 FAQ: Aeroforce Interceptor Scan Gauge
setsuna57
robertwolf86
Ironclad-454
manofmany
lyonsperformance
BillBoost37
rivwilly107
Supercharged
34 posters
Go to page : 1, 2, 3, 4, 5, 6  Next
FAQ: Aeroforce Interceptor Scan Gauge Empty
PostSubject: FAQ: Aeroforce Interceptor Scan Gauge   FAQ: Aeroforce Interceptor Scan Gauge EmptySun Sep 23, 2007 8:20 pm
Note from admin:
Before asking questions about how to connect the gauge, how to use it, or its list of features, please visit the Aeroforce web page at the link below and read the manual. Choose the version number closest to the number on the back of your gauge:
http://www.aeroforcetech.com/Usermanual.html
_____________________
I've got a couple questions about the aeroforce guage -
- Does it read engine temp?
- How do you control it ?   I'm wondering about replacing the engine temp guage with the Aeroforce guage and keeping the vents, but then the guage wouldn't be physically accessible.
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   FAQ: Aeroforce Interceptor Scan Gauge EmptySun Sep 23, 2007 9:08 pm
Yes, it reads almost anything a regular scanner reads. It also reads and clears engine codes. It has an option to record performance too (1/4 mile time and hp) but I don't know how accurate it is.
You just push the button and it scrolls through the params. I think I have about 25 total. Well worth it IMO.
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   FAQ: Aeroforce Interceptor Scan Gauge EmptyMon Sep 24, 2007 2:43 pm
The button is on the guage face?
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   FAQ: Aeroforce Interceptor Scan Gauge EmptyMon Sep 24, 2007 11:01 pm
Yes, 2 of them. You can display two params at once.
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   FAQ: Aeroforce Interceptor Scan Gauge EmptyMon Sep 24, 2007 11:39 pm
Can someone list all the parameters the Aeroforce gauge can display? Thx.
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   FAQ: Aeroforce Interceptor Scan Gauge EmptyTue Sep 25, 2007 3:10 am
Aaron, did you see the .pdf -
Link
Maybe you did, since the .pdf doesn't have a full listing either dunno
High intensity LEDs can be used as shift lights or warning lights to indicate when a
selected parameter exceeds an entered threshold.
That sounds cool.
What about this:
Two user configurable analog inputs
Would it be possible to run an input from the fuel sending unit into one of the analog inputs? Then those of us with nutty fuel sending units could get a NAPA sending unit, configure the Aeroforce guage to read it, and have a functional sending unit again.
Then you could get the double guage deal and replace both the temp and gas guages in the dash.
If you really wanted to get crazy perhaps you could find a way to rewire the scan guages to be controlled by the steering wheel buttons.
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   FAQ: Aeroforce Interceptor Scan Gauge EmptyTue Sep 25, 2007 8:37 am
No didn't see it. That helps, thanx.
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   FAQ: Aeroforce Interceptor Scan Gauge EmptyFri Jul 11, 2008 1:28 pm
The Aeroforce gauge I bought has these new options on it:
"Bidirectional controls for GM, Ford, and Chrysler including fan control, CASE re-learn, PCM/TCM
reset, and Power Stroke injector buzz and cylinder contribution tests"
What the hell does this mean in English?
Edit....nevermind...they have an on-line manual
Supercharged
Supercharged
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   FAQ: Aeroforce Interceptor Scan Gauge EmptySat Jul 12, 2008 12:39 pm
how much PSI are you getting
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   FAQ: Aeroforce Interceptor Scan Gauge EmptySat Jul 12, 2008 8:58 pm
Don't know yet...the gauge gets here next week....I'll post the numbers then
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   FAQ: Aeroforce Interceptor Scan Gauge EmptySun Jul 13, 2008 1:28 pm
I think you're going to like the Aeroforce gauge. If they had been available back when I bought my scanning software, I would've got the Aeroforce instead. Wouldn've saved me buying a laptop and palm device, plus it's a pretty cool-looking gauge.
rivwilly107
rivwilly107
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   FAQ: Aeroforce Interceptor Scan Gauge EmptySun Jul 13, 2008 2:31 pm
How does this compare with the HP Tuner,can you tune the pcm with it , or does it just display things.To me it seems somewhat pointless unless you can correct through programming.
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   FAQ: Aeroforce Interceptor Scan Gauge EmptySun Jul 13, 2008 2:40 pm
Aeroforce has no tuning capability, but It's not pointless to scan. You can "tune" by changing SC pulley size, doing mods, etc. Programming the PCM is usually the next step.
rivwilly107
rivwilly107
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   FAQ: Aeroforce Interceptor Scan Gauge EmptySun Jul 13, 2008 2:51 pm
I see your point,I just like the idea better of progressing forward instead of finding that you have to de-mod your car to make it work.For 200.00 more you could make your mod work through programming.I know I'm not adding anything new that everyone doesn't already know , just voicing my goal and my opinion.I would however love to know now even through basic scanning to ensure no damage is occurring.
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   FAQ: Aeroforce Interceptor Scan Gauge EmptySun Jul 13, 2008 3:09 pm
I totally understand where you're coming from, and you're absolutely right that by spending a bit more, you going to get the extra capability. The Aeroforce has another useful advantage, though:
It's permanently installed, acting as a gauge and has programmable alarms.
There is a very good chance you will not use your HP Tuners scan software everyday, and even if you did, it's not really safe or smart to monitor using a laptop or PDA while driving. So you have to log instead. The Aeroforce lets you record, but it also lets you monitor real-time. Could warn you of a potential problem days or weeks before you would notice any hard symptoms.
rivwilly107
rivwilly107
PostSubject: temp   FAQ: Aeroforce Interceptor Scan Gauge EmptySun Jul 13, 2008 3:49 pm
Great ! Now I need both! Thanks Aaron. happy
PostSubject: Aeroforce Gauge   FAQ: Aeroforce Interceptor Scan Gauge EmptyWed Jul 16, 2008 9:24 am
This weekend I'll be installing my Aeroforce gauge. What parameters should I program for scanning?
I can have up to 8.....Knock Retard and Boost are first on my list, so I need 6 more that I need to choose. Which ones are the important ones that I need to look at?
# RPM
# MPH
# Intake Air Temperature
# Mass Air Flow Sensor Frequency
# Mass Air Flow Sensor (lb/min.)
# Engine Coolant Temperature
# Injector Pulse Width (bank 1 and 2 if supported)
# Long Term Fuel Trim (bank 1 and 2 if supported)
# Short Term Fuel Trim (bank 1 and 2 if supported)
# O2 Sensor Voltage (bank 1 and 2 if supported)
# Manifold Pressure in PSI (Boost pressure for factory
turbo/supercharger applications)
# Ignition Advance
# Knock Retard
# Engine Run Time
# Misfire information
# Battery Voltage
# Transmission Temperature
# Transmission slip speed
# Remaining fuel
# Throttle Position Percentage
# Throttle Position Voltage
# Oil temperature
# Fuel economy (vehicle must have a MAF)
# Fueling status (open or closed loop)
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   FAQ: Aeroforce Interceptor Scan Gauge EmptyWed Jul 16, 2008 9:32 am
Can you make different programs for different parameters? Like a "driving" program could have:
1) KR
2) Boost
3) Fuel Economy (if it works)
4) IAT
5) LTFT
6) Current Gear
7) RPM
8) Trans Temp
A "Tuning" program could be:
1) KR
2) LTFT
3) O2
4) A/F
5) MAFF
6) Timing (Ign Adv)
7) IAT
8) RPM
A "Trans" program could be:
1) Trans temp
2) Shift time
3) TCC status
4) Deliv torque
5) Slip speed
6) RPM
7) Current gear
8) MPH
With my AutoTap software, I can select from preprogrammed Config files to scan for different sets of parameters.
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   FAQ: Aeroforce Interceptor Scan Gauge EmptyWed Jul 16, 2008 9:37 am
I don't think you can have separate programs with multiple parameters. Thats why I think alot of people put 2, or sometimes 3 of these gauges in their car. I need to read more about it....
But thats a great list you wrote....thanks for the help.
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   FAQ: Aeroforce Interceptor Scan Gauge EmptyWed Jul 16, 2008 9:57 am
It really depends on what you are trying to do. For everyday driving, I would want different parameters than if I were scanning/tuning the PCM. Hopefully programming isn't too difficult.
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   FAQ: Aeroforce Interceptor Scan Gauge EmptyWed Jul 16, 2008 10:04 am
It looks like programming the gauge is a piece of cake.....just push one of the two buttons and toggle to the parameter you want to scan...
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   FAQ: Aeroforce Interceptor Scan Gauge EmptyWed Jul 16, 2008 10:06 am
maybe the thing to do is write the parameters for each of the different programs on a card & put in glove box - so you don't spend time re-figuring parameter sets. Program in the driving parameters, and if you want to tune pull the card and change some parameters?
just a thought.
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   FAQ: Aeroforce Interceptor Scan Gauge EmptyWed Jul 16, 2008 10:18 am
For a first scan, I'd go with these:
1) LTFT
2) MAFF
3) O2
4) IAT
5) KR
6) Timing
7) Boost (or MAP)*
8) RPM
*AutoTap does not show boost, but it can be calculated from MAP if you know barometric pressure.
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   FAQ: Aeroforce Interceptor Scan Gauge EmptySun Jul 20, 2008 4:00 pm
Installed the aeroforce! Such an awesome gauge!!
Just did a quick scan on a couple parameters until I figure this thing out.....
The P0141 code is now fixed (thanks everybody, points at AlbertJ and BillBoost....plug was not on all the way. Also re-routed those sparkplug wires)
Very little knock under load (1.0 and under with a 3.5" pulley and stock exhaust)
Two things though....
(1) When I bring up the misfire screen it shows misfire on cylinders 1, 4 & 6 at idle and only for a few seconds...then its at zero for all cylinders even at WOT...it seems it only happens at a cold start up....is this normal or something I should be looking at?
(2) Very little knock for a very little time.....you think its safe to drop to a 3.4"??
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   FAQ: Aeroforce Interceptor Scan Gauge EmptySun Jul 20, 2008 4:45 pm
I have a Intense MPS 3.4 I am not using if you want to drop.
Page 1 of 6Go to page : 1, 2, 3, 4, 5, 6  Next
» Scan
» FAQ: Do I need a scan tool?
» New MAF Scan
» Scan Tool Purchase Advice - Auto X Ray EZ Scan 6000
» scan
