptyFri May 16, 2008 5:40 pm
is the vac line under the blower snout connected?
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 EmptyFri May 16, 2008 6:35 pm
well 7-9 is normal for a 3.8 pulley on a stock motor. I got a 3.25" Sorry, didn't mean to hijack your thread. What was the theory behind bypassing the BCS?
yes. All my vac lines now run from that one port since I got the newer type SC housing.
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 EmptyFri May 16, 2008 6:40 pm
Yes, but drew is running a 3.25" pulley and some other mods, so I think 7 PSI is pretty low. I normally hit 11-12 with a 3.4" pulley. 14-15 PSI with a 3.2".
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 EmptySun May 18, 2008 11:11 pm
so any thoughts?
is missing half my boost enough to suspect the BBV or BCS as culprit? Or is it something else?
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 EmptySun May 18, 2008 11:20 pm
dreww wrote:
so any thoughts?
It happend to me. Bypass the BCS to be sure.
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 EmptyMon May 19, 2008 1:41 am
oldsman105 wrote:
dreww wrote:
so any thoughts?
I bypassed the BCS and it doesnt make a difference. The BBV is opening fully, and now Im getting max 1.6psi mad I just know if I start replacing all those parts it still wont fix the problem and will make we wanna drive her off a cliff.
oh, and also got a vac leak somewhere now (LTFT 16.4) and I cant hear it anywhere. ALL vac lines are new. I dont even know where to go from here.
arttu80
arttu80
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 EmptySat May 24, 2008 11:47 am
Anyone know, where I can get supercharger-to-intake gasket??
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 EmptySun May 25, 2008 11:54 pm
http://www.zzperformance.com/grand_prix/products1.php?id=306&catid=103
dont forget the o-rings too.
http://www.zzperformance.com/grand_prix/products1.php?id=305&catid=103
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 EmptyMon May 26, 2008 12:04 am
dreww wrote:
oldsman105 wrote:
dreww wrote:
so any thoughts?
So how did you bypass the BCS oldsman? I tried it (but dont know if I did it correctly) and the problem remained. I re-tightened the SC bolts and about half were a little loose (1/4-1/2 turn) but that still didn't fix the problem. Got a new BBV Im gonna test today but dont think it will fix the problem since the old one seemed to be working fine (but was ghetto patched with JB weld)
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 EmptyMon May 26, 2008 12:53 am
Sure way to check the BBV, physically brace it shut (down) at the flat swinging lever with a block of wood or something. If it makes boost at that point, the BBV or something that controls it is malfuntioning. If you don't get your boost, then the vac leak must be pretty bad or theres another problem entirely
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 EmptyWed May 28, 2008 11:12 pm
well my new BBV didn't fix the problem rolleyes though it did need replacing as its been broke since I got the car. Now Im getting 2psi at WOT so its looking more like the BCS.
I think I finally figured out how to bypass it. And will check the ohms on it to to see if its functioning or not.
EASHER
EASHER
Name : ERIK M. ASHER
PostSubject: CAN YOU RUN BOOST ALL THE TIME?   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 EmptyWed Dec 17, 2008 8:02 am
Is it possible to block the bypass in the S/C so that it runs under boost at all times?
Would this damage the engine, or is it just a way to keep the mpg up?
It seems that running most of the time in a N/A mode kind of defeats the purpose of having a supercharged engine in the first place.
What do you think?
http://snardfarker.ning.com/profile/ERIKMASHER
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 EmptyWed Dec 17, 2008 9:20 am
What do you think?
There is a BBV mod that you can do to make it boost QUICKER.... I did it and noticed a LITTLE BIT... its a FREE mod so Search it... under Free Boost Bypass Valve mod
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 EmptyWed Dec 17, 2008 9:21 am
curious riv
curious riv
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 EmptyWed Dec 17, 2008 9:23 am
ive read that this mod increases knock at mid level rpm and the poster swore that should not be done. the gains are very minimal and really dont seem to be worth the extra chance of knock where there used to be none
EASHER
EASHER
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 EmptyWed Dec 17, 2008 9:26 am
I did that already. I was wondering if it is possible to completely eliminate the bypass function and have the engine under boost at all times.
curious riv
curious riv
PostSubject: Re: FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost)   FAQ: Boost Bypass Valve/Boost Control Solenoid Questions (No Boost) - Page 2 EmptyWed Dec 17, 2008 9:33 am
Im still fairly new to the whole 'boost' thing- but that sounds bad to me. Why would u want boost when its not needed ie. idle.
Page 1 of 12Go to page : 1, 2, 3 ... 10, 11, 12  Next
» Boost Bypass Valve Mod
» FAQ: Starter/Solenoid Info
» Boost Control Solenoid Filter
» Armored boost control valve filter!
» boost control silenoid
