 Exhaust tips?
BrianEsser
florence_x
VJD2
ghost88
97rivsc
KillaKeninaRiv
riviera2454
manofmany
Ridin-Rivi
99 Riviera 99
Sag
jrocha
97rivman
97Riv-Jon
Orca
ender467
TType_Riviera
¤DoughBoy¤
59 posters
Go to page : Previous  1, 2, 3 ... 5, 6, 7 ... 9, 10, 11  Next
Exhaust tips? - Page 6 Empty
PostSubject: Re: Exhaust tips?   Exhaust tips? - Page 6 EmptyWed Mar 26, 2008 12:17 am
Thanks, Ben, for explaining about the sound - you are right I missed your comment.
I like the way the stock exhaust burbles at idle and is quiet at cruise. I was thninking that an exhaust that roars on hard acceleration but is quiet otherwise would be fun - but it also is definitely not a priority. Something like a s/s cherrybomb style resonator and a pair of rear mufflers that use baffles rather than fiberglas to cancel out sounds - if done right there's no restriction problem but...
99 Riviera 99
PostSubject: Re: Exhaust tips?   Exhaust tips? - Page 6 EmptyFri Mar 28, 2008 2:53 pm
How much does it cost to get those professionally installed?
PostSubject: Re: Exhaust tips?   Exhaust tips? - Page 6 EmptySun Mar 30, 2008 5:40 pm
I don't know... it was probably $100 or something. They had to cut off the old tips and weld the new ones on, plus straighten my pipe.
So I'm not sure.
jrocha
jrocha
PostSubject: Stainless Steel Chrome Tips (I'M LOVIN IT)   Exhaust tips? - Page 6 EmptyMon Mar 31, 2008 4:40 am
I've had these tips for almost a year just sitting around in the garage, until one day I started to clean out some things and came across them again.
Well here they are finally installed, and not to my surprise, they look as good as I thought they would when I first saw them online.
I was really split between the round and the square, but because the Riv is so "rounded" I decided to go with the double round.
Whatever the shape, it will always look better with the double tip on either side.
I'll shut-up now and start the sharing,
thumbsup thumbsup
Exhaust tips? - Page 6 SH102953
Exhaust tips? - Page 6 SH102952
Exhaust tips? - Page 6 SH102951
Exhaust tips? - Page 6 SH102950
Exhaust tips? - Page 6 SH102949
Exhaust tips? - Page 6 SH102946
http://www.24quilates.net
PostSubject: Re: Exhaust tips?   Exhaust tips? - Page 6 EmptyMon Mar 31, 2008 6:41 am
Grooovy! clap
Bert tavis
Ridin-Rivi
Ridin-Rivi
PostSubject: Re: Exhaust tips?   Exhaust tips? - Page 6 EmptyMon Mar 31, 2008 11:38 am
I like the tips... Very nice!
PostSubject: Re: Exhaust tips?   Exhaust tips? - Page 6 EmptyMon Mar 31, 2008 3:44 pm
there bad ass, they look just like corsa tips
Sag
Sag
PostSubject: Re: Exhaust tips?   Exhaust tips? - Page 6 EmptyMon Mar 31, 2008 6:07 pm
Really nice cool
PostSubject: Re: Exhaust tips?   Exhaust tips? - Page 6 EmptyTue Apr 01, 2008 12:42 am
Verry snazzy
PostSubject: Re: Exhaust tips?   Exhaust tips? - Page 6 EmptyFri Apr 04, 2008 5:35 pm
You got my vote!
More interesting, however, is that your Riv. has a landau top! Haven't seen one of those... neat!
jrocha
jrocha
PostSubject: Re: Exhaust tips?   Exhaust tips? - Page 6 EmptyFri Apr 04, 2008 6:08 pm
I keep getting asked if it's a convertible?
I wish, Maybe one day I'll take a chainsaw to it!!!
Thanks man
jrocha
jrocha
PostSubject: Re: Exhaust tips?   Exhaust tips? - Page 6 EmptyMon Apr 14, 2008 11:41 am
I got these off Ebay too for something around $100. Which I think is worth it considering the condition of the OEM that were on there.
PostSubject: Exhaust tips?   Exhaust tips? - Page 6 EmptyMon Jun 23, 2008 7:57 am
I'm thinking about changing out my yucky, black tips for something a little shinier. I was wondering, can the stock ones be removed easily, what diameter am I looking for, and can a replacement simply bolted- or clamped-on?
I'm liking these magnaflow tips, they're cut at a 45* angle, with a 2.5" inlet and 3.0" outlet. Click the picture for the amazon.com page.
Exhaust tips? - Page 6 31eClD-JMDL._SS500_
They're also available with a 2.25" inlet and 3.5" outlet here:
LINK
And 2.25" inlet with 3.0" outlet here:
Exhaust tips? - Page 6 31Y03S4K1TL._SS500_
They're all 18 inches long, by the way.
PostSubject: Re: Exhaust tips?   Exhaust tips? - Page 6 EmptyMon Jun 23, 2008 10:21 am
Anyone? Does anyone know the diameter of the inlet for the tips?
PostSubject: Re: Exhaust tips?   Exhaust tips? - Page 6 EmptyMon Jun 23, 2008 10:36 am
1 3/4 inch i believe. the 18" tips will stick out really far unless you have the mufflers moved back or you get new ones. if you look at the stock tail pipes, they are kind of S shaped in order to make the tips stick out straight. there isnt much straight pipe directly behind the stock tips to bolt up an 18" tip to w/out it sticking out from the bumper 12"+.
you may be able to make the 2.25" bolt up to the stock pipes. depends on how the clamp is. if they are the weld on kind, you may need to have the exhaust shop bend up some new tail pipes to weld them to.
Exhaust tips? - Page 6 Dsc_0110
PostSubject: Re: Exhaust tips?   Exhaust tips? - Page 6 EmptyMon Jun 23, 2008 11:32 am
Okay, so those are out of the question. Would 2.25" inlet tips work, like these? How about a 2.25" clamp, would that be too wide to fit properly? Says some of them have to be welded on, any idea what that would cost? Also, how would I get the original tips off, should I let the shop that's gonna weld the new ones on take care of that?
LINK
Exhaust tips? - Page 6 41T4QCYVRWL._SS500_
Those are still a little more than 7" long. I also found these which are only 4.5" long.
Exhaust tips? - Page 6 Mpe-35125_w
PostSubject: Re: Exhaust tips?   Exhaust tips? - Page 6 EmptyMon Jun 23, 2008 11:51 am
the shop will take the old ones off. i dont know how much it would cost, but if the 2.25 fits over the stock pipes and the guy is able to get a weld on the 2 to hold, then it shouldn't cost much at all. when i had mine done, i had 3 tips and i gave the shop one of the tips in exchange for welding the new ones on. i told them it was worht ~$50. i also had new pipes made up to go from the mufflers to the tips. i think i used 2" pipe. and i had them mandrel bent for a case of beer happy
PostSubject: Re: Exhaust tips?   Exhaust tips? - Page 6 EmptyMon Jun 23, 2008 12:01 pm
Okay, thanks! I'll call around with the local shops for pricing, although I can't think of anywhere like that around here.
Merit : 90
PostSubject: Re: Exhaust tips?   Exhaust tips? - Page 6 EmptyWed Jul 02, 2008 4:59 pm
little late but...
99Rivman wrote:
I'll post pics of mine when and if I ever get them on headbutt
I have tips like Matthew for my black '95 only in black chrome, I thought that would look better on a black Riv thumbsup
Well I'm a lot late but figured I'd post'em here anyway!
Exhaust tips? - Page 6 Exhaus10
Exhaust tips? - Page 6 Exhaus11
Exhaust tips? - Page 6 Exhaus12
PostSubject: P/s request   Exhaust tips? - Page 6 EmptySun Jul 20, 2008 4:05 pm
Could someone move the exhaust tips to the center of the bumper and move them up a litte into the Gray area of the bumper.
Exhaust tips? - Page 6 Rivoneyearlater026
I am trying to plan a center exhaust for my car with my current tips.
thanks in advance
PostSubject: Re: Exhaust tips?   Exhaust tips? - Page 6 EmptySun Jul 20, 2008 4:11 pm
I can help you out tommorrow....no photoshop at home.
PostSubject: Re: Exhaust tips?   Exhaust tips? - Page 6 EmptySun Jul 20, 2008 4:52 pm
Thanks Chicken!
PostSubject: Re: Exhaust tips?   Exhaust tips? - Page 6 EmptySun Jul 20, 2008 4:56 pm
you want the two together centered under the license plate, but molded into the rear bumper, right?
PostSubject: Re: Exhaust tips?   Exhaust tips? - Page 6 EmptySun Jul 20, 2008 5:06 pm
Yep!
PostSubject: Re: Exhaust tips?   Exhaust tips? - Page 6 EmptyMon Jul 21, 2008 9:07 am
here ya go...
Exhaust tips? - Page 6 Oldsok8
Exhaust tips?
Page 6 of 11Go to page : Previous  1, 2, 3 ... 5, 6, 7 ... 9, 10, 11  Next
» new persons s/c 95 riv
» What do our exhaust tips look like, originally?
» stock tips - side exhaust
» A Real Head Turner
» KANDY any one????????
