| | FAQ: Fuel Pump - General Questions, Compatibility & Troubleshooting | |
+42bigdave al_roethlisberger pbrktrt rivy96 96riv rivparadise LARRY70GS dtrumbo Bawb2u flyineagle96 Karma Northeast BMD manofmany robotennis61 Abaddon rivman96 jeffyd123 themba elh21566 Rick's Riv 98inSFl Eldo Z-type playa jonly turtleman Rickw AA lionfish T Riley albertj cjoform Mr.Riviera Snowdog 99Rivman 1995 Riv 97rivsc Riviera96 deekster_caddy Sag envus87 46 posters | |
 | Subject: Re: FAQ: Fuel Pump - General Questions, Compatibility & Troubleshooting Mon Sep 23, 2013 12:08 pm | |
| Locating a vac leak by ear can be difficult at best. Using a mechanic's stethoscope w/funnel amplifier makes the job a lot easier. The spray test mentioned above by turtleman is another tried/true method that works.
If you can't find a vac leak, I would inspect the MAFF sensor and IAT (intake air) sensor for proper connection, dirt, or damage. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
|  | | bmcd9179 Fanatic
Name : Bryson Age : 27 Location : Utah Joined : 2013-09-21 Post Count : 288 Merit : 1
 | Subject: HELP FUEL PUMP Tue Sep 24, 2013 8:19 pm | |
| HI guys i just bought my 96 riviera and it was running lean for awhile and finally the fuel pump died, i got it towed home and im stuck, anyone have specific steps on how to replace it and pictures, anything would help. thanks! | |
|  | | joshuadalegrimes Addict
Name : josh Age : 42 Location : harrodsburg, ky Joined : 2012-09-02 Post Count : 501 Merit : 13
 | Subject: Re: FAQ: Fuel Pump - General Questions, Compatibility & Troubleshooting Tue Sep 24, 2013 10:11 pm | |
| search for the write up. its easy | |
|  | | al_roethlisberger Junkie
Name : Al Roethlisberger Age : 54 Location : Sanford, NC Joined : 2013-03-12 Post Count : 960 Merit : 24
 | Subject: Re: FAQ: Fuel Pump - General Questions, Compatibility & Troubleshooting Tue Sep 24, 2013 11:12 pm | |
| Here you go. https://rivperformance.editboard.com/t6381-write-up-fuel-pump-sending-unit-na-series-iihttps://rivperformance.editboard.com/t8943-faq-fuel-pump-general-questions-compatibility-troubleshooting?highlight=fuel+pumpI would advise getting the Delco or Delphi pump. It is a little more expensive, but it will last. Some of the cheaper units don't last very long, so in the end the savings aren't really there as you'll be changing it again soon... maybe very soon. Also go ahead and buy a new locking ring and gasket for $5-ish. Most are corroded by now. Cheap insurance. I just did this replacement about 6 months ago, and it was a snap. I think it took maybe an hour. Be prepared to cut and attach a new wiring harness connector at the pump though. They changed the connector at some point. The new pumps come with the new plug, wire and instructions. It is easy, but is the only "complex" (not really) part of the replacement that isn't purely plug-and-play. If your locking ring is really corroded, that can be a bear. Mine was pretty clean and still took some serious whacks with a mallet. But once it started turning, it came right off. Al | |
|  | | bmcd9179 Fanatic
 | Subject: Re: FAQ: Fuel Pump - General Questions, Compatibility & Troubleshooting Thu Sep 26, 2013 10:55 pm | |
| so i fixed it, the fuel pump went out, it was the fuel pump going out and not working well, but its running amazing now! | |
|  | | Abaddon Expert
 | Subject: Re: FAQ: Fuel Pump - General Questions, Compatibility & Troubleshooting Fri Sep 27, 2013 8:39 am | |
| Well now that's a rarity. Not often does a Fuel Pump take a dump and toss a lean code out.
Glad to hear that it's fixed. | |
|  | | deekster_caddy Master
 | Subject: Re: FAQ: Fuel Pump - General Questions, Compatibility & Troubleshooting Fri Sep 27, 2013 12:31 pm | |
| Lesson learned - it's worth checking fuel pressure as well when you have a lean code! | |
|  | | Sponsored content
 | Subject: Re: FAQ: Fuel Pump - General Questions, Compatibility & Troubleshooting  | |
Similar topics |  |
