 FAQ: Fragged Tensioner/Idler Pulley Reports & Questions
IFallsRon
moldymac
Nez
Joby70739
97rivsc
manofmany
duster_do_little
millerje18
Sweepspear
baynes72
captshiner
96rivgirlla
texasfan010
BillBoost37
36 posters
Merit : -16
FAQ: Fragged Tensioner/Idler Pulley Reports & Questions - Page 3 Empty
PostSubject: Re: FAQ: Fragged Tensioner/Idler Pulley Reports & Questions   FAQ: Fragged Tensioner/Idler Pulley Reports & Questions - Page 3 EmptyTue Nov 11, 2008 12:02 am
They didn't take anything, but I am not about to pull ALL of the stuff in my center console out for that. There's a ton of stuff crammed in there.
AA, it is a low drone-like sound. Not harsh, it almost sounds like maybe if I took the resonator off or something but not quite as loud. It's an exhaust noise, I'm positive. It's not a belt or anything making the noise. The only noises it made before were some S/C noise due to the coupler but that was it.
PostSubject: Re: FAQ: Fragged Tensioner/Idler Pulley Reports & Questions   FAQ: Fragged Tensioner/Idler Pulley Reports & Questions - Page 3 EmptyTue Nov 11, 2008 12:10 pm
Hey, Shintsu, the noise might be co-incidental. Even with the best of maintenance, in higher mileage cars someting is always 'going.' It's as likely not something the mechanic did as it is that it is.
IF it was the supercharger belt that was replaced, might want to look and see if the bolt and ferrule were inadvertently not replaced or not tightened all the way in teh bottom right corner of the passenger side engine mount.
Also might want to check the motor and transmission mounts.
Merit : -16
PostSubject: Re: FAQ: Fragged Tensioner/Idler Pulley Reports & Questions   FAQ: Fragged Tensioner/Idler Pulley Reports & Questions - Page 3 EmptyWed Nov 19, 2008 11:53 pm
Found out that it sort of was something they did - but not really something they could be blamed for. The noise is apparently coming from the tensioner pulley. Fix one thing (torn up belt) and break another doing it. Bullshit...dealer says $158 for the part and no telling what labor would be.
PostSubject: Re: FAQ: Fragged Tensioner/Idler Pulley Reports & Questions   FAQ: Fragged Tensioner/Idler Pulley Reports & Questions - Page 3 EmptyThu Nov 20, 2008 10:52 am
The tensioner pulley is about $35-50 if you shop around. The mechanic should fix it for you, since the problem was almost directly related to the area they were working in. If the pulley was bad, they should've noticed and offered to fix while they had the belt off. If it was good, it should not be making noise now. This is looking like more than just coincidence.
Merit : -16
PostSubject: Re: FAQ: Fragged Tensioner/Idler Pulley Reports & Questions   FAQ: Fragged Tensioner/Idler Pulley Reports & Questions - Page 3 EmptyThu Nov 20, 2008 11:07 am
My dad is the one who took it back up and had them look at it and they even when he took it up there took a wrench to it and showed my dad that's what was doing it. It's funny that this pulley can make what sounds like an exhausty sound. It's not like there's a squeaking or anything under the hood, it's an exhausty sound for certain.
PostSubject: Re: FAQ: Fragged Tensioner/Idler Pulley Reports & Questions   FAQ: Fragged Tensioner/Idler Pulley Reports & Questions - Page 3 EmptyThu Nov 20, 2008 5:31 pm
Hmm.... wonder if the pulley fragged the belt?
Merit : -16
PostSubject: Re: FAQ: Fragged Tensioner/Idler Pulley Reports & Questions   FAQ: Fragged Tensioner/Idler Pulley Reports & Questions - Page 3 EmptyThu Nov 20, 2008 11:29 pm
Well, the belt managed to ride up on the lip of the supercharger pulley and that frayed the edges of the belt. That's what caused the belt to get torn up in the first place. What caused that to actually happen though, I don't know.
PostSubject: Re: FAQ: Fragged Tensioner/Idler Pulley Reports & Questions   FAQ: Fragged Tensioner/Idler Pulley Reports & Questions - Page 3 EmptySat Dec 06, 2008 5:57 pm
The wifes car started making a racket Monday. It was the pulley on the SC tensioner. Since it was dark by the time I get off work and I dont have time to fix the problem I let a local AC Delco certified shop repair it. I have used them several times before and they try their best to do good work.
They replaced all the pulleys for the Supercharger belt. $192.15 I thought that was a fair price.
Bert tavis
Sweepspear
Sweepspear
PostSubject: Re: FAQ: Fragged Tensioner/Idler Pulley Reports & Questions   FAQ: Fragged Tensioner/Idler Pulley Reports & Questions - Page 3 EmptySat Dec 06, 2008 7:05 pm
Bert tavis
That sounds like a bargain.
By the way, I just this afternoon replaced my SC belt without removing that cast iron engine mount bracket that attaches to the block.
I removed the nut off the top stud, removed the nut and stud from the bottom one and was able to wiggle that spacer out.
The tough part was getting the spacer back in place since the crank sensor harness is right there, and you have to feel your way around blind. censor
These different engineering departments should have gotten together for coffee now and then.
There is no excuse for making belt replacement such an ordeal. suspect
cheers
PostSubject: Re: FAQ: Fragged Tensioner/Idler Pulley Reports & Questions   FAQ: Fragged Tensioner/Idler Pulley Reports & Questions - Page 3 EmptySat Dec 06, 2008 10:07 pm
Bert tavis
Bert, are you sure they replaced the lower idler pulley, the one that is TRAPPED by the engine mount? I'm surprised they did it that cheap, even though it was only the SC system.
PostSubject: Re: FAQ: Fragged Tensioner/Idler Pulley Reports & Questions   FAQ: Fragged Tensioner/Idler Pulley Reports & Questions - Page 3 EmptySat Dec 06, 2008 10:16 pm
1998 Riv wrote:
Bert tavis
Yep, I checked.
I asked the shop manager if he knew what he was getting into when I carried the car to get it fixed.
He had already told me it would be no problem, so I said what are we looking at here... $300 to 400.00 ?
He told me it should be less than $200.00, maybe they gave me a break because they did not realize it would be harder to do than a SC Regal or PA.
I will call next week and ask the guy, he is a friend from my dirt track racing days and this is a really good shop, or so it seems to be...
Bert tavis
millerje18
millerje18
PostSubject: need advice about bearings   FAQ: Fragged Tensioner/Idler Pulley Reports & Questions - Page 3 EmptyTue Feb 17, 2009 11:41 am
im a college student and dont know much about engines ans so forth. And my car has been making a terrible loud sound for the past two days. I thought it was my supercharger since ive been trying to get it rebuilt for like 2 years. but when i brought it in to the auto repair shop he just said the i need a new bearing since it's chipping away. I dont want to get jipped off by him,
Does anyone know a reasonable price for a bearing to be replaced by a mechanic?
PostSubject: Re: FAQ: Fragged Tensioner/Idler Pulley Reports & Questions   FAQ: Fragged Tensioner/Idler Pulley Reports & Questions - Page 3 EmptyTue Feb 17, 2009 12:01 pm
you can check on ebay for rebuilt superchargers and kits; it would take a couple hours to properly remove and reinstall teh supercharger. Add $70 or so for miscellaneous gaskets and shop supplies.
one thing that might frustrate you about the Riviera is that it's a luxury car and unless you are doing the repairs yourself they get real expensive real fast. If you are not doing the work yourself you might set some time aside to learn.
PostSubject: Re: FAQ: Fragged Tensioner/Idler Pulley Reports & Questions   FAQ: Fragged Tensioner/Idler Pulley Reports & Questions - Page 3 EmptyTue Feb 17, 2009 12:25 pm
What bearing did they say needs replacing. ???
Supercharger bearing or something else ???
millerje18
millerje18
PostSubject: Re: FAQ: Fragged Tensioner/Idler Pulley Reports & Questions   FAQ: Fragged Tensioner/Idler Pulley Reports & Questions - Page 3 EmptyTue Feb 17, 2009 12:28 pm
it was a bearing that was connected to the belt. there was residue from it since it was chipping and grinding off.
PostSubject: Re: FAQ: Fragged Tensioner/Idler Pulley Reports & Questions   FAQ: Fragged Tensioner/Idler Pulley Reports & Questions - Page 3 EmptyTue Feb 17, 2009 12:34 pm
Is that a bearing or a pulley? You got a picture (cell phone snapshot?)
PostSubject: Re: FAQ: Fragged Tensioner/Idler Pulley Reports & Questions   FAQ: Fragged Tensioner/Idler Pulley Reports & Questions - Page 3 EmptyTue Feb 17, 2009 12:37 pm
Sound like a pulley bearing. Can't tell which one from your description but they are not expensive. I just changed a tensioner pulley with bearing and the part cost me $20.00 and 10 minutes to change it.
I don't know which one of your's is chirping but any one of the pulley's are not expensive.
If they are talking about the bearings inside the supercharger then that's a different story, but it doesn't sound like it from your brief description.
Bring it to someone else for a second opinion and write down what they tell you specifically so we can help you.
PostSubject: Re: FAQ: Fragged Tensioner/Idler Pulley Reports & Questions   FAQ: Fragged Tensioner/Idler Pulley Reports & Questions - Page 3 EmptyTue Feb 17, 2009 1:48 pm
If it is a bad idler or tensioner pulley bearing, you'll need to fix it soon. They tend to fail quickly after they start making noise. The pulleys are easy to change except for the one inside the engine mount. If it's that one, you might want to let the mechanic do the job.
I've never heard of a bearing going bad in the supercharger. Very unlikely unless you're out of supercharger oil (also unlikely).
millerje18
millerje18
PostSubject: Re: FAQ: Fragged Tensioner/Idler Pulley Reports & Questions   FAQ: Fragged Tensioner/Idler Pulley Reports & Questions - Page 3 EmptyTue Feb 17, 2009 2:03 pm
there saying to install a new bearing they want 200$ for them to buy it and get it shipped to them. and 100dollars to install the new bearing.
PostSubject: Re: FAQ: Fragged Tensioner/Idler Pulley Reports & Questions   FAQ: Fragged Tensioner/Idler Pulley Reports & Questions - Page 3 EmptyTue Feb 17, 2009 2:05 pm
There are lots of bearing on the car. Did they say which bearing?
millerje18
millerje18
PostSubject: Re: FAQ: Fragged Tensioner/Idler Pulley Reports & Questions   FAQ: Fragged Tensioner/Idler Pulley Reports & Questions - Page 3 EmptyTue Feb 17, 2009 2:07 pm
he said it was an ac clutch that was making the noise
PostSubject: Re: FAQ: Fragged Tensioner/Idler Pulley Reports & Questions   FAQ: Fragged Tensioner/Idler Pulley Reports & Questions - Page 3 EmptyTue Feb 17, 2009 2:32 pm
OK, that explains things better.
The whole clutch mechanism is replaceable and that price seems about right to me.
Mine was replaced a few years ago, don't remember the exact cost but that seems close.
That's a job that requires special tools and is better handled by a competent shop.
millerje18
millerje18
PostSubject: Re: FAQ: Fragged Tensioner/Idler Pulley Reports & Questions   FAQ: Fragged Tensioner/Idler Pulley Reports & Questions - Page 3 EmptyTue Feb 17, 2009 2:44 pm
thanks a lot. i appreciate it.
duster_do_little
duster_do_little
PostSubject: Re: FAQ: Fragged Tensioner/Idler Pulley Reports & Questions   FAQ: Fragged Tensioner/Idler Pulley Reports & Questions - Page 3 EmptySun Feb 22, 2009 4:25 pm
my tensioner pulley fragged on me in december. It was at like 155k miles. I replaced it with a smooth metal one, but that's all I could find at any of the autoshops. AutoZone and Advance didn't even carry a 3" idler pulley. Luckily it's an easy fix
PostSubject: Re: FAQ: Fragged Tensioner/Idler Pulley Reports & Questions   FAQ: Fragged Tensioner/Idler Pulley Reports & Questions - Page 3 EmptySun Feb 22, 2009 5:52 pm
Well - the metal one won't frag like the plastic ones, but is somewhat higher drag on the engine. You can get billet aluminum pulleys for lots of $$. Plastic ones should be available from RockAuto.com among other places.
When you replace a pulley, be sure to check the others and replace all that have any binding,.. and use a silver or white Sharpie to write the date somewhere on the face of each pulley you replace.
Page 3 of 8Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
» FAQ: High Mile Club - Wear/Repair Reports
» FAQ: Selecting Proper Supercharger Pulley & Belt Size (Series I)
» FAQ: Smaller SC pulley? What Size?
» SC PULLEY
» Pulley kit
